Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire Front loader won't pump out water
It does everything in the cycle except pump out the water. What's my most likely cause and/or where should I start looking?
  • bbuckta Dec 23, 2008
    2 quarters were in the pump. The pump was also leaking. It will be replaced ASAP. Thanks Much!
  • 61 Answers
If the machine doesn't drain the place to look is the drain pump. there is probably coins or some other blockage in the pump (very common). If this unit doesen't drain it will not spin. The pump is difficult to get to if there is no front access panel call local authorized tech to solve problem. good luck
Posted on Dec 23, 2008
My front loader will not spin but runs on every other cycle
I had the same problem. Check the filter, I have a GE front loader and it is located behind the front panel under the door.
Removed the baby's socks and haven't had any more issues.
Jun 23, 2012 | Frigidaire ATF6000ES Front Load Washer
I have a mo# FTF2140ES0 front loader washer that won't spin
check the pump for a blockage,if the water cantget out of the wash tub,the machine senses this and wont spin out the load,also make sure to check both sides of the pump from the tub to pump and pump to house drain sides
Mar 12, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire front loader washing machine won't spin...
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Jan 18, 2009 | Frigidaire GLTF530DS Front Load Washer
Issue with front loader going through spin cycle
you can try removing the lower acess panel(2 screws along the bottom of front) behind the panel youll see the pump assy mounted to the right, disconnect the hoses and check for debris in the hose assy. the machine will not spin if it cant get rid of water, and it cant get rid of water with a clogged hose. very commom.UNPLUG UNIT FIRST PUMP WIRES ALWAYS LIVE!!!!!!!
Nov 03, 2008 | Frigidaire ATF6000ES Front Load Washer
just had my frigidaire fronter loader repaired,,try the door switch ...mines wouldnt spin clothes were soaked did everything else fine... what may have happen is when the spin cycle is ready to do its part it double checks to see if door is locked but with a bad switch it sends the wrong signal and computer this the door is open so it shuts off....well gl mines is running got lots of laundry to do,.,,,hope this helps
May 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer doesn't drain
yes remove bottom panel but you need to remove all the water possible first you need to take the big hose off the water pump clean out hte pump and the trap in that hose should drain then if your pump not bad
Mar 19, 2008 | Frigidaire GSTF1670A Front Load Washer
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Dec 13, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
FRIGIDAIRE FWX435RHS - FINAL SPIN PROBLEM...............
Most likely cause is partial blockage in the pump or filter. refer to your manual for access to your pump filter..most manual's show you how to do this and is not a difficult procedure. Good idea to do this on a semi regular basis as front loaders do build up with lint in this area
Dec 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
87 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
