Question about LG RU52SZ30 52" Television
My tv shuts off after about amionute
My TV shuts off after about a minute. I have attempted to cheange the battery backup in the event it was the power supply. I also tried atthing an extension cord and used another outlet across the house. It's not the picture tube, since it wroks for a min, and the sound shuts off too. It's aldo not a fuse since it goes on for a min. At least to my knowledge it's not the above issues.... Any ideas?
  • 4 more comments
  • fpeipman Nov 05, 2007
    My LG RU52SZ30 shuts off randomly too. After between 2 to 15 minutes it just switches off. I can turn it on again but none of the solutions mentioned so far have worked.
  • Anonymous Dec 23, 2007
    TV shuts off.
  • Anonymous Mar 13, 2008
    mine has started shutting off right away too...its 5 yrs old and never done this. has anyone had it repaired? what was the issue?
  • Anonymous Sep 15, 2008
    Hi I have the same problem.
    Did you have any luck in fixing this?
    If so what was the problem?
  • Anonymous Nov 24, 2008
    insignis.. shuts off.. i cant even get it to turn on for a second now.. im going to body slam it in a dumpster.. thats how ill fix my problem..
  • mbcook Nov 28, 2008
    Mine lasts about a minute and shuts off. I was going to change the power supply out but not sure. Anyone ever find a fix?
  • 203 Answers
Could be a temp issue or bad cooling fan.
Posted on Jun 08, 2007
There's no event information on my tv.i already fixed the aerial connection
Possible it just needs reset.If its new tv try turning everything off for 5 minutes and then turn everthing back on. DO you have freeview built into tv try this first.
Feb 02, 2013 | Televison & Video
Samsung 55" LED UN55D6003 Intermittently turns off and on...T/S help
DO NOT ATTEMPT ANY REPAIRS, CALL THE FACTORY PHONE NUMBER IN THE OWNERS MANUAL AND FIND OUT WHERE TO HAVE THE TV SERVICED, IF YOU ATTEMPT ANY REPAIRS THEY WILL VOID THE FACTORY WARRANTY. THIS IS CAUSED BY AN ELECTRICAL FAULT INSIDE THE TV, IT SHUTS DOWN AS A SAFETY FEATURE TO AVOID ANY FURTHER DAMAGE.
Dec 06, 2011 | Samsung UN Televison & Video
I have an APC XS 1500 UPS. We recently had a power outage and now the display states "event 9" and the unit beeps every 15 minutes or so.
This "Event 9" means that the UPS has has 9 events. It could be going on battery or a high input or output. Either way we can reset it. You will have to turn on the UPS. Unplug it from the wall and also unplug the battery. When all is unpluged push and hold the power button for a few seconds. This is the reset. once done hookup the batteries and plug in the ups. All should be better. Event 9 will be gone. Till next time..... When it will say "Event 10"
Sep 11, 2011 | APC TM) Back-UPS XS Series Battery Backup,...
Mitsubishi 52'' TV Model WD52525
U restart the tv,u hear alots of clicking?That mean the Ballast is dead or have problems,that why ur picture lamp not sustaning the picture.Replacing the Ballast might or will sustance the picture.
May 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My tv cable box and radio are connected to my cyberpower 485. quite often it shuts off my cable box and tv and beeps, the radio does not shut off. This time when I pressed the siver button it tries to...
It sounds like it's either at the age where the batteries need to be replaced or there is a problem with a component 'Capacitor or transistor' on it.
Is it still under warranty. If not - if you pull the batteries out of it you may be able to find some replacement ones on line. Place the part # of the battery in a search engine.
A Good place to try is CyberPower's website also.
Blessings,
A/V Guy
Nov 19, 2009 | CyberPower 485VA UPS Backup (BE485) UPS...
My Powercom UPS battery backup is lasting for 5 minutes than it is shutting down.Can you provide me the solution. Model No. is 2200APRM1320W It is very urgent, please.
The UPS can temporarily provide power to IT hardware in the event of a disruption to the Mains power supply. The UPS should stay powered up for long enough to enable the hardware it is protecting to be powered down in a controlled manner, before shutting off itself. The 5 minute period seems reasonable for such a task (although significantly less than the rated time), and if at any point within that period the Mains power supply comes back online, the hardware could continue to work.
I note that this particular model is supposed to provide battery power for 85 - 95 minutes. The amount of time it can supply regulated voltage for will depend upon the load placed upon it. The greater the load (in terms of current drawing devices), the shorter the amount of time that the UPS will be able to provide power.
There may be a Manufacturer Limited Warranty period (parts): 2 years for this model, although labour charges will probably be made.
Jun 08, 2009 | Computers & Internet
Visio television after being on for awhile gets hot and shuts off
Hello emt_05288,
This denote a thermal problem in your set, perhaps even a high current event caused by a short circuit on one of the circuit boards. Whether or not it is a major or minor problem can only be best determine by troubleshooting the TV to find out what happens during the shutdown event. I would suggest that if you have a background in electronics, you get a schematic of the Tv and through testing the voltage levels during the shutdown event try to determine the board causing the problem, and then find the component that if cuasing the problem. If you do not have a background in electronics I would suggest that you get a TV repair technician to find the cause of the high current event.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Feb 25, 2009 | Vizio L32 32 in. LCD HDTV
RCA D52W20 52" TV SHUTS DOWN AFTER A FEW MINUTES
this is the filment circuit having a problem. i think you will find it is a loose connection on a solder joint. Goodluck
Jan 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Insignia FLAT screen LCD tv
It's more than likely over-heating. You can try a Battery BackUp with AVR (Automatic Voltage Regulation) built-in to see if possibly your electricity isn't coming in as cleanly as it should. If that doesn't do anything different for you then you'll have to take it to either a repair shop or back to Best Buy (if it's still under warranty).
Jan 03, 2008 | Insignia LCDTV26 26 in. Television
Tv shuts off
This shutting on and off~On Durabrand TV`S. If your Tv Turns Off after about 1-11/2 minutes after turning it on then you need to replace your batteries in your remote control with BRAND NEW BATTERIES or it will keep doing it. It is a real pain in the behind especially if you dont have brand new batteries handy!
Dec 06, 2007 | Durabrand DWT1905 TV
LG RU52SZ30 52" Television Logo
128 people viewed this question
Steve Allison
Steve Allison
