Question about Asko D1976 Built-in Dishwasher
F2 error message flashes, cannot reset.
Asko D1976 Dishwasher. Error message F2 and all the lights on panel flashe non stop. There was a lot of watery noise. I opened it up and there was too much water. I tried to hold down the "start' button to turn it off (this usually works) but this made it drain the water leaving only enought to swirl in the centre drain. I had to disconnect it from power. Pulled it out to look in the back. Saw that the drain pump, electrical connection and inlet valve sat above a 1/2 inch of water that had pooled on the metal plate below. I sopped this water up with a large sponge. Whats the verdict? Can this be fixed?
  • Anonymous Jun 09, 2008
    We cleaned the water drain as there was a lot of grease in it. There is no water in the pump but it sounds like it is still trying to pump out water. When the door is closed the dishawsher continues to make this noise and the F2 light symbol is still on. We tried to reset the dishwasher to no avail.
  • Anonymous Mar 14, 2014
    I have soaked up the water remaining in the base of the unit F2 disappeared but then came back after the machine drained again
  • 88 Answers
Hi how are you...asko has a safety overflow protection switch...were the electrical comes in bend down it....theres a float an micro switch...push up in down on it...soak up water in bottom first...float might be bent up ...use long screw driver...turn power off first...hope this helps...had problem on 3/27.2010.. sincerely michael doctor airr appl.repair..843-384-8474...call if need more assistance...its free..good luck....
Posted on Mar 27, 2010
  • 641 Answers
Try to find out from where water leaking from (pump or inlet valve). The leaking one, should be replaced. Good luck !
Posted on Jul 27, 2007
Hi I had f2 flash up on the control panel so we drained it and turned it back on it now shows 5 on the control panel and wont do anything else it is a ASKO D1976
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be there when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now. Hope it helps...
Daniel
Jun 08, 2011 | Asko D1976 Built-in Dishwasher
ASKO D1976 model. We have a F2 error message. Water has now been drained but we are unable to remove error code or have dishwasher return to normal cycle
Display shows an error code. Do the following:
1. Unplug washer or disconnect power for one minute.
2. Plug in washer or reconnect power.
3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
May 27, 2011 | Dishwashers
My Asko Dishwasher D1976 on the main panel all of the top lights are on and in the display window it flashes F2. The motor is on but nothing else is happening can you help. I have checked that drains are...
Hi
Error F2 in asko dishwashers indicate high water level. This may happen due to plugged drain pump or due to faulty water inlet valve. To resolve the issue remove the back plate and check the drain pump. Disconnect the hoses from the drain pump and clear the lint from the hose and the pump area. Lot of water would be ther when you'll remove the hose from the pump, be ready to collect it. Let it dry and now the dishwasher will work perfectly now.
Hope it helps...
Daniel
Apr 22, 2011 | Asko D1976CSTM Built-in Dishwasher
My asko dishwasher flashing F2. Can't stop it! What do I do! Thanks, Elva
Hi
Hope it helps...
Feb 16, 2011 | Dishwashers
Dishwasher will not start error message F3
Refer user manual. Contact service provider for assistance.
May 26, 2010 | Asko D1976 Built-in Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
ASKO Dishwasher F2 light flashing
Hold the Rinse button for 5 seconds to reset.
Jan 19, 2009 | Asko D1776 Built-in Dishwasher
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
F2 Error Message on my Asko D1776
F2 error message means that you have a high water level problem that could be caused: - A plugged or bed water pump - A defective water inlet valve (stay open) Good luck !
May 21, 2007 | Asko D1776 Stainless Steel Built-in...
Asko D1976 Built-in Dishwasher Logo
586 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
