I just installed a new HANNspree 22'' HF229H and the displays are
Stretched to wide. I can't find out how to change the aspect ratio'
  • 2 more comments
  • rbutch Dec 22, 2008
    I'm running vista. Right clicking on the desktop does not give me a properties screen. I went to control panel, device manager, monitors, but didn't see a way to make any changes.
    ginko, the monitor is a HANNspree HF229H. Thanks for your help.
    unfortunatly I don't know how to navigate thru vista well enough to find the correct place to change the settings for the video card. Can you help me?
    Thank you all very much for your help. Now things don't appear distorted and I'm happy with my new monitor. rbutch
  • 4,806 Answers
Hi there
All you have to do is right click on the desktop, select "personalization" and then "display settings" this will allow you to change the aspect ratio to whatever you want and feel comfortable with
kind regards and Merry Christmas
Posted on Dec 22, 2008
  • 3,037 Answers
Hello rbutch
You need to go into your OSD menu, the buttons should be on the side or top. I am not very familiar with this brand so if you need to know exactly what to do, please post what buttons you have since they are very similar between each other, but once you find them, it shouldn't be too hard to figure out otherwise. If for some reason, you don't have these buttons, then you need to go into your graphics card settings which can be selected by right clicking on the desktop and going to properties and then click on the settings tab to adjust. Let me know if you have any further questions.
bestdarngood
  • 19,396 Answers
I think it is setting menu, then video then ratio, tell me again the model, since I cannot see the full title.
Thanks.
    President:
  • 2,110 Answers
Hi
Your entire desktop is probably stretched left to right.
You need to adjust the resolution of your computers video card in the display properties to one that the widescreen will accept correctly.
There is a chance that your video card may not have the correct resolutions available. If this is the case then you may be stuck with this view until you change coputers or video cards.
to get to display properties based on win2k or xp
Right click in the center of your desktop, choose properties, go to settings and there you should see the resolutions available. Try different ones till you find a good one, you may have to settle for one that is close to your monitors setup if the exact one isn't available.
If using a laptop with a standard screen with the wide monitor, you may need to disable the laptop screen and use just the monitor to get the correct resolution on the monitor.
Youtube on my vizio 470i tv is off centered
CHANGING THE SCREEN ASPECT RATIO: ( From Manual )
The TV can display images in four different modes: Wide, Zoom, Panoramic, and Normal. Each mode displays the picture differently. To change the screen aspect ratio:
1. Press the MENU button on the remote.
2. Use the Arrow buttons to highlight the Wide icon. Press OK.
3. Use the Arrow buttons to highlight your desired screen mode and press OK:
• Normal preserves the content's original aspect ratio. Since the 4:3 aspect ratio is not large enough to fill the TV's screen, black bars are added to the left and right of the display image.
• Wide stretches a 4:3 aspect ratio picture to the edges of the screen. Since the picture is being stretched, the display image may appear distorted. If the program is already formatted for widescreen viewing (1.85:1 or 2.35:1), then black bars will appear on the top and bottom of the display image.
• Zoom expands images with black bars to fit the screen.
• Panoramic expands the display image to fill the screen.
images may appear wider than intended.
If you are watching widescreen (1.85:1 or 2.35:1) content, black bars will still appear on the top and bottom of the display image. This option is only available when the TV is displaying a 480i/480p source.
Apr 25, 2014 | Vizio Televison & Video
How can I get full screen image without distortion on tv viewing? I only get 4:3, zoom, full and justified. Full looks stretched horizontally with tv, looks ok with dvd.
Hello
Most of the telivision transmissions are comes at an aspect ratio of 4:3. Wide aspect ratio is 16:9. If you try to see a picture with aspect ratio 4:3 to wide 16:9, it will look like stretched. it is not the fault of the tv. Most DVD recording have the aspect ratio of 16:9 [Wide]. This aspect ratio will be displayed correctly when your tv is also set to wide mode. If you select normal mode at this condition, the picture will be displayed elongated. Ok Your Tv has no probelm.
Oct 19, 2010 | Panasonic Televison & Video
Acer 22 aspect circle, not elipse
You'll need to change your resolution to one of the below to get the correct aspect ratio for a wide-screen display.
1440 x 900
1600 x 900
1600 x 1024
1680 x 1050
You will find these settings in Control Panel / Display / Advanced. If none of the above are options you will need to obtain newer display drivers.
Please let me know if this helps or if I can be of further assistance. Thank you.
Sep 19, 2009 | Acer 22" X223w LCD Monitor
NEW WIDESCREEN TOOOOOO WIDE
Use menu button on monitor.
select menu.
select image setting
select aspect ratio
change aspect ratio to "Fit"
Jun 21, 2009 | Hannspree HW191D LCD Monitor
22'' LCD monitor aspect ratio is off.
Set resolution to the native 1680 x 1050. Then, using the buttons on the monitor, go into the monitor's menu. go down to "Image Setting", go to "HDMI Mode", then select "PC Mode". This should help everything fit on screen correctly.
Mar 17, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Feb 16, 2009 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree will not supply XP drivers
i found a driver for my dell latitude d800 on dell.com. the download is r105341.exe. monitor works perfectly now.
Dec 15, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree 22" wide monitor won't recognize hdmi to dvi cable connection
First, fire up monitor in VGA. You can then use the monitor menu to select the hdmi instead of vga. Restart andf it should work Ok.
Jul 27, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Compatible with Mac?
I have the same problem.  Did you find a solution or just return it?
Jul 21, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
