Question about GoVideo Go Video DVD/VCR Combo
DVD slot does not open. Can't insert into it.
Model DV 1030. Purchased in 2004 in CA and was able to use it then. Have not tried to use it since 2006. (So it only had about 1 1/2 year's actual usage. That means an average of 1 DVD every other week.)
The machine is connected to the cable box and I assume all the connections are OK. The power goes on, the VCR part works fine--insert and eject in the VCR are OK. Pressing eject for the DVD does nothing for that slot. I do get the message that I can "Load" and that there is "no disc". Doesn't all of this seem to indicate that everything is connected alright. So what do you think is the problem?
  • vel2eite Dec 24, 2008
    I tried the paperclip route but unfortunately it didn't work. Any other suggestions?
    President:
  • 1,179 Answers
Sounds like the dvd door is stuck. Try using a paperclip in the small hole by the dvd door to open manually. Once opened then try to use the button to close. Hope this helps.
Posted on Dec 22, 2008
Hello, I just purchased a 2004 ford expedition. The overhead dvd player will only show a blue scren after the dv is inserted.. Please help
may need clened because its not recognising a disc.. get a can of dvd spray with the tube on it(like dusting spray) and insert the tube and inch or so inside the slot..spray short bursts of spray into the unit..wait a minute or so and retry..repost findings..
Dec 09, 2013 | 2004 Ford Expedition Eddie Bauer
Jvc sr-dvm700 stuck in "please wait" when powered up
iT MAY BE A DV CASSETTE WAS INSERTED AND HAD A TENSION PROBLEM THAT CAUSED THE PLAYER TO CHEW TAPE . PLEASE SEE IF JVC SERVICE CENTRE IN LONG BEACH CAN REPAIR IT ( GOOGLE FOR THEM) . ANOTHER OPTION IS TO MANUALLY OPEN THE UNIT YOURSELF-
REMOVE THE MAIN POWER CORD OFF .
YOU WILL REMOVE 8 SCREWS TO REMOVE THE TOP COVER OFF - 2 ON EACH OF THE SIDE , AND 4 AT THE BACK , , AND GET THE TOP COVER OFF, THEN YOU CAN PEEK INTO
THE DV TAPE DRIVE TO SEE IF THERE IS A TAPE CHEW UP MESS , IF YOU ARE OKAY TO DESTROY THE TAPE , CUT OFF AND MANUALLY EXTRICATE LOOSE TAPE WITH A FORCEPS , , THEN FORCE EJECT THE TAPE BY TURNING THE BLACK GROOVED GEARWHEEL ONTHE RIGHT FRONT OF THE TAPE DRIVE - BY PUSHING IT INWARDS INTO THE SLOT , YOUR TAPE WILL MOVE UPWARDS , THEN PUSH THE WHITE PIECE ON TOP OF THE TAPE TOWARDS THE TAPE DRIVE DOOR , THE TAPE SHOULD NOW COME OFF THE DOOR , PULL IT OUT .IF THERE IS AND DVD LEFT IN THE DVD DRIVE , YOU CA MANUALLY REMOVE IT BY TAKING OFF 4 SCREWS AT THE TOP BLACK ROOF OF THE DVD DRIVE , AND REMOVE ANY DVD HELD INSIDE .REPLACE THE SCREWS BACK ON THE DVD DRIVE AND THEN CLOSE THE TOP COVER OF THE UNIT .
POWER BACK THE UNIT ON AND SEE IF IT RESETS ITS STATE -
NOT FINDINY ANY PLAYBACK MATERTIAL IN THE DV OR DVD DTRAY - IT SHOULD GO TO OFF , SWITCH OFF THE UNIT FROMTHE FRONT SWITCH AND THEN UNPLUG IT. RESTART THE UNIT AFTER 1 MIN AND IT SHOULD BOOT PROPERLY AS LONG AS FIRMWARE IS NOT CORRUPTED ON ON-BOARD HDD.. PLEASE CHECK IF THE REAR HDD COOLER FAN IS NOW WORKING GOOD LUCK . PLEASE RETENSION ANY DV TAPES BEFORE PUTTING THEM INTO THE PLAYER . EVEN DV HEAD CLEANING TAPES CAN CAUSE ISSUES . JVC WILL NOT ADMIT IT .
Jul 07, 2012 | JVC SR-DVM700 DVD Recorder/HDD Recorder
GO VIDEO model 1030....VCR works fine...DVD..nothing happens...door won't even open?
Combo units have this essential flaw--if one half fails you are usually done especially if the DVD side fails.
If Door does not open either a disc is jammed inside the mechanism or the mechanism is out of alignment or damaged.
Good argument against buying these units--DVD individual parts are rarely sold--only (if available) would be the entire DVD unit itself--not cost effective to repair.
DVD players are now real cheap (see some for as little as $20) so if not a simple jammed disc or something like that buy a DVD player.
Apr 05, 2012 | GoVideo Go Video DVD/VCR Combo
I HAVE PROBLEMS WITH MY ACER ASPIRE M1100 COMPUTER,WHICH I PURCHASED IN 2008. SPECIFICALLY, THE DVD RAM IS NOT FUNCTIONAL AT ALL. THE CD RAM HOWEVER, IS WORKING JUST FINE. PLEASE, HELP ME FIX THIS...
You better check the DVD if this is recognized by going to My computer > Device manager > DVD/CD-ROM drive and see if mark as ( ? ) question mark. also check the IDE slot as well as cable if its properly attach or insert,try to change IDE cable at least. Check the power supply socket all going thru your DVD, might no supply or power entering the drive that's why it's not recognized.
Good luck.
Jun 27, 2011 | Computers & Internet
I need free code multi region of DVD PLAYER , LG DV647
  1. Turn on the player (without disc inserted)
  2. Open the disc tray
  3. (Press PAUSE)
  4. Press 0, 0, 0, (0)
  5. Enter region (1-6; 0=region free)
  6. (Press PAUSE)
  7. Turn it off
Jun 05, 2011 | Televison & Video
Onkyo DV-SP405 DVD player says no disc
This woud be due to two things
1. laser
2. servo motor not spinning to the correct speeds i,e Bad motor
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 11, 2009 | Onkyo DV-SP404 DVD Player
RCA DVD player model DRC285
try sticking a knife on the top of the dvd slot. don't put a lot of pressure to break it though. turn the dvd player on, and it may open. If this solves the issue, try not to put items on top of the dvd player because it will cause it to stick and not open.
Apr 02, 2008 | RCA DRC-285 DVD Player
Unable to open DVD slot
USE A SCREWDRIVER UNDER LIP OF EJECT AREA.SOMETIMES THEY SLIP OR GET OFF TRACK; OPEN UNIT EJECT TRAY THEN RECLOSE IT.SHOULD WORK
Sep 02, 2007 | Cyberhome DVR 1600 DVD Recorder
GoVideo Go Video DVD/VCR Combo Logo
187 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
