Question about Mintek MDP-1760 Portable DVD Player
Plug into Tv?
How do I plug the dvd player into the television? I know you can do this but I am not sure how and I have lost my booklet.
  • Budisattva Jan 05, 2009
    I did that, plugged it into the same RCA jacks that the regular DVD used, and still no video or sound output to TV.
  • mackey1 Feb 28, 2009
    I have the same problem... I lost the original RCA AV cable that came with the Mintek unit. I have since purchased a couple different RCA AV cables to replace the original and they do not work. You plug in the cable, both to the TV and the portable DVD then push the source button and the picture does not appear on the TV as you would expect.
  • 962 Answers
In your accessories kit that came with your DVD, you should find a cable with a red ,yellow and white RCA ends. at the other end is a 1/8 inch Tip /ring/sleeve plug. Insert the plug into the output of the DVD. Insert the yellow wire to the same color coded INPUT of your television, insert the red and white wires to the Audio input on you TV. Your DVD should be sending the signal directly to your TV. hope this helps . if it does , vote.
Posted on Dec 22, 2008
Bypassing built in dvd player for another DVD player?
Try using the AVI cord, plug it into AV(1 or 2 etc) and set the TV to that
Jan 02, 2014 | Televison & Video
Sanyo tv model ds27930 not supporting my ps3
Whatever input you are using is either damaged or the tv is on the wrong channel and I'm sure you don't have it set on the wrong channel.
1. Another method would be to connect an old VCR to the TV through the cable plug on the back of the TV.
2. Then plug your PS3 or dvd player into the VCR's rca inputs on the back.
This works but your television has to have a cable plug on the back.
Oct 16, 2013 | Televison & Video
Need to know how to hook up a Toshiba DVD player to a TV
To hook up a toshiba DVD player to a television, you need to get the prongs, that you will use to hook them up.
You have a prong with red and white tip, locate the audio out on the DVD and plug in one of the prong in it then locate the audio in on the television, then you plug the other prong in the video out of the DVD player also you plug it in the video in of the television.
That is all you need to do, then you ensure you have your television on the AV mode to enjoy the DVD player on it.
Take care and good luck
Oct 22, 2010 | Toshiba SD-2109 DVD Player
Can't figure how to hook up a dvd player to my model 1359 tv. this was given to me without booklet
if your tv has a a/v hook up you will see a set of plugs that are the same colors as the wires coming out of the dvd player just plug in the wires to the corresponding plugs, then turn your tv to either a/v mode or video mode using the input button on remote, depending on the # of devices your tv can accept it may say video 1 etc.
if you don't have the corresponding plugs on your tv you may need to visit your local electronics store to pick up a converter or see if they have a less expensive solution
hoped this helped
Dec 21, 2009 | Orion Televison & Video
TV won't work after storm
ok lets try this hit the power button on the DVD player some go into stand by mode and when power is interrupted you have to push the button manually also reset the surge protector next get a lamp that you know works and unplug the tv and plug the lamp into the socket where the TV was plugged into turn on the lamp, does it turn on? yes then something wrong with TV again may have been in stand by mode plug back in and try pushing the power switch on make sure the TV if it has a remote is on the right im put to get a picture say like a satellite or cable or DVD player. hope this helps.
May 29, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Disney Princess dvd player will NOT turn on or eject.
On front of television is the video, left and right audio plug ins. This is where you will plug the adapters from your dvd player. They are color coded for easy installation. Step2Make sure the adapter is also plugged in to back of dvd player. Step3Plug dvd player into power source and turn on. Step4On the front of television there is a tv/av button. Press this button twice or until it says video 2 in upper left hand corner of television. Step5Insert movie into dvd player and enjoy. To get your tv back to cable press tv/av button once.
Apr 20, 2008 | Disney Princess MCP DVD2050P DVD Player
Durabrand TV I can't get DVD player to work.
Hi you have obe of two options have you tried leaving the dvd plugged in then switch it off at plug leave the telly on then switch the dvd on at plug then switch dvd on usually it pick up the signal on it own if this dont work you will then need to buy an all in one remote let me know how you get on ok.
These remotes are cheap to buy and do work
Jan 04, 2008 | Televison & Video
Dvd player
If it's too old and probably doesn't support progressive scan plug it on s-video or yellow rca plug, but be sure your DVD is setted for that. If is setted for component output plug it on another tv who support and redo the settings.
Dec 30, 2007 | JVC AV-27230 27" TV
Hooking up a DVD player?
There should be 3 plugs at the back that will take a 3plug av cable.
Buy one of these cables,[red, yellow, white], plug them into the correct inputs on your tv and dvd and it should work.
You can also use an S-video cable which will give you better picture.
Or a Hdmi cable but you must have the correct plugs, these are ussualy only present on newer tv's and dvd players
before buying the last 2, make sure both your dvd and tv have these corresponding plugs.
If its an old Tv you either need an Antenna-AvCable
or a simple Antenna plug that will twist onto both the antenna plug on your tv and dvd player.
Hope this helped.
Dec 26, 2007 | Panasonic PV-M1369 13 in. Combo
Mintek MDP-1760 Portable DVD Player Logo
116 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
