Question about Sanyo VPC-S500 Digital Camera
Deleted Pictures I took over a 150 pictures on yesterday .... I pressed the reset number's button .... and it "erased" all of my pictures ... is there anyway I can get them back ?????
  • 4,806 Answers
There is a way to get them back but its a job in itself, firstly you need a data recovery program and you have to connect the card to a pc, run the data recovery program and you want a format/deleted recovery, this should recover your deleted pictures
kind regards
Posted on Dec 22, 2008
How to delete photos on digital cmera A3100 IS Canon
Bring up the pic you want to delete...press the button with the garbage can icon...follow the on-screen instructions.
Mar 02, 2011 | Canon PowerShot A3100 IS Digital Camera
How to remove time stamp /Date off a picture that has been or will be taken?
For future pictures: In any mode, press the MENU button. Use up/down to select Setup (wrench) and press the OK button. Use up/down to highlight "Date Stamp" and press OK.
For pictures that have already been taken, you can edit them just like any other photo. However, the pixels behind the numbers are already lost. You can erase the numbers just like you can erase a person or a tree, but you won't be able to perfectly restore what was there.
Dec 24, 2010 | Kodak EasyShare Z650 Digital Camera
A couple of weeks ago my 2GB memory chip got full. I put the chip into my laptop and copied all the pictures and then deleted the pictures from my laptop. Since then, I am having problems taking...
Erasing the pictures using the computer is the problem. Your camera does not recognize the card anymore. If your pics are safely on your computer, format the card in the camera to get it working again.
Oct 16, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Yesterday my card was working fine, it kept telling me that my card was full so i just deleted older pictures.. Now i'm trying to upload pictures and it is telling me i need to format my card but that will...
Yesterday, did you use the computer to delete the older pictures? Don't ever do that. For now, you can use a card reader to download your pictures to your computer. After they are safely downloaded, format the card in the camera and don't let it get that full again.
Aug 02, 2010 | Polaroid i1236 Digital Camera
Deleting images
Generally your camera will have a main menu, which lists this as an option.
Look for a menu button on your digital camera. While the camera is on, press this button, and cycle through the options that appear, watching for a listing which says something like "Erase all".
Usually there will be another button or set of buttons that have arrows on them, and let you move up and down among the listed options. Press the up or down button (or the right/left button, whichever applies to your camera), until the "Erase all" option is highlighted.
There should also be a button on your camera that says something like "Ok" or "Function Set"; no matter what it's called, the important thing is that it is NOT one of the buttons which either opens the menu listings (the one I'm describing as the "menu" button, regardless of what your camera calls it), or moves between menu items (the up/down/left/right buttons). Once you have found the menu item for "Erase all", and have highlighted it, press this button.
You will probably get a message asking you to verify your choice, since once the photos are deleted from your camera, you won't be able to retrieve them, so most cameras will ask you to confirm any erasing you do, whether it's just one picture, or all the pictures in your camera's memory/storage. You confirm the deletion by pressing the same button that you used to start the deletion process.
So, to recap:
1) Turn the camera on.
2) Find and press the "Menu" button.
3) Find and press the arrow/next button until you see a menu item saying something like "Erase all".
4) Find and press the "OK" button -- or whatever button will get the camera to accept the menu item selection you've made.
5) If the camera asks you to confirm your choice, use the arrow/direction keys to highlight the "Yes" or "OK" option in the confirmation window.
6) Press the same button you used to start the process ("OK" or "Function Set"), one more time to confirm your choice.
7) The camera should now delete all of the photos in its memory.
WARNING: DO NOT DELETE YOUR PHOTOS UNTIL YOU'VE DOWNLOADED THEM, UNLESS YOU ARE ABSOLUTELY SURE THAT YOU'LL NEVER WANT THEM. It is always better to have an extra backup of your pictures than to permanently lose something you can't replace.
If anyone else has used the camera, it's best to check with them to make sure that they've downloaded their pictures off of the camera, before doing a full delete of all pictures on the camera.
Most cameras will also let you individually delete pictures that came out badly, or where you accidentally took a picture you didn't mean to take. If you're not sure what else is in the camera's memory, it's always wisest to use this method, instead of deleting all the pictures at once.
Apr 02, 2009 | Cameras
Small black squarowing up on all my pictures on Nikon D80
Have you checked that the exposure compensation isn't set to anything other than zero?
Sep 18, 2008 | Nikon D80 Digital Camera with 18-135mm...
My camera erased my pictures
use a recover program...like the one used to recover data from formated dvds..and use it on your memory card,inserted into a card reader..I dont suggest you to use it in the camera
and you can do the same with moving pictures..use the copy/paste option...put them into the card...attention...only D40X made pictures..
good luck;)
Feb 04, 2008 | Nikon D40x Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Sanyo VPC-S500 Digital Camera Logo
Top Sanyo Cameras Experts
ray gallant
Are you a Sanyo Camera Expert? Answer questions, earn points and help others
