Question about LG RU52SZ30 52" Television
The word MATURE keeps coming up on the screen
My remote controle will not work and the word MATURE is on the scren.... how do i stop this?
0 characters
1 Points
It's called closed captioning (cc), and maybe theres a button on your remote directly, otherwise you will have to go into menu and find the setting. If you tell us what model you have, we may be able to help you better.
Jun 20, 2012 | Projection Televisions
Our TV is getting a black box over most of the screen and a scrolling number keeps coming up in the box. No matter what we do we cannot get the box to go away. The screen is also very dark. How do we...
The black box on the screen are the work of the captioning function are still on.Tries check the remote control have a button said CC push that CC buton turn all CC1,2,3 all off.Check the menu.Find the captioning function turn off all the text 1,2,3 all off too.The screen is dark,the projection lamp,require changing.
Oct 07, 2010 | Panasonic PT-51SX60 51" Rear Projection...
How do i get a full screen back?
Check your remote control for the picture in a picture feature or split scren feature. Also Unplug the TV and wait a minute. Plug it in and see if that clears it.
Oct 06, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Uverse standard remote control stops working at night
The remote stops working the Uverse box or the TV or both?
Try putting the Uverse box behind the plane of the TV screen so the I.R. that the TV emits doesn't get to the front of the Uverse box.
Mar 20, 2009 | Samsung HL-S5687W 56" HDTV
Tv comes on picture comes
There can be several causes for this, few of which you can do anything about. However, a few things to try.
1) Replace the batteries on your remote control
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
Good luck with your problem...I hope you can work it out.
Oct 04, 2008 | Projection Televisions
TV -Ferguson (Wide Screen) model no: W7023U. unable to operate either with remote control or manually.
Is it possible it has locked itself? It can be locked in 3 ways according to manual.
1. by pressing the remote's stand by key for more than 3 secs.
2. By programming an auto stop.
3. By putting it on stand by after programming a wake-up time.
Flashing "red on" indicates it is locked. It can only be turned on by the remote. Press any number key on the remote to unlock it.
Aug 16, 2008 | Projection Televisions
On screen display keeps coming on
can you specify the model. In most cases it is sufficient to press the info button on the remote control.
Best regards,
Jun 01, 2008 | Projection Televisions
Toshiba rear projection tv
Will the tv power up with the power button on the TV control panel? If so its your remote sensor inside the TV. Let me know your model number.
Jan 21, 2008 | Projection Televisions
Remote Control for Magnavox Big Screen TV (PTV 705-AH01)
sgtdar, list the model & chassis number (located on back of tv), if set is old the universals won`t work because as more newer sets come out they delete the older ones because the chip in the remote will only hold so many codes, BMW Rider
Dec 12, 2007 | Projection Televisions
Trouble w/ my Phillips 50P8341 50 IN. HELP!!!
there is most likely a prob. with the keybd. switches all need to be replaced at the same time.
Aug 22, 2007 | Philips 50P8341 50" Rear Projection...
LG RU52SZ30 52" Television Logo
138 people viewed this question
Top LG Projection Televisions Experts
Steven Wander
Steven Wander
Lawrence Oravetz
Are you a LG Projection Television Expert? Answer questions, earn points and help others
