Question about Akai LCT2662 Television
LCT2662 turns on, no picture
I had the power supply problem, changed out 5 caps that were visibly bad. I put it back together. Now when i turn it on the red light turns green, and there is no picture. When i try to turn it off, the light stays green and wont power down. Would it be worth replacing all the caps? Could it be something besides the power supply?
  • Anonymous Dec 26, 2008
    Hi, this is someone elses post for this problem. I have not tried it myself but I may. Hope this helps.
    My 2 LCT2662 TV's lost power within weeks of each other. The power supply had 23 defective capacitors on it. They were bulging out of the top. Quite visibly defective. I replaced them all and now they are working again.
    4- 3300uf @35V
    8- 2200uf @25V
    7- 1000uf @10V
    1- 1000uf @6.3V
    3- 100uf @25V
  • uberphokis
    uberphokis Dec 29, 2008
    I found two 100uf 450v caps that were bad. I will change these out and see what happens. thanks for the ebay suggestion.
Mine is the 5volt regutator. It works fine untill I put a load on it then it craps out. Need to know what the 5v regulator part # is.
Posted on Jan 07, 2010
    Problem Solver:
  • 21 Answers
Hi
Please go to ebay and buy your power supply board:
AKAI LCT2662 POWER SUPPLY E7801-061001
Posted on Dec 30, 2008
Akai LCT2662 won't turn on, indicator solid orange
Any luck getting this fixed?Please let me know.Thank You very much!
Tyler
Jul 13, 2010 | Akai LCT2662 Television
The power supply on my Akai LCT2662 (Flat screen TV) has gone bad
I went to Radio Shack and purchased a replacement power cord 18-gauge, 10 amp, 1250 watts for 9.00 bucks and it works fine.
Aug 19, 2009 | Akai LCT2662 Television
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Are you willing to fix a power supply for a Akai lct2662?
You may have inadvertently swapped one of the caps and didn't install it in the correct polarity... Or one or more regulators are also bad... Or there may be some more and severe damage caused by the swollen (popped) cap - especially if the cap was in the 100mf range or above...
Can't really quote something like that until I was able to see and test it. However, I will charge the same as our shop rate: $29.95 plus shipping for the estimate and based on the estimate if you choose to have it repaired I'll waive the $29.95 - shipping is repaired or not.
Bill
Jul 25, 2008 | Akai LCT2662 Television
AKAI LCT2662
Power supply most likely... It's a common problem with this particular model and we've seen quite a number of them for exactly what you're describing.
You need to replace 19 caps in the power supply 4) 3300uf/35v, 8) 2200uf/25v, 6) 1000uf/10v, 1) 1000uf/16v and you can go a little higher in the voltage of each cap for greater reliability.
It's best to have an ESR meter also and test the remaining caps as well.
Bill
Mar 18, 2008 | Akai LCT2662 Television
AKAI LCT2662
Bill
My magnavox 37mf321d 37 LCD tv
This is a bad power supply and an easy fix. Their are several electrolytic capacitors on the power supply. If one is bad it will have a bulge on the top. Mine had a bad 2200uF and a bad 1200uF capacitor. About $7 worth of parts at Radio Shack. Radio Shack had the 2200uF but it was axial leads instead of radial. (leads come out of each end instead of one end) but It will still fit. They only had a 1000uf capacitor so I combined that with a 220uF capacitor and wired them in parallel. Make sure you put them in with the correct polarity.
Mar 05, 2008 | Philips Magnavox 42MF521D/37 Television
Tv won't turn on
The problem is the electrolytic caps in the switch mode power supply. They are located on the output side of the supply board. You can tell which ones are bad by the "bulge" on the top of each cap. All need to be replaced..
May 16, 2007 | Akai LCT2662 Television
Akai LCT2662 Television Logo
242 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
