Question about Whirlpool LGQ8000JQ Gas Dryer
Whrilpool model# LGQ8000JQ1
My dryer heats up for just a few minutes. After that it tries to heat but will not produce a flame. I have cleaned the vent system and aslo the dryer free of lent and dust. I have also did a resistance test on the thermal fuse and it is good.
  • 1 more comment
  • MELISSA PALACIOS Dec 30, 2007
    MY GAS WENT OUT NOW I'M NOT SURE ON HOW TO GET THE HEAT BACK IT IS A WHIRLPOOL CLEAN TOUCH AN OLDER MODEL PLEASE HELP
  • anitta Jun 27, 2008
    my dryer does not heat up
  • tardaguila80 Oct 21, 2008
    When the dyer starts, it blows hot air. Then during the cycle, it blows cold air. The venting system is clean and clear. I changed the thermo fuse. Please assist. It could be the coil or themostat.
    Problem Solver:
  • 18 Answers
It might have more than 1 thermal sensor, if you can find a manuel and check. Also if you have a leak on your gas connection(flex hose, ect.)
Posted on Apr 09, 2007
What causes my gas dryer to heat and the flame goes out
Try using timed dry insted of sensor dry if runs ok you need aew sensor strips. also make sure dryer vent is clean.
Aug 10, 2014 | Whirlpool Dryers
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
Our dryer stopped heating up. We cleaned out all the vents and repleced the ignitor. Still no heat. Any suggestions?
If the ignitor is glowing then check the flame sensor for continuity if it is not glowing then check the thermal fuse. If the dryer heats up for a few minutes then doesnt after that replace the coils
Jul 15, 2011 | Dryers
My Magtag dryer model#DG612 (series 05) stopped producing heat to dry the clothes. There was a flame for approx two minutes, and then the fame went out. What can I do to fix this problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 28, 2011 | Dryers
Kenmore 110.70982990 front loading gas dryer. Everything seems to work, except the flame stays on for only 5-10 seconds, and therefore does not produce enough heat. Lights up again after a few minutes,...
Remove the exhaust vent from the rear and try a load of laundry.
If ir dries correctly,clean and or repair the connecting exhaust vent.
It may also be necessary to disassemble the dryer and clean internal ducts.
Feb 20, 2011 | Kenmore 63942 Dryer
Heat is sporadic. model DDE5900RALWH erial G246248G
Make sure lint filter is clean also frre airflow from Exhaust, if tisis ok could be thermostat or element, try basic stuff 1st...
Feb 22, 2010 | Dryers
GE Gas Dryer Model #dbvh512gfoww heat problems
Hi, It sounds like the coils on top the gas valve are bad. If the ignitor glows but shuts off before a flame, the coils need changed.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 24, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer -...
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Whrilpool gas Dryer Mod # LGR54636JQO
probably your exhaust vent is clogged, make sure every inch of it is clean. as a safety measure, if it is clogged, your dryer will not produce heat, because it will have nowhere to go
Oct 26, 2008 | Dryers
Whirlpool LGQ8000JQ Gas Dryer Logo
175 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
