Question about Leisure HOMEPRIDE Electric Fireplace Heater w/ Remote
I have a gas fireplace in my home. I've connected the gas tanks outside, but can't get the pilot to light. I can see the spark, but can't get it to catch. Any advise?
    Problem Solver:
  • 7 Answers
Check the pressure at the unit inside and make sure the pressure is correct,ther might be a problem between the tank and the unit only letting enough gas to run the pilot light
Posted on Oct 20, 2011
The fireplace probably has a thermocoupler. It produces current when engulfed by the pilot light flame. The small current produced (you can check for output with a votmeter) is enought to allow the gas valve to open when you turn on the switch to start the flame. The solid metal tube may not be properly connecting with the flame - repostion the pilot light and make sure surrounding air flow does not distort the pilot light pattern too much. OR the surface of the device may be slightly oxidized - very gently sand or wire brush it. Again check for small voltage output. If no volts - REPLACE THERMOCOUPLER.
Also: read this link;
Posted on Dec 23, 2008
Pilot light of gas fireplace went out. Normally the pilot light is lit, and you turn on the fireplace with a light switch on the wall. Is it safe to relight the pilot with a match ?
if the stove or fireplace doesn't have electronic ignition then yes its looking for a pilot lite I used to have a old water heater that did this , turns out the problem was defective gas regulator making the pressures go up/down also was leaking outside that's what made it noticable
Dec 07, 2016 | Heating & Cooling
Where is the thermocuple on my marco gas fireplace
Fireplace Pilot Light Tutorial - YouTube
? 5:06
Nov 12, 2012 - Uploaded by FogoFox
This video walks you through the process of turning on the gas to your fireplace, lighting ... Lighting a Gas ...
The thermocouple compared to the thermopile. - YouTube
? 6:01
Oct 16, 2013 - Uploaded by grayfurnaceman
I got an 1980 gas fireplace, I just see the pilot and something that look more ... My land lord purchased a ...
Marco Natural Gas Fireplace (Model B36CFI) won't turn on ...
? 0:16
Jul 31, 2015 - Uploaded by Roscoe Sikes
Download MARCO GAS FIREPLACE MANUAL PDF ... How to Safely Light Your Pilot on Your Gas Fireplace ...
Dec 07, 2015 | Heating & Cooling
Bought a new house that had a ProCom SSEB24RT in the fireplace. I tried lighting it this year and there's a spark but will not light. I've tried holding it in for 10 minutes to bleed t
Clean pilot generator and clean that very tiny fine hole in where that pilot light shoot out. If this don't work you that new pilot assembly kits.
Nov 24, 2014 | Procom Heating & Cooling
My Insta_Flame gas fire place will not turn off completely. We ahve turned off the gas supply now, but before it still had a tiny flame burning even when turned off.
boy that is one sad excuse for a heating guy. how foes this thing flame on? if it doesn't have an electronic spark start mechanism then it operates with a pilot light that will always be going as it uses this small flame (pilot light) to ignite the gas when the thermostat turns it on.
Nov 21, 2014 | Heating & Cooling
Gas fireplace won't light
Your fireplace does have a pilot. It is either millivolt, where you manually light the pilot and use a remote or wall switch to light the logs
or is IPI where it still has a pilot light but the reote or wall switch lights the pilot first then the logs. The second version has a non-standing pilot. In either case, it sounds like a pilot assembly issue. When you "throw the switch", do you hear clicking inside the fireplace? If so and it does not light, you may have a pilot assembly issue. If there is no sound at all, then you may have a bigger issue with the control module. The only sure way to know which is the culprit is to have a certified technician come oput and examine your fireplace.
Feb 02, 2014 | White Mountain Hearth Empire Tahoe 36...
Problem lighting gas fireplace
my fireplace lights up for a short time and goes out after 5 or 10 minutes, please help with this problem.
Dec 08, 2009 | Heating & Cooling
Help troubleshooting an FMI GL-850E Gas Fireplace
It sounds like the Ignition Control Module went out, as I've heard the vibrating noise you speak of just before the module "dies." You most likely have the gray Robertshaw control module box located under the fireplace connecting the power to the gas valve. You will need to have a Certified Gas Fireplace Specialist look into this issue and replace, if necessary.
Dec 07, 2009 | Heating & Cooling
I just bought a Lennar home in the Hanford area. It was a foreclosure. There is a Heat n Glo doublesided fireplace. No manual for operation. How do I get the thing started? There is a red gas valve on the...
i would really suggest having a gas log service company come out . 2 reasons 1st it should be maintenanced every year and 2 its a gas appliance have a qualified person explain the operation visually
Nov 28, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Marco fireplace Model 794 cant light the pilot
the valve handle is on when the handle is in line with valve body, off when crossed...are you pushing in on the pilot gas valve under unit? if not.. open bottom panel.. turn knob to pilot..push and hold down while sparking..if pilot lights continue to hold for about 60 secounds.. then release knob and turn to on! Also FYI... these units have a vent recall on them! please go to google and type in your heater, then model #
Mar 25, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Hi clean pilot light check out thermocouple might need new one
Nov 14, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
143 people viewed this question
Top Leisure Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Leisure Heating and Cooling Expert? Answer questions, earn points and help others
