Question about Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine
Saeco incanto grinder keeps tripping halfway through process
I have an Incanto classic, the grinder suddenly started playing up and would stop halfway through the grind and the warning light would flash indicating motor or grinder jam. I have replaced the motor and have checked the grinders and all seems okay but still the same problem, could it be the sensor unit under the grinder? cant think of anything else. anyone have any ideas?
  • Ernest R
    Ernest R May 11, 2010
    Have you check the chute and the solenoid that opens the door?
mirran
  • 515 Answers
SOURCE: SAECO Incanto Rondo espresso machine
I think you have to take it to a Saeco service center, they have to upgrade your power board in the machine.
Posted on Jul 22, 2008
  • 521 Answers
SOURCE: Saeco Incanto "grinder blocked"
there is nothing like sensors.but for sure there are gears which helps the grinder motor to rotate and the gears are been stucked by something so the motor is nor able to run the grinder.and this problem occurs.try cleaning that internal gears.it will solve your problem.
  1. How to remove a jammed Brew Group?
  2. How to clean out grinder on Saeco Vienna Line or Trevi?
  3. How to clean out grinder on Saeco Charisma?
  4. How to clean out grinder on Saeco Magic Line and Royal Lines?
  5. How to clean out grinder on Saeco Italia?
  • Click here to Download Saeco User Manuals
  • Click here if you need a parts diagram to order parts
  • Click here to browse our online selection of espresso machine parts
pls do rate the solution
thanks.
regards.
fixya expert team
Posted on Aug 29, 2008
SOURCE: Stuck grinder
Thanks! It does not seem to be damp. I emptied the bean box and vaccum cleaned the grinder - I did not see any beans blocking the grinder. What would the next step be?
Posted on Aug 30, 2008
  • 1089 Answers
SOURCE: how do i reset my saeco sclass incanto coffee machine
Hi
If you are talking about the descale light you must let the machine quit on its own. The lights will change. Then do the rinse by replacing the water in the tank and closing and then reopening the steam knob and again letting the machine quit on its own. Again the lights will change. Then repeat the last cycle until all the red lights go away and you only have a green blinking light. Stopping it when it is out of water will only let it continue on with the descale cycle. The pump must quit on its own.
Posted on Oct 26, 2009
SOURCE: Grinder Blocked said on screen. Any Quick fixes?
This has happened to me twice. Usually caused by a trapped bean in the grinder. Here is how I fixed it. It is easy.
Inside the plastic bean hopper is a screw located in the bottom. Remove it and lift off the hopper. Have someone help you as you turn the machine upside down to remove all the beans. Use a tooth pick or a wooden skewer to pick out any beans lodged inside the grinder housing. Once completed, return the unit to its upright position.
Look inside the hopper and locate the grinder stem which is gold colored. On top of the stem is a hex bolt. Take a hex wrench with a 7/16 hex socket, connect it to the grinder hex bolt and turn it "counter clockwise" about half way which is the same direction the grinder turns. Add some beans and see if it works. If not, turn the hex bot "clockwise" a half to a full turn. Add beans and check.
This helps move the grinder out of its "stuck" position.
Posted on Jan 19, 2010
Machine won't grind beans "says beans empty" it is not
www.naplesbestcoffee.com/saeco/Incanto-Classic.pdf
This manual above should help you. It has pictures and steps to follow.
Jun 08, 2010 | Saeco Incanto Classic Espresso Machine
Beans don't seem to go into the machine upon use
The grinding burrs need cleaning if we consider that nothing have damage them.
First and simple advice is to use the vacum cleaner and try to s**k everything from the grinder and try again the machine. If the problem is insist then you need to resasemble the grinder and clean the hole grinder with the vacum and also with a wire brush.
Good luck
Mar 22, 2010 | Saeco Incanto Classic Espresso Machine
Ave an SAECO INCANTO RONDA with milling problems.
You can turn the grinder (mill) so the plates open for a more gross coffee this will help the grinder motor to rotate more free you can use a vacume cleaner to **** all the remainig coffee inside the grinder. If still not any reaction you have to desasemble complete clean the grinding plates. If you still not have any reaction then the grinder motor burn out and need to bee replaced.
Remeber to vote for this answer.
Feb 25, 2010 | Saeco Incanto Rondo Fully Automatic Coffee...
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
My saeco incanto doesnt dispense coffee any more only water comes out of the dispenser :( please helppppp ,it was working fine an hour ago then suddenly i start getting only water instead off coffee , P.S...
Check the coffee dregs are they wet? Or are they even there?
If there are no dregs then the grinder chamber is clogged and needs to be cleared out, remove the brew unit and you can gain access to the chamber on the left. Clean the chamber.
Jun 25, 2009 | Saeco Incanto Classic Espresso Machine
Stuck grinder
make sure you not get any damp into the grinder. If you have damp in the grinder then it do not grind the beans.
/Mirran
Aug 30, 2008 | Saeco Incanto Classic Espresso Machine
Saeco Incanto Classic - Bean feed problem
First, make sure you not get any damp into your grinder.
If you get damp into the grinder then it will not grind the beans.
To check the grinder you have to loosen the three screws in the beanhopper and lift it up.
The jagged plastic in the machine you will see when the beanhopper is off, turn it anticlockwise to you can see
the claque is free, then you can take out the jagged plastic and you will see the grinding wheel, make sure the wheel and the jagged plastic is clean.
Before you mount all again, use a vacuum cleaner to clean it.
Put back the jagged plastic again and turn it clockwise to it stop, then you turn it anti clockwise 14"click".
Set the number to 8 on the beanhopper and mount it again.
Hope this will help you.
Best regards
/Mirran
Aug 29, 2008 | Saeco Incanto Classic Espresso Machine
Jul 22, 2008 | Saeco Incanto Rondo RS SBS Espresso...
Saeco Incanto
how tight is the coffee packed in the dripper, the flow rate is determine by how tight the coffee is, thats why you always see the barista press the coffee against the disk of the grinder dispenser in a coffee store
Jul 06, 2008 | Saeco Incanto Classic Espresso Machine
Saeco 00034 Incanto Sirius Super Automatic Espresso/Coffee Machine Logo
99 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
