Question about PANDIGITAL (DPF802) Digital Picture Frame
The slideshow on frame displays photos out of numeric order
Hi - I numbered all the photos in a timeline so that the slideshow on the frame would reflect the order, but the frame shows the slideshow slightly out of sync. When I plug the frame into my computer, the file shows the numeric order correctly, but the slideshow is not working properly. It's not on the shuffle mode.
How do I fix this?
  • Anonymous Jan 01, 2009
    The previous poster stated the problem pretty well. I have a Pandigital 7 inch frame. The slide show starts out in file name order but jumps later into the list and proceeds from there to go backwards. Does anyone have a any help for us?
    Thanks
2 Suggested Answers
  • 157 Answers
SOURCE: new xD M+ card won't work in the digital photo frame.
Alot of the digital photo frames will only display images up to a certain resolution. There is a good chance your camera resolution is too high for the photo frame. try change the settings on your camera to 3mp or so and take a few photos and see if they will display.
Posted on Jun 16, 2009
How to start slideshow after selecting the pictures
When you power on the picture frame, a slideshow will automatically display the photos on your memory. (If you have not inserted a memory card yet, the slideshow will display the photos pre-loaded into the internal memory.)
To restart the slideshow, press
ENTER again, or press the Slide Show button on the remote control.
May 05, 2014 | PANDIGITAL 7-Inch Digital Photo Frame with...
Tip
Polaroid IDF-1030 Digital Picture Frame - Slideshow with Music
The manual for the Polaroid IDF-1030 is ridiculously simple and not very helpful. There's actually more information on the outside of the box.
One of the features that is not intuitively easy to figure out is how to get the frame to display a picture slideshow AND play music at the same time. The remote is the only way that you can set this up.
First, on your computer, create a folder for the images and a folder for the music. If you put music in the images folder, your slideshow will stop at the first music file it finds and just display the music player's equalizer interface. This is very boring.
Note on the pictures.. spend a little time and reduce the size of your pictures to 640 x 480 pixels. Dealing with large files on the photo frame is painfully slow.
images should be in JPEG (.jpg) format although it will also display .gif files. Music should be MPEG (.mp3) format.
Copy these folders to the root of your memory card.
Put the memory card in the Polaroid frame card slot and turn it on.
Use the remote and press the STOp button if it automatically starts displaying the pictures.
Press the MUSIC button and select the REPEAT button until you see REPEAT ALL at the bottom of the screen.
Press the PLAY/PAUSE to start the music, then immediately press the SLIDESHOW button to start the slideshow with music.
I hope this helps some of you who had trouble with this.
on Jan 07, 2009 | Polaroid IDF-1030 (826219006783) Digital...
Whenever I load photos onto my photo frame from the PC, they all seem to transfer just fine. But then when running the slideshow, not all the pictures are showing up. When I go into the photo menu on the...
The issue may be due to the file types of the pictures you are sending to the frame. You did not include the model number of the frame, so I can't be sure of the file types it can display but generally, JPG file types enjoy the most compatibility on such devices.
You should determine the file types of the images you are sending to the display. While displaying the slideshow, make a note of an image that displays properly. Look at the the image on your computer and check the file details to learn which file type it is. Play the slideshow on the frame and double check as many as you can against the list / thumbnails on the computer. After a short time, a trend show be visible. You may find that JPG and GIF files display properly, but TIF and others do not.
If you want those pictures to display, you'll have to convert them to one of the file types that does display. If you're finding that only some JPG (or other displayable file type) do not display properly, you'll have to see what is different. Sometimes, very large files may not display correctly, or it may have "too much color" information (they might be a 16 bit graphic or 16 million colors instead of an 8 bit graphic or 256 colors), or some other issue that isn't readily apparent. You can try resizing or converting to yet another format that is supported by the display (GIF for instance).
This is a starting point - hopefully you'll find the issue within one of these suggestions. Good luck! Please rate my reply - thank you.
Feb 24, 2011 | Philips 6.5-Inch Digital Photo Frame...
How can I make slideshows for youtube?
Youtube only accepts video formats like MP4, AVI, FLV, so you have to make a video slideshow.
To make a video slideshow, you can first make a PowerPoint slideshow with your Microsoft PowerPoint, if you are using PowerPoint 2010, you can save your slideshow to wmv video directly, if you are using PowerPoint 2007 or a lower PowerPoint version, you can use a powerpoint to video converter like
Moyea PPT to Video Converter
http://www.dvd-ppt-slideshow.com/ppt-to-video/
Leawo PowerPoint to Video
http://www.leawo.com/powerpoint-video-converter/
After the conversion, you can upload the video slideshow to youtube smoothly.
May 12, 2010 | YouTube Videos
How do I turn off the clock option during slideshows?
While the Slideshow is playing hit the setup button then go to Enable Clock Display and hit enter. Arrow to off and hit enter. That should do it.
Thanks
Ryan
Mar 25, 2009 | PANDIGITAL 7" Digital Photo Frame With...
Pandigital Frame Photos NOT in order or NOT in sequence..FIXABLE?
i'm having the same problem. I've gotten a good amount of photos going in the timeline order but then it starts messing up again to where it's not in order! GAH i thought i had it! :(
Jan 10, 2009 | PANDIGITAL (DPF802) Digital Picture Frame
Problem displaying slideshow on a Philips digital photo frame (7F
http://www.nodevice.com/user_manual/philips/home_audio-video/7ff1m437e/download.html
Go here and download the manual you need for your Mum's frame. Hopefully it will help you with troubleshooting your problem
Dec 30, 2008 | Cameras
Slideshow on axion digital photo frame
noooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
Dec 05, 2007 | Computers & Internet
PANDIGITAL (DPF802) Digital Picture Frame Logo
78 people viewed this question
Top PANDIGITAL Photography Experts
LP
Are you a PANDIGITAL Photography Expert? Answer questions, earn points and help others
