Question about Philips PSS110/17 MP3 Player
I have a new philips pss110/05 and I can't get the power to stay
I think this unit was old stock. I can only get the power to stay on by holding the button down. As soon as I let go the on button it swiches off. I have followed a the guide from the philips website but it still does not charge. I think I have loaded the latest firmware (by keeping my finger on the on switch) but it still does not want to charge or stay on with the mains cable. Can anyone help?
  • cglas415ss41 Dec 25, 2008
    I bought the PSS120/37 and I can't even get it to charge up. I had it charging for about 3 hrs using the AC charger, but can't get it to even turn on. I'm n ot sure if I got a bad unit, a bad charger, o am missing something in the directions. It seemed pretty straight forward but just not working. Anyone know if it can be charged through the USB? At least then I might know what's causing the issue or at least narrow it down.
  • willjolinn Jan 26, 2009
    I am having the same problem. Will not hold a charge.
  • 8,596 Answers
For the person with the model # ending in /05 - that is a non-US model, so it won't work on a US computer.
For everyone else:
Make sure the hold/lock is not engaged
Try another USB port
Reset the player
If that fails:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Repair" tab
If still nothing:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
If these methods fail, call Philips to see if you are still in-warranty.
-Tha Mp3 Doctor
Posted on Mar 23, 2009
I have a bad audiovox AWM 524. How do I replace it?
Contact me I have a new old stock unit in stock .petert@lardners.com.
Jan 18, 2015 | Audiovox Car Audio & Video
I got 2 kicker comps with a boss amp and stock head unit when i get the volume to 20 my subs will just cut out hard like my car battery had no more for that hit do u think it is the stock head unit or am...
Put a new head unit in easier then messing with line converters, use the RCAs outs to amps , ground amps well,, do the big 3. make sure grounds are to bare metal sand the paint off if necessary.
Jan 24, 2013 | Rockford Fosgate Car Audio & Video
I HAVE A 50' PHILIPS MODEL 50PFP5332D/37 FLAT SCREEN TV. I BLEW A BREAKER ON THE TV PLUG IN WITH A PORTABLE HEATER. TURNED BREAKER ON TV CAME ON WORKED FINE. TURNED OFF. 1HR. LATER A RED BLINKING LIGHT WAS...
HI:
This is a plasma unit and philips plasma's are nortorious for bad power supplys, your problem may very well be the power suppy in the television, it is possible you blew a low B+ fuse on the power supply. There is also a issue with the Y-sustain board failing in this model, If you open the back and looking at the unit from the rear the y board is on the left side of the unit and the PS is in the center. disconnect the Y-sustain power plug from the power supply and turn on the unit if the unit stays on with no red light then the y board is bad. it does the same then replace the Power Supply.
Mar 10, 2011 | Philips 50PFP5332D 50 in. Plasma...
Unit does not stay on for more than 5 to 8 seconds. I opened the case and inspected the boards. All capacitors appear normal, there are no visibly burned components, No visible signs of heat. Unit worked...
from your suggestion, i think the problem is come from power supply unit, maybe the transformator was burned or damaged that make no power to the board
the other suggeastion is the power supply componen was damaged
try to check it
Feb 20, 2011 | Philips HTS3410D/37 700W DVD Home Theater...
New install only powers up and ejects momentarily then powers down modle kd-416 reset does not work
remove unit, read instructions line for line and find out what screws were installed incorrectly or which are needed.
Take the the harness and check each wire for proper connection. I always solder and heat shrink mine to a sub harness and then the stock wiring harness stays stock.
Try the stereo out again but do not install it all the way this time. hold it and try the cd. If it works, you probably had the chassis binding or something. Too much pressure somewhere.
Or it is a bad unit that needs to be returned.
Jan 04, 2011 | JVC AM FM CD DET FACE CAR STEREO
When I turn on my Philips LCD TV, It just stays on the "philips" logo home screen...the picture never comes up. Also, I have tried to unplug it form the wall and I also removed the power supply cord from...
It is possible that the TV was hit by a small power surge, and the processor has some garbage in it, and you need to leave it unplug for 40 MIN, and that will reset back to normal. Make sure for at lease 40NIM,
Oct 16, 2010 | Philips 42PFL5603D - 42 IN. LCD HDTV
25 year old Whirlpool side by side fridge not cooling. Thermostat OK, both fans running, relay OK, overload protector stays closed 10 seconds or so then kicks out for a minute or so then closes again and...
hi try out the following settings....
Check your temperature setting.
- Check if no ice present in the evaporator, try the defrosting
- Check vents if air is present if no then check your blower if running or icing evaporator.
- Check your vents if not obstructed with stocks, or the unit is not overloaded with stocks.
- Check if compressor is running continues, if not then you need a qualified technician.
i think after checking this it will work out for u.!!!
thank u
rate me!!
May 01, 2009 | Whirlpool ES5FHAXS Side by Side...
My MP3 player is a Phillips Expanium portable player from the year 2000 - it has worked great all these years till now. I went to play my MP3 and when I press the button to turn it on - all I get is the...
I did not really fix the problem, I think my unit is just old. So I am deciding to buy something more up to date. My unit now is already 8 years old and there are other items smaller in size to carry and more modern.
Thanks anyway.
Jun 01, 2008 | Philips Audio Players & Recorders
Won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Dec 11, 2007 | Philips CDR785 3-Disc CD Recorder
Philips PSS110/17 MP3 Player Logo
138 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
