Question about Sub-Zero 561 / F
Fridge not cooling
We are in the Northeast and just recently got our power back after being out for 10 days. Our SubZero Model 561 (side by side) is not cooling properly. The freezer works just fine, which tells me that the compressor is okay. We cranked the setting up to 10 but it has been 36 hours now and the inside is barely cold...almost warm.
Any suggestions as to what i can look for?
  • Firesavage Mar 05, 2009
    Same thing. warmish inside fridge - Freezer is fine
  • 725 Answers
Two comperssor ... check the thermostate ..or make sure there is power to the compressor...
Posted on Sep 19, 2009
My sub zero model 561 refrigerator side is not working
The fridge side or the freezer side? not cooling, or just no lights? Nothing is cooling or lighting?
Sep 18, 2013 | Sub-Zero 561 / F
Sub Zero 561 Refrigerator side is not cooling." the freezer side is working perfect.."
pop the top panel and clean your condenser,this is the most common problem,other than that it could be your compressor or refrigerant leak.this model i believe is two separate systems so one will not effect the other/. good luck!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 17, 2010 | Sub-Zero 561 / F
Refergerator side back panel freezing up with ice
2 posibles problems. if the ice is only about 4 an 8 inches you have a seal system problem.(evaporator freon leak) need replace the evaporator asap. if the ice cove a big part of the back wall you have a thermostat problem. for replace the evaporator better call a tech. remember to call a subzero factory authorized company. maybe still under some warrantty> good luck LEAVE YOUR COMMENT IF IT WAS GOOD FOR YOU....... THANKS
Sep 06, 2009 | Sub-Zero 561 / F
Subzero model 532 fridge not cooling well, freezer ok
Did u check condenser on the top behind the grill? If it's clean, check unit for evaporator freon leaking. Light....Possibly bad bulbs behind that plastic light cover or light switch - one of them located on upper portion of door frame.
Aug 28, 2009 | Sub-Zero 690 Side by Side Refrigerator
Subzero model #561, freezer is warm, water leak
Check to see if the freezer fan is running. Push in the two switches at the top. The light should go out and if the freezer is powered on the fan should come on. The icemaker runs on temperature so no cold means no ice. Check for ice build up around the evaporator. Could be a defrost issue or a sealed system problem. As for the water, is it the floor of the unit or the floor of the house? Is the drippan in place or sitting on the floor? Also check the condenser fan motor. If this is all greek to you, you should probably call a factory authorized servicer.
Feb 03, 2009 | Sub-Zero 561 / F
Refrigerator not cooling
Please call Jon Larson in our Sub-Zero and Wolf customer service department at 800-222-7820. He will assist you in resolving the situation with your model 690.
Sincerely,
Diane E. White
Assistant Markeing Manager - Trade
Sub-Zero and Wolf
diane.white@subzero.com
Sep 18, 2008 | Sub-Zero 690 Side by Side Refrigerator
Our Subzero 561 ( -15 yrs. old) just started making a rattling noise. It sounds like a fan is hitting ice. It stops when we open the freezer door. When we look up in there, ice is caked on. What steps...
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Refrigerators
Subzero Model 550, freezer not working properly
Blow out the condenser with an air compressor. Make sure the evaporator coil is not frosted up, if so, the drawer may naot have been closed properly, or you may have a defrost problem, (timer, terminator, etc). Possible freon leak in the high side drain loop. Compressor may not be pumping efficiently, could have a bad condenser fan motor.
May 28, 2008 | Sub-Zero 650 / O Bottom Freezer...
Subzero 690 flashing EC and service
Rhino, this is yet another simple fix. You need to call subzero and let them know that your ref section is not cooling properly. 9 out of 10 times it will be a problem with the evaporator coil needing replacement. Sub is aware of this issue and usually picks up the tab for this repair.
Mar 26, 2008 | Sub-Zero 632 / S
Refrigerators Logo
177 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
