Question about Toshiba 50H71 50" Rear Projection Television
Toshiba 50H71 Won't Come On
When powered on we hear a click but nothing happens. Red light flashes in the front panel. How can we fix this?
  • babygirl75 Dec 22, 2008
    Hi! Your response seems to be very insightful...is there any way you
    can help me to locate these parts you are referring to? I greatly
    appreciate your help!!
    Thanks Again!
    Kim
    Problem Solver:
  • 13 Answers
This could be caused by several different things.. your convergence amplifier ICs could be bad, causing 1 of the 2 pico fuses to open up.. another possibility could be bad solder or defective hybrid voltage regulator to be bad (its usually a light brown color).. worse case could be a cracked picture tube hidden by the deflection coil on 1 of the 3 tubes.. might also wanr to check if the horizontal output transistor is shorted..there is also a 1A pico fuse that could be open..
Posted on Dec 22, 2008
  • dj70s80s Dec 22, 2008
    Sure.. If I am not mistaken, then if you are facing the back of the tv, the hybrid regulator (Light brown in color) will be to the left of the the set (on same board as the flyback transformer).. I had one which did what yours is doing, and found that the solder connections were bad on this regulator..keep in mind that there is a possibility this ic could be defective.. also very close to this ic you should find a 1A pico fuse (eithere grren or black in color) that could be open.. if its not these 2 things causing the problem, then check the 2 pico fuse for the convergence , which are also on this board... i think they are 4A.. if either of those are open then you will need to replace the STK392-150 ICs.. The horizontal outup transistor is located close to the flyback transformer..check to see if it is shorted...if it is none of these then it might be a cracked picture tube, althought if this is the case usually you will hear some arcing before the relay clicks off.. hope this helps you some
PN50B550T2FXZA won't power up
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Dec 31, 2012 | Samsung Televison & Video
Toshiba 42hpx95 wont turn on.. when i unplug and plug in i can hear a sound but then a red light on the front starts blinking and it does nothing
the blinking light signifies to a repair technician with capacitors or circuits are having an issue they can diagnose the problem via the amount of blinks in between pauses however it will require a technician and some specific tools and schematics to fix and it may be cheaper if its no longer under warranty to purchase a new one
Hope this helped
Robb
Apr 29, 2010 | Toshiba 42HPX95 42 in. Plasma Television
I have a toshiba - 50h71 - i get a clicking noise from the back of the tv, and the red light on the front flashes, no picture what can cause this
Toshiba Lamp 75008204 Y67
lamps-dlp.com$169.95 Toshiba Warranty 180 Days In a Toshiba Box!
You need a new lamp. simple easy fix. just cost's a bit. Thats the part number for your exact tv. You can probley find it cheaper on E BAY
Mar 11, 2010 | Televison & Video
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Fix 50H71 Rear Projection TV
Go to this site and leave an email indicating your model number and what the problem is, they should be able to help you with the problem.
http://servicemanuals.vstore.ca/
May 24, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50h71 red light after fixing the convergence chips
Did you check to be certain none of the resistors were burned or open that power the ICs ? This is fairly common for one or two of the convergenvce resistors to be open when the ICs go out. Also double check the iC pins to insure that none of the pins are bridged with solder. If you need more assistance please let me know.
May 19, 2008 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50 in. Rear... Problem
set most likely has bad convergence ics J.D.W.
Mar 26, 2008 | Toshiba 50H71 50" Rear Projection...
Red Blinking light
the same thing just happened to mine, i was told it might be the diplexer ??? still trying to research it though.
Mar 01, 2007 | Toshiba 50H71 50" Rear Projection...
Toshiba 50H71 50" Rear Projection Television Logo
335 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
