Question about Dynex DX-LCD37 TV
Blinking light on 37" Dynex LCD
Our t.v. won't even turn on. It was working fine the day before. Then 30 minutes into our cable watching. The screen flickered and shut off. We turned it back on and 5 mintues later it flickered, but this time a white cloud came across the screen. We unplugged the t.v for 2 hours and now the t v wont turn back on. Sometimes it gets close to turning on, but we just get the white cloud before it shuts off. Everytime we try to turn it on the green power light flickers then shuts itself off.
  • 608 Answers
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Posted on Dec 09, 2010
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
Proscan 40lc45s won't stay on
Try changing the input device to something you are sure, works such as a DVD player. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Aug 01, 2012 | Proscan 40LC45S 40 in. LCD TV
Turns off automaticly
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Sep 27, 2010 | Nintendo GameCube Console
    RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
    you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
    Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
    PS3 - Screen Flicker
    You need to try a new HDMI cable.. Cheap HDMI cables do that? I had the same thing happen to me... I switched the HDMI cable and it fixed mine.
    AV
    Jan 14, 2008 | Sony Playstation 3 (PS3) Console
    Mitsubishi VS-45607
    Do self test first goto www.ctechnicians.com
    Dec 08, 2007 | Mitsubishi VS-45607 45" Rear Projection...
    TV picture flickers
    If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
    Mar 01, 2007 | Sanyo DS31520 31" TV
    Dynex DX-LCD37 TV Logo
    1,045 people viewed this question
    Top Dynex Televison & Video Experts
    Jaime Hernandez
    Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
