Question about Refrigerators
2630 icemaker solution
Hi thanks for your solution regarding my icemaker but my refrig doesn't have a numerical display. Will this method work anyway?
  • Icechips Dec 23, 2008
    I have a Samsung RS2630SH it has a series of 1-5 boxes for the display
  • Todd Born
    Todd Born May 11, 2010
    im sorry whart type is yours? do you hjave the model number by chance?
  • 700 Answers
Icemaker is not working
Pour about 2/3 cup of water into the icemaker . If those cubes freeze and dumps but water does not go into the icemaker , replace the water valve behind the refrig ( piece the water line connects to ) . If it does not dump the cubes , replace the icemaker . Also , check the fill tube ( tube which fills the icemaker ) to make sure it is not frozen up . If so , the water valve is seeping and still needs to be replaced . Check the coils under the refrig for dust , lint , pet hair , etc. The coils have to be clean for the icemaker to be 5 degrees , and work properly .
Mar 20, 2011 | Kenmore Refrigerators
The ice maker is not working anymore and the light inside the freezer is flashing red.
Do you have water at the dispenser?
The water tube to the icemaker inside the refrig is frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker stopped working. the water and ice dispense from the door, but it does not make any NEW ice...
Jun 06, 2010 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working on model #frs24zsg
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Jun 06, 2010 | Frigidaire FRS3R5EMB Side by Side...
Kenmore model 79578502800 refrigerator error code 1F. icemaker does not work
Jun 05, 2010 | Refrigerators
Kenmore refrig mod # 507920. Icemaker working
check to see if the hose going into icemaker is frozen. unclog it
Aug 24, 2009 | Refrigerators
I have a Kenmore model 795 77563600 refrig side
This is an error code for the icemaker fan motor.
If the control does not see a signal coming back from the fan motor you will get this error code.
Please see the image below from the service manual that explains the ER IF error code.
http://media.fotki.com/1_p,wkbwtkdqbqkgrkkxgtqsskgwtqkq,vi/ktfgsrbbdxktrrwffdr/1/1303472/5961857/image18067img-or.jpg
The ER IF code indicates a failure of the icing fan.
You may notice slower ice production but the other fans should be okay.
You can select the ultra ice option and see if the fan toggles on.
The fan or the control is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice dispenser
I bought the PSS26MSWSS model (GE Profile) in August 2007. I have had numerous problems with the icemaker. It was out of warranty for the last two visits (Oct 2008) but GE warranteed anyway because of the previous problems I had had with the icemaker.
The last time the repairman came out I asked him if this latest part would "fix" the problem. He said it would help it but not fix it because there was a design flaw with the back/rear dispensing icemakers. I paid around $2,000 for this frig. I called Lowe's and told them of the problem and they said they would replace the refrigator for one of equal value.
Other than the problems with the icemaker I thought this was a very nice refrigator. However, I don't think I will buy another GE. If they knew there was a design flaw they shouldn't have sold these refrigators or had a recall when they became aware of it.
Nov 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Nokia 2630 locked to movistar
hi
i am afraid to tell u that ur phone unlocking is not that esay by sending u a code
the best and only solution is to give it to a phone repairman and tell him unlock my phone plz!!
then u will fix the prob
technical INFOS:
the price of unlocking 2630 is not expensive its can be unlocked by a phone box tool called JAF
best regards
Sep 24, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Refrigerators Logo
214 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
