Question about IBM ThinkPad T42 Notebook
I have just bought a recon ibm t42 and I cant get the wireless broadband to work. The antenna LED is not illuminating at all. Also when I plug it in to my router I don't get a connection and so have no way of connecting to the internet at all. (This mail sent by another PC!)
    Problem Solver:
  • 12 Answers
It is probably broke. I suggest to get a new one.
Posted on Dec 22, 2008
Does my thinkpad 42 have a wireless switch? We cant find any networks in range but time warner says my routers good and system properties are good
Hi
IBM ThinkPad T42 is a Series number rather than a Model number.
There are various models in this series. Some models have Wifi capability. Others don't.
Look underneth your notebook to see the full model number, then check here for the exact specifications for your specific model:
http://www.thinkwiki.org/wiki/Category:T42
I hope this helps.
Aug 25, 2011 | IBM ThinkPad T42 Notebook
I can not get my wireless connection to work on my t42. wireless diagnostics is telling me wireless disabiled
There is a small switch on most laptops that enables the wiresless card. Make sure this switch is in the on position....there is usually a yellow led that comes on when it's in the on position. You might also look around in Networks Connections if that doesn't work, and see what's going on there. Hope this helps!
Mar 17, 2010 | IBM ThinkPad T42 Notebook
Where is the wireless switch located on the IBM thinkpad T42
Unlike the newer laptops, the T42 doesn't have it's own wireless switch. So in order to get the wireless working, you need to also make sure that the Power Management driver and the Hotkey driver are installed as well.
Load the drivers in this order:
1) Power Management driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4GXPEG
2) Hotkey driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-68000
3) Wireless Driver - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-70504
After downloading it, you must go into C>Drivers>Win>Wlanint and run the setup file from there.
4) Access Connections (Optional) - http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4ZLNJB
Dec 16, 2009 | IBM ThinkPad T42 Notebook
IBM Thinkpad T42. About 1hr ago went black-dead. When the power supply is plugged in there is no icon illuminated. No power reaching anything. Recently have had some fan-error warnings and have been...
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Dec 02, 2009 | IBM ThinkPad T42 Notebook
Where is the wireless switch for ibm t42 laptop i have tried fn and f5 nothing works
There will either be a switch on the side of the machine or it will be fn and one of the funtion keys, look for an image like this:
http://hpshopping.speedera.net/www.shopping.hp.com/shopping/images/overview/wireless_black.jpg
Nov 26, 2009 | IBM ThinkPad T42 Notebook
My wireless connection keeps disconnecting and then keep acquiring for network address but never connecting. My other laptop works well with my wireless router. I could reconnect to wireless by plugging in...
You may need to update your Wireless drivers:
Nov 03, 2009 | IBM ThinkPad T42 Notebook
IBM thinkpad T42 internet works with ethernet cable but not wirelessly.I checked the device manager and downloaded the latest driver but still doesn't work. Could the internet card be out of date?
It seems eaither your wireless card has gone bad or it need to be reseated. Its quite easy to take out the wireless card and install it back. Try it and if this does not work you need to ask IBM to send you a new Wireless card if its under warranty or buy a new external wireless card.
Regards,
Jamil
Oct 03, 2009 | IBM ThinkPad T42 Notebook
I keep losing my connection - IBM Thinkpad t42
Are you using IBM SW or Windows to manage the wireless? Occassionally, the IBM SW has issues with certain model routers and encyrption types.
You can also try unchecking the "Allow Computer to turn this device off to save power" in the adapter properties and
Adjusting the power on the wireless device to the max. By default IBM sets it in the middle to conserve power.
Mar 03, 2009 | IBM ThinkPad T42 Notebook
IBM T42 LAPTOP
If there is an icon in the taskbar refereing to your wireless connection, right click it then properties, then connect. You can also get to it through control panel> internet conenctions and then click on your wireless connection and click enable.
Feb 07, 2007 | IBM ThinkPad T42 Notebook
IBM ThinkPad T42 Notebook Logo
80 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
