Question about Bosch Saws
Bosch PFZ600E blade clamp
The small metal clamp which grips the blade on my PFZ600E has cracked. It no longer grips the blade. Do you know where I can get a replacement clamp please? It's held in by an allen bolt and is like a wide, shallow U
  • David Ford
    David Ford May 11, 2010
    Can you be more specific on the Brand and Model Number. I checked and there is no information in there database. I know exactly what part you are looking for but need this info. Dave
  • 4,234 Answers
Your best bet is to call a local tool repair center. If you post your location, I can provide you a more detailed referral.
These parts are considered normal wear items and are not that expensive. You may also b e able to order the part from your local Home Depot or Lowe's store too. I carry extras of these for all of mine. I think these were about $5 when I bought them.
Dan
Posted on Dec 24, 2008
How to undo the nut on sabre saw pfz600e
then you need to find one that fits . perhaps a metric one
Apr 09, 2016 | Bosch Saws
Need to remove chuck on new BOSCH DDS181-02 18v cordless drill. No screw evident @ bottom of chuck-only small 1/16" hole. How do I remove chuck?
There is supposed to be a Phillips head LH thread screw in the chuck. I have seen the screw head worn down so you can no longer get a screwdriver to work.
We usually cut the chuck off with a metal chop saw just at the screw - thread what remains of the chuck off, which usually leaves 1/4" of the screw sticking out of the spindle - remove with vise grips.
Its not an easy prospect when that happens.
Oct 12, 2013 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
How do i remove a broken blade in the bosch rs 325
Open the chuck and try gripping the bit of broken blade with some tweezers or flick it out with a small screwdriver.
Nov 30, 2012 | Bosch RS325 Compact Demolition...
How do i fix a crack in my radiator in my 1996 chevrolet cavalier
Is your radiator Plastic and metal? or Just metal? where is the crack? Can you see the "crack" or can you just see it leaking antifreze? It could be a hose clamp leak,or small hole? At this point without knowing that it is a crack for sure ,all I can say is check hose clamps ,they also sell a product called Bars . Any auto parts store has ,it seals small radiator leaks ,be sure to follow directions on bottle! I would recommend changing the raditor if your keeping the car,or really depend
on it,they like to go bad at the worst possible times!
Feb 10, 2012 | Cars & Trucks
PLASTIC ON OIL DIP STICK BROKE OFF & IS STUCK.
I've had some success with a jig saw blade if the metal stick came out leaving the plastic behind. I put the blade in the slot with the teeth backwards and use vise grips to clamp onto it.
Mar 15, 2011 | 2005 Chrysler Town & Country
How do you hold the blades on a toro LX460 while breaking the nut loose to change them
Use a piece of 2x4 and a clamp. Clamp the wood to the inside of the deck using the clamp. When the blade comes around and bumps against the wood it should act as a stop. Or you could rig something with a Vise-Grip plier. Lock onto the blade with the Vise-Grip, run a piece of rope from the pliers to a point on the mower where it will stop the blade from turning.
May 23, 2010 | Toro Lawn Mower With Toro Power Tools
The quick clamp chuck on my bosch 600 has seized up and I can't remove the drill bit. Any suggestions please
Hit a metal part of the clamp chuck to just create a "shock" using a hard rubber-hammer (or a metal hammer if the rubber one fails) one or two times. Chuck grip will loosen on the bit for you to remove it.
Dec 21, 2009 | Bosch Drills
Not sure how the blade seats in saw pneumatic bosch jig saw i can get it to go in but the blade seems to wander and seems to be unstable
do you have the screwdriver that came with the saw? if not you need a longer straight slot screw driver and it must be ground down to fit into the blade clamp tightener. it is a narrower than usual screw driver. I lost mine and had to custom make one. good luck.
Sep 14, 2009 | Bosch 7561 - 118 Pneumatic Cutting Tools
Clamp
I use a needle nose vise grip at the top, make sure not to puncture boot. put it around the left side, then i use small screw driver to hold spring on one side, then pull the other side of spring until it goes over boot. Be carefull not to stretch spring to far.
Oct 22, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Saws Logo
484 people viewed this question
Top Bosch Saws Experts
Craig Butler
Craig Butler
mikenearman
Tim Venetis
Are you a Bosch Saw Expert? Answer questions, earn points and help others
