Question about Onkyo TX-SR601 Receiver
More watts needed
Can a pre amp or something be added to a home theater setup to increase the wattage to 2 floorstanding jbl 250 watt fronts?
I have a Onkyo tx- sr601 receiver..
Can the front channels on that receiver be vbidged?
Thanks,
Justin
The TX-SR601 does not have pre-amp outputs. Unless you know how to splice it at the circuit level and install your own RCA plugs, I don't think you can accomplish this task with the 601.
Posted on Jan 11, 2010
  • 85 Answers
Add another power amp to line outs from your main amp to your speakers this will give more power(current) to your main speakers as you have decreased load on main amp
Posted on Jan 08, 2009
Given 1hp motor how to compute the exact amount of amphere use in circuit breaker
You're not going to be able to do this with just a known Horse Power.
There are 3 elements to the equation, with any two, you can work out the third.
If you want to know how the amperage, you will need to know the voltage and wattage of the motor. I imagine that you already know the voltage (It's going to be 220V or 110 volt)
Watts divided by volts = Amps
Examples:
A 220v 1000 watt motor (1000 divided by 220) will draw 4.55 amps
A 110v 800 watt motor (800 divided by 110) will draw 7.27 amps
Bear in mind that most washing machines have a couple of windings for wash and spin. As an average, the was winding will usually be about 500 watts to spin and about 250 watts to wash. ALSO, bear in mind that if you are using this data for a WASHING MACHINE, then there is a water heating element in there too and that draws about 2Kw (2000 watts)
Dont just take this as read, you DO need to check wattages, but, working on what I have just said, the max consumption on a 220V machine will look like this:
At Spin, with a 500 Watt consumption: (500/220) = 2.3 amps
While Washing with a 250 watt consumption: (250/220) = 1.14 amps
Consider that the WASH and HEAT may be running at the same time.
2Kw heating (2000/220) = 9.1 amps PLUS 1.14 amps for the motor - Total wattage 10.24 amps
Watts / Volts = Amps
Amps x Volts = Watts
Watts divided by amps = Volts
Aug 25, 2011 | Washing Machines
I have the phillips hts5580w. how much wattage output does it have? an does this system have a built in amplifier as well?
Anything that drives speakers must be or have amplifiers. They are rated in watts.
http://www.retrevo.com/support/Philips-HTS5580W-Home-Theater-Systems-manual/id/23889dj591/t/2/
It says the power output, presumably in the phoniest of terms - all channels summed together with THIRTY PRECENT DISTORTION which would seriously risk any speaker system and the health of tha amps themselves - is 1000 watts. This is a joke, a lie, marekting at its worst, especially when the totoal power consumption of the unit (that power whci it drwas from the wall outlet) is ONLY 135 watts.
Philips must be onto something no one else has ever seen - they get six times as much sound energy out of the unit as the amount of electricity that goes into it, plus all that heat. That, my friend, would be a miracle and would put all the reputable amp maufacturers, who rate their amps in honest watts per channel at certain (vanishingly low) distortion figures, to shame.
If you push this unit into sustained 30% distortion it will self destruct.
Aug 04, 2011 | Philips HTS5580W Theater System
1 question can Cutler Hammer breakers have the amperage feed through the breakers. To the breaker box and from the box grid to the load. Does it matter which way the amperage is fed through the breaker?...
There seem to be several questions mingled in with those 2 questions.
1) Amps can go either way
2) Breakers trip when heat exceeds certain level. Heat is caused by amps.
3) You want to add a subpanel in garage.
I do not know the code in your area for installing a subpanel.
Your plan will work by connecting 6 gauge wire to main breaker, and new 60 amp breaker will protect wires between main box and subpanel.
Remember, wires going into main breaker cannot be turned off without pulling meter.
Some areas require license to pull meter.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
4) To work around license and meter-pull, simply replace a 240V breaker in main panel with your new 60 amp breaker.
Then move breakers around to match new set-up.
New subpanel can accommodate two new 240V breakers and one new 120 Breaker
http://waterheatertimer.org/How-to-install-a-subpanel.html
5) 6 gauge wire is correct for 60 amp breaker.
6) I'm not sure what you mean by the box rails?
7) Do you need more amperage on main service?
This means adding a larger service panel with 150 Watt or 200 Watt main breaker.
Some areas require service upgrade when remodeling or adding circuits.
8) How to figure total amp draw at your house.
Add up total watts being used.
For example you have 1/2 Hp motor
754 watts per Hp
1/2 Hp = 377Watts
Volts x Amps = Watts
Amps = Watts divided by Volts.
377 Watts divided by 240Volts = 1.57 amps (plus a bit more amperage when motor starts)
40 watt light bulb divided by 120Volts = .33 amps
Double oven has label located inside door that shows upper and lower wattage.
Dishwasher, dryer, big screen TV, satellite receiver all have labels that show wattage.
Water heater has label that shows wattage of each element.
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more help
Feb 18, 2011 | Cutler Hammer 100 Amp Main Breaker...
Car subwoofer just past half volume cuts off the amp
Assuming there is no short, or lose ground wire somewhere inside the box, diodes( in the amp) are fine, you might be overheating it by not allowing it to get good ventilation. This can be a big deal on some low end Chinese amps. Or the speakers are blown , or your Resistors (in the amp) are bad, but for arguments sake.
Most people don't use the proper size and or conductivity types of wiring, for pushing high amperage Think about it like this, Watts (power) =.Amps (energy) x Voltage (pressure) Resistance or Ohm's (amount) determines how much Wattage will go in or out, Ohms = Volts x2 / Watts.
What gauge wire are you using on your setup?
Jan 09, 2010 | Car Audio & Video
Does onkyo HT-s3100 supports 4 Ohms speakers from JBL(control 1)
Palaboy is incorrect. JBL Control 1 speakers are 4 Ohm 150 watt speakers. He's probably thinking of the Control 1x speakers which are 8 ohm 80 watt speakers.
If you hook your Control 1s to that Onkyo, it won't sound great and could cause the receiver to overheat and trip the protection circuit if played at high volume.
Aug 11, 2009 | Onkyo HT-S3100 Receiver
Wattage for Kirby Sentria G10D
The conversion of Amps to Watts is governed by the equation
Watts = Amps x Volts
For example 1 amp @ 110 volts = 110 watts
your case 7 amp @ 120 volts = 840 watts
unless you are running it at 230v but I don't think you can
I would look for one rated for Volt-Amps instead of watts
It's best to round up to be safe add 40 - 60 watts
Don
Apr 25, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Needed watts and voltage of JbL 5000 series platium speakers
If you have one already, just check the wattage on the power supply.
Feb 28, 2009 | HP JBL Platinum Computer Speakers
Turntable to Receiver
Yes you will need a pre-amp to connect a turntable to this unit. For the AUX input you will need something that can output 400mV into 47k ohm, somewhere like RadioShack should have what you need. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 31, 2007 | Audio Players & Recorders
Combining an integrated receiver and an external amp.
yes, you are "forgoing the 100 Watts of my integrated receiver and now just using the 100 watts from the external amp"
Jun 03, 2007 | Home Theater Direct MA-1235 Amplifier
1000 watt amp sony xplod
how do you have your system hooked? What speakers do you have? There is a lot more too it then just wattage.
Jan 23, 2007 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Onkyo TX-SR601 Receiver Logo
162 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
