Question about Panasonic Lumix DMC-FZ20 Digital Camera
FZ20 Locked up
My FZ-20 recently stopped working altogether. It did not power on at all with freshly charged battery. After a few days, it powered on when the battery is plugged in, seems to got through the booting sequence, but none of the buttons work. If I move the dial around, I am able to see the last pic on my card in review mode but cannot browse photos. MF/AF switch works and its able to sense the flash being raised. The on/off switch also does not power the unit down. I am only able to turn it off by removing the battery. Any insight or thoughts about repair. Unfortunately it is out of warranty. Thanks in advance, Jid
  • Panasonic Master
  • 5,527 Answers
It's thirteen years old - probably just worn out.
Posted on Apr 10, 2017
4 Suggested Answers
SOURCE: Buttons stopped working
If yours still zooms in all the way when you turn it on, then I had a similar problem with mine. When I turned it on, the camera would zoom out all the way and the other buttons wouldn't respond. If I switched it to review, it would just cycle through all the pictures, so I figured somewhere the zoom lever was stuck inside. I don't know a lot about cameras, so I sent it in to Panasonic (it was still under parts warranty), but was informed that due to "grit substance" my warranty was voided and it would cost $179 to repair. Since I could buy the same camera used at www.keh.com for that price I told them to send mine back and I'd take a shot at fixing it (since I was pretty sure it was a mechanical problem). Here's what I did with a $1.79 glass repair screwdriver. Remove the battery and take out all the visible screws on the outside (2 on the right, 1 on the left, 3 on the bottom). Lift the back panel at the bottom edge, and it should pivot along the top edge until you can remove the back. Then unplug the two ribbon cables (the small one has a latch on top and the larger one has a black latch on the side that you need to lift). BOTH have hinges, not just the smaller one like other posts have said. Next you need to remove the front panel. There are three silver screws placed around the lens unit (look down inside, and you'll see them attaching it to the front panel). Remove these, and you should be able to remove the front (lift at the bottom and it pivots along the top edge). Now you should be able to pop off the top cover (with the zoom, power, etc). Now if you look at the bottom, there are two screws holding the board to the cover, remove these and you've got it apart. On the top right side of the board, you'll see where the external zoom switch pushes a very small black lever. This was where the problem with mine was, the black lever was stuck over. You can use the tip of the screwdriver to pop it back to the center position. Now make sure that if you push it one way or the other that it will recenter on its own. Mine didn't, so I had to pop the small silver cover off where the lever is with the flathead tip of the screwdriver. Be careful here. The lever just sits on a peg, and has very small gears that move a slide bar. If either of these fall, you may never find them again. I took both the lever and the slider off, cleaned them, and got it so it would recenter easily again. Then I put them both back in, popped the cover on (you may have to pry out one of the sides slightly to get it back on), and the lever works fine now. I wouldn't be surprised if your camera has this same problem. If it's something else, it's still probably a problem with this mechanism that you could fix. Anyways, reattach the board to the top cover, and pop it back onto the camera. Now insert the battery, and turn it on to see how it works. Even without the screen, you can try the zoom. If it all works, then all you need to do is put it back together in the opposite order you took it apart. When reattaching the LCD ribbon cables, make sure the hinges are open, insert the cable, and snap down its latch. Hopefully that works. I don't know much about cameras, but it wasn't too hard. Just work slowly and carefully.
Posted on Aug 19, 2007
SOURCE: Panasonic DMC-TZ1 Won't turn on
I have just had this problem - was about to take it to shop for a checkover when I held shutter button down and then turned on - viola - don't know if it was a fluke or what
Posted on Jul 30, 2008
SOURCE: DMC TZ3 all buttons blocked
Jan, I have the same problem on the same camera. Did you get yours fixed?
Posted on Jul 04, 2010
Testimonial: "Hi Kitsy, EXCELLENT! This was exactly what was wrong with my camera as well. Pretty difficult to spot the little lever that was stuck though. I took some pictures and will try to post them here as well. MANY THANKS for the great tip and super description what to do! Cheers, Jan"
Have an electric LG dryer that stopped working. The internal light was out first. Checked fuse, plug, lint.
It's probably power supply related, check warranty. Should be easily diagnosed by electrician or someone who knows how to use multimeter. I would start there. Also, is the electric "clean" in the home? Surges,bad grounds in circuit will wreak havoc on electronics. Hope this helps.
Feb 23, 2015 | LG Dryers
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
No power
They only have three connectors in the camera, unfortunately, you may be looking at a repair bill or replacement, as the minimum cost to repair may be more than replacement cost. i have an FZ 15 and love it, but the newer ones do much better especially in darker settings, I also have an FZ 18, seems cheaper, but good photos, the FZ 28 I think is the current one, but a step up would be better if your wallet allows, you are used to a heck of a good camera and the replacement needs to be a good one!
Apr 24, 2010 | Panasonic Lumix DMC-FZ20 Digital Camera
Camera DMC-FZ20 fails to turn on after having a flat battery. recharged battery and used a new battery but fails to show ant life. What can I do?
Assuming that the new battery you tried was the correct type for the camera and that it was fresh/fully charged, your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your camera may have a problem that requires professional repair.
Oct 12, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
On/off
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 13, 2009 | Kodak EasyShare P850 Digital Camera
DMC FZ 20 powers on but the controls do not work.
Make sure the camera is not in play mode. look for a reset procedure or a firmware flash procedure.
Aug 16, 2009 | Panasonic Lumix DMC-FZ20 Digital Camera
2001 elantra lack of power
Confirm ur fuel pump is working. Ensure ur pickup tube is not blocked. Then ensure u did not leave a rag or parts in the manifold tubes. Not laughing it happens. Is the distributor in the right spot. Etc etc. Did u rehook the alt up if removed . Is tje battery fully charged. And lastly is the fuel flowing and freash. Then recheck your work did u replace all parts right. Any air in the head gasket will make the fuel /air mixture off.
Good luck
Jul 16, 2017 | 2001 Hyundai Elantra
Battery drains
I too have problem with camera on/off switch . Solved the problem by charging battery fully and installing only when I needed to take pix. Then removed it when not required. I found I could open battery cover and remove battery while camera was 'on' as an emergency measure, without apparent damage.
Aug 16, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Low light situation
Where the Panasonic FZ-20 does very well, is with conditions where you need a long zoom under low light. Most lenses will lose light as they are zoomed out. The Leica lens in the FZ-20 does not lose light when zoomed. No matter which camera you are using, you will have to use the manual controls for the best results. So learning about exposure and how to use it, is necessary.
Sep 04, 2005 | Panasonic Lumix DMC-FZ20 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
74 people viewed this question
Top Panasonic Cameras Experts
Computer Links
ogerfire
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
