Question about Remington Smooth and Silky WDF-3500 Hair Trimmer
I need to replace batteries in Remington wdf 3500
I've removed 8 screws but cannot remove a plastic plate to access motor and batteries.
  • Anonymous Mar 25, 2014
    We need replacement foils and cutters for the Remington WDF 1400. Do you know where we can find these? Thanks, Bill Beebe
  • 3 Answers
Have just opened the same model -
First prise off the front and back "rubber" inserts - they should come unstuck quite easily. Then pull the bottom half of the case off the top half - it is held by 2 internal clips, one on either side of the inside black plastic casing - pull and wriggle and pull some more, and suddenly it will pop off.
Posted on Jan 31, 2009
  • Tony Woodruff Jan 31, 2009
    Correction, the top half of the case should lift off easily after the inserts are unstuck - the bottom half will yield if you twist it a bit as you pull - that will release the 2 clips holding it on.
I need to replace the battery in a Remington women's razor model wdf 1600
  • Open battery compartment
  • Note correct polarity and remove
  • Install new battery
  • Close battery compartment
  • Test operation
If the razor does not work, the replacement battery may be defective
Jul 12, 2016 | Remington Health & Beauty
Is my remington razor model wdf-3500 a wet and dry
The WDF-3500 can be used wet (with foam lather or soap) or dry when not plugged in. Turn it off when you put it under running water (when cleaning it for example). Do not have it near water when plugged into the charger.
Remington has the manuals for many of its products here: http://www.remingtonproducts.com/ConsumerService/UseCareManuals.aspx . Use the drop-down menus to get to your specific product. The direct link to the manual for the WDF-3500 in English is http://www.remingtonproducts.com/~/media/Files/Manuals/Shavers%20Womens%20Shavers/Remington%20Womens%20Shavers/English/WDF3500.ashx . (This is a PDF; you will need Adobe Reader or a similar product to view or print the manual.)
I hope this helps.
Sep 08, 2014 | Health & Beauty
Battery will not charge on remington hair trimmer hc5550.
You can, but you need some experience with soldering.
Look for the other answers here in this forum, there are some descriptions on how to open the device.
In short: you have to remove the power button (be careful not to destroy it), then slide off the middle plastic part, remove a screw, then take off the upper main plastic housing, remove another two screws and take out the inner device which holds the motor and batteries.
The old batteries can be replaced by 2 AA-size eneloops.
Aug 21, 2012 | Remington Hair Trimmer Accelerator Hc5550
Can I replace my Remington Titanium MS 5200 shaver's battery myself and where do I buy the battery?
You will find compatible batteries for model MS-5200 at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
To open the shaver body, remove one screw on the back. Also partially remove the 4 outer screws found on the metal plate under the cutters. Once these 4 screws are removed you can partially remove the top part of the shaver body (the parts with the trimmer on it). Then you will need to gently pry off the rubberized grip on the front of the shaver. This will reveal two more screws. Remove these to seperate the front and back of the shaver and access the batteries.
You will need to remove the wires from the batteries by melting the solder with a soldering iron. Solder in the new batteries and reassemble. Charge for 24 hours before use
May 16, 2011 | Remington MS-5200 Electric Shaver
How do I replace a battery on the Remington WDF-2000
You can have the battery replaced. This however needs to be done by an Authorized Service Dealer. To find your nearest dealer in the USA, use the online search function here:
http://www.remingtonproducts.com/ConsumerService/AuthorizedServiceDealers.aspx
If you are in another country, go to the top right of the screen, mouse over the Country and select your country. Look for a tab for the Authorized Service Dealer search function.
Feb 21, 2011 | Remington Smooth and Silky WDF-2000...
How do I find where the battery is located?
To open the shaver and access the batteries, you must start by gently prying off the rubberized grip on the front. Once removed, you can access and remove two screws at the bottom. Under the cutters is a metal plate/clip. Remove this clip and the front of shaver can be removed and batteries accessed,
You will find replacement batteries at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/replacement-battery-for-remington-df-ms2-some-braun-p-213.html
If this job is out of your capabilities, you might want to consider the replacement part linked below
http://shaveroutlet.com/shaver-replacement-parts/remington-ms2370-lower-unit-p-208.html
Jan 10, 2011 | Remington MS2-200 Electric Shaver
I need to know how to change the battery. Can you send a manuel.
Printed instructions for battery replacement are not provided by the manufacturer.
You will find batteries for model ES-1000 at shaveroutlet.com. See link below (you will need 2 batteries)
To open up the shaver, gently pry off the rubberized grip on the front with a small flat screwdriver or similar. This will reveal 2 screws at the bottom. Remove the screws and the flat plate under the cutters that clips on there. You can then gently pry apart the two halves.
You can then access the batteries, remove the old ones and solder the new ones in place
Oct 18, 2010 | Remington ES-1000 Electric Shaver
Replace Battery in Remington wdf 3500
It is more likely that the problem is the switch. It is poorly designed and tends to remain stuck partly in the on position, so when you try to charge it, the charger is supplying low power to the motor (not enough to run the motor) and over heats the charger. You can tell this by a dull charge light on the shaver. This can be fixed by dismantling it, cleaning the switch contacts and lubricating with an electrical contact lubricant. I just did this on my girlfriends and it's gone from dead to working perfectly. Do not use this in the shower, it is not made for this even if the manual says so.
Jun 20, 2009 | Remington Smooth and Silky WDF-3500 Hair...
Remington Smooth and Silky WDF-3500 Hair Trimmer Logo
919 people viewed this question
Top Remington Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Jerry Greenberg
Jerry Greenberg
Are you a Remington Health and Beauty Expert? Answer questions, earn points and help others
