Question about Brother IntelliFAX 2800 Laser Fax
Tell me how to set the fax. I've obviously doen sseomthing wrong. The phone rings but no fax comes thru. HELP
  • angelvictori Jan 05, 2009
    i still have the same problem
    President:
  • 2,692 Answers
Her is the website site to obtain the instruction manual for  A  Brother(s) Fax machine.
http://www.brother-usa.com/downloads/Default.aspx?WT.cg_n=Support&WT.cg_s=Downloads
Posted on Dec 22, 2008
I can send a fax without any problem, but am not able to receive. I have set it to send after 3 rings, but the phone rings and then my answering machine comes on. I just turned my answering machine off. ...
Set the answering machine to answer incoming calls before the printer does. For example, if you set the answering machine to answer calls after three rings, set the printer to answer calls after five or six rings. Also, make sure the fax line is plugged into the Line port on the back of the printer and the fax settings are correct (phone number, pick-up on rings, etc).
May 12, 2011 | Lexmark X5075 InkJet Printer
Will not receive incoming fax. Everything tests OK
First, Connect the Phone line in Line 1 EXT at back of printer
Check the No. of Rings on your Answer machine.
If you have 4 Rings set on Answer machine then you need to set 6 Rings on the printer ( as simple 2 rings more than your Answer machine )
And you need to turn off ECM on the Printer setup
Press Setup button
Scroll till you find Fax Settings - Press OK
Choose Rings to Answer - Set it - 6 ( based on the Rings on Answer machine ) - Press OK
Check for ECM - Error Correction Mode - Press OK
Turn it OFF - Press OK
Check for Auto Answer option - Turn it ON too.
Try to receive Fax.. it should come thru.
Jul 01, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Can't send or receive faxes
it's most likely the compression on the phone line or you need to set up your fax machine for proper receive mode.
Contact your phone service provider to see if they support faxes.
(Faxes cannot handle nearly as much compression as standard voice)
Jun 09, 2010 | Canon PIXMA MX300 All-in-One Printer
Fax machine rings but fax doesn't come thru at times unless we actually pick up another phone and make a call, at that time the fax comes thru. At other times if we are on the phone, (different from the...
The instruction manuals of fax machines are typically large and complex books. Often there are many options to consider. Mostly the machines can be used successfully without much reference to the manual but when there is a problem the question machine or operator fault can only be determined by thoroughly reading it.
To a large extent whether a fax call is picked up or not depends on the settings (including answering machine), the quality of the phone line and connection and the machine sending the fax as well as the receiving machine.
My fax machine will mostly automatically receive a fax but it seems to miss the important ones and I have to answer the ringing phone, hear the fax tone and press the manual fax button.
I strongly suspect the problem mostly lies with the sending machines - if they are fax machines the results were much better than from a computer being used as a fax machine and while a fax machine will send a receipt, a computer doesn't seem capable of doing so.
Sep 06, 2017 | Brother IntelliFax-4100e Fax
Canon 1023if not receiving faxes automatically
Is this fax line shared with the phone? I believe there is a distictive ring setting in the add'l functions area under communication settings then receive settings. you would need to select a ring pattern different so the fax can tell between which types of calls it is receiving.
It has worked for me in serveral other installs
Hope this helps
TankMurdock
Apr 09, 2009 | Canon imageRUNNER 1023iF Black and White...
Fax machine will not reset to be able to answer the phone
When you set your fax machine to answer on a certain number of rings it will answer it on that number of rings expecting it to be another fax machine. If you do not answer it before the aloted number of rings you will not be able to talk since the fax machine will be trying to talk in computer speak. To help you may want to set it to answer after more rings.
Jan 15, 2009 | Office Equipment & Supplies
Canon Pixma MP530 - Want to setup machine & phone properly
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Canon PIXMA MP530 All-In-One InkJet...
I have a JX300 fax machine. I have it set up for Tel/Fax with message manager on my phone. I have it set to pick up on 5 rings. It says receive and then disconnects sometimes. Some faxes do come...
Try reducing the number of rings on answer, it could be the sending machine is timing out from not getting answered soon enough. Try 3 rings, if that works, then try 4 rings...find out which one works best.
Jul 10, 2008 | Office Equipment & Supplies
Fax machine beeping - Samsung SF5100
YOUR PROBLEM IS NOT VERY CLEAR,PLEASE TELL WHETHER--- A. DO YOU GET DIAL TONE ON THE MACHINE? B.WHEN THE MACHINE GETS INCOMING RING -IT IS SET TO ANSWER ON HOW MANY RINGS ? C. SWITCH OFF THE DRPD MODE. D,CLEAR THE MEMORY OF THE MACHINE TO FACTORY DEAFULT BY--SWITCHING ON THE MACHINE WHILE HOLDING THE STOP BUTTON AND THEN COOSING YOUR COUNTRY WHEN PROMPTED. SHOULD TAKE CARE OF THE PROBLEM... HAPPY FAXING OMNIPRESENT
Sep 25, 2007 | Office Equipment & Supplies
Brother IntelliFAX 2800 Laser Fax Logo
46 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
