Question about TDV Vison TDV FV19B 19" Flat Panel LCD Monitor
Screen says "out of range" after Windows 98 picture
Screen says "out of range" after Windows 98 opening picture
Apparently my 1998 Windows 98 setup (Packard Bell) has insufficient display memory for flat screen application. I'm going to see if I can increase the display memory if I can figure out how!
Posted on Dec 23, 2008
I have an IBM ThinkPad running Windows 98 Second Edition used to program older radios so it needs the older version of Windows. The display power on showing IBM Thinkpad full size, but when windows or DOS...
I've seen this before, the main problem is that the resolution is set too low, so it only fills part of the screen.
two ways to solve it.
1. Adjust the resolution to the optimal setting so it fills the entire screen.
2. Find the Picture Scaling option and have it Scale the picture to the entire screen.
To adjust the resolution, now its been a long time since I used windows 98, but I think you got to it by going to your desktop with the background, right click anywhere on the empty space and select properties, now on the window that opens it was the last page, settings I think, you should get an representation of your screen with a resolution lever and color options, pull the resolution lever one point to the right and hit apply and ok, do this until the picture fills the entire screen.
If your laptop has internet connectivity, I could take a look at it over remote support and solve the problem for you.
Oct 23, 2011 | IBM ThinkPad 380 Z (2635HGU) PC Notebook
Monitor just says out of range no matter what I do, I have switched the cords already
When a monitor is out of range it means that the computer is set up to a resolution that the monitor cannot handle
what you need to do is turn on your computer and tap F8 repeatably untill you confront a screen asking you what you want to do
you want Safe Mode with VGA
this will start windows in Safe mode (default settings for everything) and will set the resolution to 800x600 (smallest resolution supported by everything) when you are at the desktop you can just change the resolution of your screen normally
Windows Vista/7
right click the desktop > Screen resolution
Windows XP/98 etc
Right click the desktop > properties and it will be in there somewhere (don't have an XP machine in front of me sorry)
May 12, 2011 | Computers & Internet
I want to change my desktop background. .what is the easiest and safest site to go to for reat pictures?
Right click your mouse on an empty area of the desktop. A small menu will appear.
  1. Click on Properties [This will be Personalize on Windows Vista or Windows 7] to open the Display Properties screen window.
  2. 3Select the Desktop tab, if using Windows XP. Windows 98 users can select the Background tab.
  3. 4Choose a background. On the lower left half of the Display Properties Window, you will see Background (Win XP) or Wallpaper (Win 98). You can choose a background from the long menu list by clicking on the background/wallpaper design you want.
  4. 5Select a position. Stretch is generally the best choice but if the image you have selected is of a low resolution or an aspect ratio different from your monitor's, then Center or Tile will work best.
  5. 6Click OK to close the Display Properties Window.
Feb 12, 2011 | Computers & Internet
Message says that there is insuffient memory when trying to install or run Windoes 98Se on machine with 2MB Ram
FYI,
Minimum hardware requirements for Windows 98:
1. 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended).
2. 16 megabytes (MB) of memory (24 MB recommended).
3. Hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install.
4. A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install.
5. A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install.
6. One 3.5-inch high-density floppy disk drive.
7. VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
If your PC does not meet the above minimium requirements, you are bound to get errors popup installing or running software.
Hope it helps.
Oct 30, 2010 | Microsoft Windows 98 for PC
Is Windows 98 too outdated, to enable burn to a disc
Yes it is possible to burn them to a disc. Or the simplest way is get a USB flash drive and save them all there.
Oct 08, 2009 | Computers & Internet
Pendrive Problem in windows 98
you have to use xp os.because windows 98 is tatally back dated. thats why its not opening. or you can check it into another xp os. computer if it is open then your sure that windows 98 is not supporting, or if it is not open then your pendrive has some problem.
Mar 17, 2009 | Microsoft Windows 98 for PC
Help!!!
hi
first thing i ld like to tell u is that what we have to check is that the PC shuld have the basic requirements on it as Microsoft The following list describes the minimum hardware requirements for Windows 98: • A personal computer with a 486DX 66 megahertz (MHz) or faster processor (Pentium central processing unit recommended). • 16 megabytes (MB) of memory (24 MB recommended). • A typical upgrade from Windows 95 requires approximately 195 MB of free hard disk space, but the hard disk space may range from between 120 MB and 295 MB, depending on your computer configuration and the options that you choose to install. • A full install of Windows 98 on a FAT16 drive requires 225 MB of free hard disk space, but may range from between 165 MB and 355 MB, depending on your computer configuration and that options that you choose to install. • A full install of Windows 98 on a FAT32 drive requires 175 MB of free hard disk space, but may range from between 140 MB and 255 MB, depending on your computer configuration and the options that you choose to install. • One 3.5-inch high-density floppy disk drive. • VGA or higher resolution (16-bit or 24-bit color SVGA recommended).
Jun 06, 2008 | Microsoft Windows 98 for PC
Installed on Vista
Picture It 2002 is designed to be used with Microsoft Windows 98, Microsoft Windows Millennium Edition (Me), Microsoft Windows 2000, or Microsoft Windows XP, therefore I'd suggest to run your Picture It 2002 using Compatinity Mode --> Right click on the program icon--> properties-->Compatibility--> select one of the versions above
Apr 06, 2008 | Microsoft Picture It! 2002 for PC
Color drivers
Do you mean you do not see color on your monitor display right now?
If so:
1) Find out your monitor model
2) Do a search naming your monitor model (ie) dell 783s) and download the driver specifically for windows 98
3) see below for accessing Device Manager to update the monitor driver:
Microsoft Windows 95, 98, and ME users enter the Windows Device Manager by clicking Start, Settings, Control Panel, System icon, and finally clicking the Device Manager tab.
Below is a basic example of what the Microsoft Window Device Manager may look like when open. Clicking on the below image will open a more readable version of this picture.
Click Image
Dec 21, 2007 | Microsoft Windows 98 for PC
Windows 98 is not opening
You need to re-install Windows 98, and this time, you should do it on a separate hard disk partition.
Oct 31, 2007 | Computers & Internet
TDV Vison TDV FV19B 19" Flat Panel LCD Monitor Logo
163 people viewed this question
Top TDV Vison Computers & Internet Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Are you a TDV Vison Computer and Internet Expert? Answer questions, earn points and help others
