Question about Dacor Preference PGR30SS Gas Kitchen Range
Fault code F1 shows and stove is beeping and won't shut up. Have pressed cancel which silences alarm for 15 seconds but then it starts again, every 15 seconds. The only way we have remained sane is to trip the electrical breaker at the box. Is there a way to silence the alarm untill I can get someone in to repair?
SOURCE: Dacor RSD30S F1 Error Code
F1 Element relay circuit failure - The relay circuit would need to be replaced.
the part should be available at
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
just type in RSD30S into the search.
Posted on Jul 30, 2008
See item description at link (Relay pcb range 105 c; ers )
SOURCE: F1 Error Dacor oven
I'm Neil and glad to be at your service!
This time you need to call service!
For a good service you might try,
A&E Factory service
1-800-905-9505 7days / 24hours Nation Wide
Please give me a solution rating here at fixya.com
Thank You
Neil
Posted on Aug 24, 2008
SOURCE: Dacor duel fuel range
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
92028 RELAY PCB, 105 C
Posted on Aug 25, 2008
Nov 16, 2010 | Dacor ECS127 Epicure Electric Single Oven
Jul 30, 2008 | Dacor Preference RSD30 Gas Kitchen Range
Nov 09, 2009 | Kitchen Ranges
Aug 20, 2009 | Dacor ECS130 Epicure Electric Single Oven
May 14, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Dec 16, 2008 | Ovens
Jun 29, 2008 | Ovens
Apr 25, 2008 | Dacor ECS127 Epicure Electric Single Oven
Nov 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
425 people viewed this question
Pushed cancel button. After a short time it began beeping again. Failure code F1
Same problem with F1 code and beeping. The only solution has been flipping the breaker.
I have that problem too. Usually when I turn it up to 400 degrees or higher and then shut the oven off when I'm done. It never happens when I shut the oven off after it was set at a lower temp. It seems I can avoid the problem when I set the stove to a high temp, and when I'm finished, turn the stove off and leave the door open until it cools off.
I have the Millenia single wall oven and when I tried to have it self-clean, it began beeping and flashing F8. I hit cancel and it starts again in 2 mins. It's just before the holiday weekend and I don't think I can get a service rep out here over the next few days. Does anybody have any ideas how to shut this thing up?
