Question about Hampton Bay 24002 Ceiling Fan
Ceiling fan My fan has a buzz when running at the middle speed, I need to know what can be done to fix this, it's really annoying. thank you for your help
  • 883 Answers
Isolate the buzz: 1. completely disconnect it from the mount and have an assistant hold it...turn it on ms 2. if buzz stops, then remount using packaging foam (or wood tile under-layment foam) 3. if buzz, then electric coil for ms is faulty...new motor
Posted on May 20, 2007
SOURCE:
Annoying sound
Hi Anita
Determine source of Buzz
Speaker --- Computers sound channel Amplifier
Left or Right channel
Can you hear buzz in earphones
Fan --- Speed changes with Temperature - insects or junk hitting on fan
CD --- Player mechanism - CD media left inside
Good Luck
Dec 06, 2013 | Toshiba Satellite Computers & Internet
I just replaced my manual thermostat with a programmable one. The problem is the old one was positioned under a ceiling vent. Now the programmable one cause the heat to cut on and off before the room...
Move the wall thermostat to a new location away from the ceiling fan or stop using the ceiling fan. Also, try running the ceiling fan in reverse (counter clockwise when you're looking up at the fan blades) on slowest speed. That might solve the problem, too.
Please let e know is that helps.
Rich
Feb 07, 2011 | Heating & Cooling
I just bought a new construction patio home with two of these fans already installed--one in the living room and one in the master bedroom. I quite like the looks of the fans, but they both have a low...
sorry to tell you but the buzzing you here is the motor,,this is caused by the mains frequency and there is nothing wrong with them,, thats how they are,,,and if there screwed to a beem in the roof that amplifies the buzzing sounds then your stuck with it,
Oct 18, 2010 | Ellington ELGD52ABZ5 Grandeur Ceiling Fan
Lemon chain switch
To get a free switch you will have to take it out and take it back to where you bought it and they will replace it or just take the whole thing back and get a brand new one because of the switch. thats the only way you will get a free switch.
Apr 21, 2010 | Aloha Housewares (93645) Ceiling Fan
I have a dell dimension E510. When the computer boots up it runs fine for about 5 minutes, then the fan begins to speed up. It will speed up a little, then drop off a little surge more and then the end...
If the fan is clanking/clicking it needs to be replaced, a whine is an indication that the fan will be failing soon and will need to be replaced.
In general if the fans are spinning really fast it means that the system is getting hot and needs cooling. make sure to clean out your system regularly. http://www.pctechbytes.com/DIY/maintenance.htm
You may need to get another fan or two to install in the system to increase air flow, or move the system to a better ventilated area.
Dec 31, 2009 | Dell (6F858) Cooling Fan
My Hunter fan will only switch from high to low speed and won't
if the three speed switch is functioning the middle speed winding is bad.  Either replace the fan or hook up a wall speed control and keep the fan on high.
Mar 26, 2009 | Hunter 23852 Classic Original Ceiling Fan
No middle speed.
Replacing the pull switch (reostat) should have solved your problem. Try going to the internet at www.google.com and in the Google search box enter "Hampton Bay Fans homepage". If any of these suggestions have been helpfull, please rate my solution. Thanks D. Lange
Jul 31, 2008 | Hampton Bay Sidewinder 04890 Ceiling Fan
HI speed on my Hampton Bay ceiling Fan.
If you are looking to lower your fan speed, I suggest getting an adjustable wall switch that will limit the current to the settings. I have the same situation, I myself didn't do it but I know it is possible. In my bedroom, I have my ceiling fan wired to a turn knob switch, a dimmer so to speak, that limits the elctrical current, thus slowing the rpm's of the fan blades.
Feb 25, 2008 | Dryers
Hampton Bay 24002 Ceiling Fan Logo
305 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Steve Allison
Steve Allison
Gene Pitts
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
