Question about Lexmark X1270 All-In-One InkJet Printer
Unable to send fax to certain number help please lexmark x5650
Can you please help unable to send fax to certain numbers
  • hmclellan Dec 23, 2008
    my lexmark x5650 will not allow me to send faxs to certain number aby help would be great
  • 21 Answers
Is it a 800 number?
Posted on Dec 22, 2008
Lexmark X5650 Fax Machine manual
Please visit the Lexmark website at http://bit.ly/ctQOTZ for the Lexmark X5650 Fax Guide.
I hope this information has been helpful.
Dec 19, 2011 | Lexmark Office Equipment & Supplies
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
I have a lexmark x5650 printer and I can send a fax but I cannot recieve a fax. Can you please help me?
Ensure that the telephone/fax line is plugged into the Line port on the back of Lexmark printer and not in the Phone port.
Jul 26, 2011 | Lexmark X5650 All-in-One InkJet Printer
I am trying to send a fax using my lexmark x5650; I continue to receive a message that reads 'phone line is in use'. The phone line is currently not in use. Any help or suggestions will be...
try contacting your telephone service provider asking is your line is allowed to fax .becoz some service providers block the fax line if it hasn't been using the fax for a long period of time.
May 19, 2011 | Lexmark X5650 All-in-One InkJet Printer
How do you load a lexmark X5650 all in one printer, copy, photo, scan, and fax? I am trying to figure out how to load the fax to send the fax to someone.
Sending a fax using the printer control panel:
  1. Make sure the printer is on and is connected to a working phone line.
  2. Load an original document faceup into the Automatic Document Feeder (ADF) or facedown on the
    scanner glass.
  3. From the printer control panel, press the Fax button.
  4. Enter a fax number, or press Address Book to select a number from the Speed Dial or Group Dial list.
  5. Press Color or Black to select a color or black-and-white fax.
  6. Press Start to send the fax job.
Source: Lexmark 5600-6600 Series Fax Guide
May 06, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
I have a Lexmark x5650 all in one unit. I can send fax but not receive fax. What do I need to do
Make sure the correct phone line is connected to the printer and the correct fax number is set in the printer. This article in the Lexmark website will help you identify and resolve your fax problem: Fax Troubleshooting Topics
Apr 16, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
How do I change baud rate on Lexmark X5650 in
Just to set your expectation, MagicJack phone service may work but Lexmark does not recommend the printer to be connected to a digital phone signal (e.g. MagicJack, Vonage, etc.) since there are lots of jitter and packet loss in the transmission signal resulting to fax failures. The Lexmark fax machine will have its optimum performance when connected to an analog signal(regular telephone line). But here's how to configure the printer's baud rate. From the Control Panel, press Settings(wrench icon)> Fax Setup, hit Ok > Dialing and Sending, hit Ok > Max Send Speed, hit Ok > set down the speed to 9600 bps. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
May 06, 2010 | Lexmark X5650 All-in-One InkJet Printer
I can send a fax but, I an not receive one
Please follow the steps given below to reset the printer:
1. From the printer control panel, press "Set UP."
2. Press the arrow buttons until "Defaults" appears, and then press OK .
3.Press the arrow buttons until "Set Defaults" appears, and then press OK .
4. Press the arrow buttons until "Use Factory" appears, and then press OK .
5. Press the arrow buttons to select a "language", and then press OK .
6 Press the arrow buttons to select a country or region, and then press OK .
7 Use the keypad to enter the month, day, and year, and then press OK .
8 Enter the time, and then press OK
9 Enter a fax number and fax name, and then press Ok .
Initial Setup Complete appears on the display.
Good Luck........
May 29, 2009 | Lexmark X5650 All-in-One InkJet Printer
Problems sending and receiving faxes.
  1. Open Lexmak Productiviti studio - 5600 - 6000 Series ( icon on Desktop)
  2. Open Setup and manage faxes link ( left bottom corner)
  3. On Ringing and Answering card look at the Manual Answer Code ( if some nuber inside delete it, it should be blank)
  4. On Dialing and sending card look at the Dial method (if you have a tone phone select Touch - tone, and if you have pulse phone select Pulse)
The diference betwen Touche Tone and Pulse is that Tone when you press nuber hear tone (like on cell phone), and Pulse when you dial nuber hear serie of short pulses (like when you dial nuber 5 you hear 5 short pulses like tttttt)
Mar 24, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X1270 All-In-One InkJet Printer Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
