Battery disconnected now requires security code to enable radio to work
SOURCE: ford courier 4x4 ute starting problem
If I understand you right, the problem is at certain times
the engine will not crank, that is turn over when you turn they
ignition key to START. And at times it will start and run normally.
Might it be that the issue is with the starter system. The
starter system is initiated at the ignition switch when the key is
turned to start. At this point, the ignition switch then provides
+12VDC to a starter relay. The relay is but a remote switch with
slightly higher amperage capacity. The starter relay then engages and
supplies +12VDC to the staring solenoid. The starting solenoid then
performs two (2) functions. It provides the switching action (hundreds
amps) from the battery heavy cable to the actual starter motor. The
solenoid likewise pushes a small pinion gear along the shaft of the
starter motor to engage the ring gear. The ring gear is of course on
the edge of the flywheel which in turn is attached to the crankshaft.
Starter system problems could be corrected by:
1. check battery, battery cables and connections;
2. charge the battery if required;
3. clean brushes and guides of brush holders of the starter motor;
4. clean the commutator and commutator segments;
5. check/replace the armature or field coils if determined to be defective;
6. in some extreme cases it could be the drive pinion or the flywheel gear ring is defective.
7. often it is the big switch that the solenoid activates that looses contacts causing no +12V internally to the motor.
8.
Most likely would be a defective starter relay or the IGN switch
itself. Relative to this, you might try and check the
connectors/terminals and electrical joints.
In the picture below, the upper portion is the starter solenoid while the one below it is the actual starter.
Given the amount of work to overhaul a starter, you might consider just replacing it.
This of course assuming that all other vital components of the car are working.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: I have a hyundai sonata
Once you turn on the unit, "1 CDE" will appear on the LCD. Then using preset button 1~4 enter the 4 digit security number supplied on security card. After confirming the number, press preset button 5. This should unlock the player. If the incorrect code is entered "2 CDE" will appear on LCD and if incorrect code is entered again, "3 CDE" will appear on LCD. If, after the third attempt, the code is incorrect, the set will turn off. Wait 1 hour before re entering a security code.
SOURCE: radio reset code for 1998 a4 audi
I had the exact same problem on my 1998 Audi A4 Quattro Sedan I just purchased. I read a couple of other posts that said to try looking for the radio code in the spare tire compartment in the trunk. Sure enough on the right hand side of the compartment was a information label and on it someone had written the code 1174 in pen. I then left the key in the ignition and the radio on for an hour. Then I pushed the DX and FM1/2 button and the same time until the "1000" number appeared on the display. Then I pushed in the code 1174 using the 1 - 4 tuner buttons. For example the number 1 key I pushed until the number 1 appeared. Then pushed button number 2 until the number 1 appeared, pushed button 3 until the number 7 appeared and button 4 until number 4 appeared. After I had the code 1174 on the display, you again push the DX and FM1/2 button at the same time and the radio unlocked and worked perfectly. I hope that this helps. I have the Delta (Bose) AM/FM Cassette radio in my car. Good Luck!!
SOURCE: code for a Ford Mondeo 6000cd radio
Hi Geof
Your radio code number should read: 5796.
I trust this will do the job.
I have no other code for your model.
Please let me know if this works.
Bye Ray
Testimonial: "Fantastic!"
