Question about Sony Playstation 3 (PS3) Console
Ps3 turns on but does not reconize disk
When I turn on my ps3 it will come on and start booting up. However because it will not reconize any of my disks, games.DVD, or Blueray, it goes right to the console menu. How do I fix this?
  • 21 Answers
That means the laser eye is dirty it needs cleaned try running a lens cleaner disk through it. that should fix your problem
Posted on Dec 22, 2008
Can i reboot my ps3 using lenux boot disk
Yes, Ofcourse.
Instructions
    • 1 Select and download a Linux distribution to download. Your options are Ubuntu, Fedora, OpenSUSE and Yellow Dog. Ubuntu and Yellow Dog have better support for PS3 than OpenSUSE and Fedora. Links are provided in the first Resource.
    • 2 Locate the boot loader included with your Linux distribution of choice and rename it to "otheros.bld" so the PS3 recognizes it. Your bootloader is either named "kboot" or "petitboot" followed by a version number.
  • Create a folder named "PS3" on the CD or Flash drive. Create another folder named "otheros" inside the "PS3" folder. These folder titles are case-sensitive--enter them exactly as they appear here.
  • 4 Save the "bootloader.bld" file in the "otheros" folder. If you are using a CD, burn it now. See the second Resource on how to burn a CD using tools included in Windows.
  • 5 Insert the Flash drive or CD into the PS3.
  • 6 Go to the "Settings" column of the PS3 main menu, select "System Settings," then "Install Other OS." The PS3 then searches for and starts installing the boot loader from the Flash drive or CD.
  • 7 From the "Settings" column again, select "System Settings," then "Default System." Choose "Other OS" from the options listed on the right.
  • 8 Burn the .iso of your Linux distribution of choice to a CD, if you want to boot the PS3 from a CD. If you're using a Flash drive, see the third Resource on how to put a running Linux installation on a Flash drive.
  • 9 Remove any disc already in the PS3 and turn it off.
  • 10 Insert the CD or Flash drive. The Flash drive goes into one of the PS3's USB ports, located on the front face, in the bottom right-hand corner. If you insert a CD, the PS3 automatically turns on.
  • 11 Turn on the PS3, if it hasn't turned itself on already. Select your Linux distribution from the boot loader menu to boot the PS3 from the Flash drive or CD.
  • Jun 05, 2013 | Computers & Internet
    Hi every time i turn on my ps3 ican not play anything all that comes on is the playstore sign comes up .it dosent seem to reconize the disk plesae help
    I think there is something that turned off inside your console This happened to my PS2 too. You have to find a repairer know how to check the problem.
    Oct 30, 2010 | Sony Playstation 3 (PS3) Console
    Auto start not working it is turned on and whats new is shut off what else can i do
    to be honest i cant understand what is the problem exactly, but lsn if u r talking about the Disk auto start, then u have to know that it has to do with the latest updates, so if u want your PS3 to auto start your Disk u have to turn it on and wait until it loads and see the PS3 menu after that insert your Disk and it will auto play it, but if u inserted your Disk as soon as you turned your PS3 on IT WILL NOT auto start it. u have to wait man until you see the menu, ok
    Feb 18, 2010 | Sony Playstation 3 (PS3) Console
    PS3 hard disk is corrupted and will be restored but does not restore
    ps3 will turn off while booting up , unable to restore system .
    Jan 01, 2010 | Sony Playstation 3 (PS3) Console
    My PS3 doesn't read disks that i insert!
    It needs a new laser because the old one is "burnt out". It's a really common problem with them.
    You could replace the laser or the entire Bluray drive.
    I buy my parts at http://parts.consolerepairguy.com - the laser are about $75 each and Bluray drives are about $95.
    In your caseme, best bet might be to get the whole drive.
    I run a repair business and that place has best prices aside from Hong Kong which I don't trust.
    Oct 31, 2009 | Sony Playstation 3 (PS3) Console
    Any time i turn on my ps3 it will turn off
    HI If the light turns yellow then red, this is a overheating issue. let it stand for an hour unplugged to cool.
    Now, if the green light doesn't turn yellow before red, this will confirm that the HD(Hard disk), is experiencing some difficulties with the booting process. This will occur if the internal connections are damaged, due to a solder break. In this case, you will need to send the unit to Sony for a repair. Try removing the HD from the unit. after the unit HD is removed for a minute and re-installed, try to power up and initiate a boot. if the unit continues to not boot and flashes the red light after the HD is pulled, this will confirm that the HD is the culprit.
    Contact Sony for a repair ticket if the problems persist.
    Oct 03, 2009 | Sony Playstation 3 (PS3) Console
    PS3 freezes when booted up
    This sounds like your hard drive might be bad. Try pulling the hard drive out of your PS3 then turn it on and see if it will turn on. If the system turns on then i would say your hard drive definitely needs to be replaced.
    May 17, 2009 | Sony PlayStation 3 40GB System
    Dell Dimension 4600 will not reconize cd or dvd drive
    1. ensure the drives are jumpered Cable select.
    2. Boot to the BIOS, turn on Caps Lock, Scroll Lock, Numlock. Then press ALT+E (You should hear one beep) then ALT+F (You should hear one beep) if you have no floppy disk drive, turn off the Floppy Drive and the diskette controller the ALT+B to save and reboot.
    Mar 01, 2009 | Dell Dimension 4600 PC Desktop
    Primary master hard disk error
    i also need help
    my motherboard cannot detect also my SATA harddisk
    my Mother board is K8V-X but in boot options i see my harddisk
    but in main menu no SATA..
    so thats why i cannot reboot or reformat my pc
    May 29, 2008 | ASUS K8V-MX Motherboard
    Sony Playstation 3 (PS3) Console Logo
    70 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    shaun taylor
    juanmireles1
    David
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
