Question about Tricity Bendix AW1400W Front Load Washer
Part from drawer compartment has come loose and I don't know where it attaches. During the wash water then comes out of the drawer compartment. The piece is about 6cm long and must funnel water. Can you help please?
  • Tricity Bendix Master
  • 3,463 Answers
The part you are referring to sounds like part of the conditioner compartment, it syphons the conditioner into the drum on the last rinse, it should fit in the smallest compartment of the soap draw.
Plz rate my solution.
Thanks.
Posted on Jan 19, 2009
A small hinged part came loose from behind soap dispensing drawer. It Looks like a flap to close the main soap channel during prewash. How and where do I put this back?
To the rear and top of the drawar there should be a mechanism to release the drawer, it will need to be depressed, pushed down....then you should be able to pull drawer out in order to check how the flap should go back
Jun 11, 2015 | Miele W4840 Front Load Washer
Water in the Softerner compartment
The softener drawer cover is designed to siphon out most of the water that runs into the drawer so, when the wash is over, the drawer should always be nearly empty. Unclip and take out the detergent drawer, unclip the softener cover and fill the softener tray with water. Clip the softener cover back on and the water should run out immediately. If it doesn't then a small blockage in any of the 3 pipes in the cover can completely stop the siphon action. Cleaning them out is generally all that's needed.
Apr 06, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
After each wash the softener drawer full of water
This is quite normal. Unlike the soap drawer, which is an open ended slot where the liquid detergent candrain out or powder be washed out, the softner compartment is a small reservoir that has a raised tube inside it. It relies on water coming into the reservoir and washing the softner upwards, beyond the level of the raised tube, where it then washes down into the machine. Because of the way that this works, it's not uncommon for the water that washed out the softner to remain, filling the reservoir afterwards. Since the softner is more dense than the water, when you refil, the water will be pushed out of the raised tube by the new softner you put in.
This said, if you are noticing more than there used to be, it is possible that there is a slight blockage in the tube. You may want to lift the cover that goes over the conditioner compartment and make sure the tube is free of any blockages or residual congealed conditioner.
Usually, there is a clip at the rear of the soap drawer. Pull the drawer out to its fullest extent, depress the clip and this will allow you to take the drawer all the way out. Then you can clean the entire drawer with ease. Some models have no clip and by putting slight downward pressure on the draw and giving a sharp tug when it is fully pulled out will allow you to remove it - Just use some common sense here, if it doesn't appear to want to come free, don't force it. Come bac here, drop a note on the thread and I will provide some more detailled help :-)
Jul 29, 2011 | Zanussi F1045W Front Load Washer
When pushing the soap dispenser drawer it does not spring open any longer. Is there a way to fix this?
Re: Soap dispenser door not opening properly...(in case you still need to know)
You might want to use a small mirror (and flashlight) to see where the the spring assembly fits. Turn the rod facing towards you with the flat side up. It attaches at the rear, top left corner, near a small opening on the back wall (shaped liked the assembly). Fits into the "grooves". Apply enough pressure and you will feel it snap into place.
Dec 31, 2010 | Electrolux EIFLW55I Washer
Fabric softener drawer filling with water
lift out the blue part of the conditioner compartment and you'll see attached a tube at the end.
clean this out completely.
also check the tube in the compartment is clear.
poke a cotton bud down it to clear it.
if you want to check to see if its worked take the drawer out(blue button at back of drawer) put the blue grid back in the dispenser and fill the compartment up under the tap ,hold the drawer level.
as it gets full you should see water start to flow out the back ,turn the tap off and if its worked the compartment will slowly empty.
these were a big problem for hotpoint and concentrated conditioners will block it regularly.
Jan 17, 2010 | Samsung Washing Machines
Fabric softener doesn't leave the dispenser
Take out the drawer and clean the compartment and pipe at the end of the drawer with hot soapy water - washing up liquid works well. Clean all around it. To show this is working OK, put it in the sink and fill up the compartment with water until it is overflowing then stop. The water should drain out of the compartment on its own.
Next, where the drawer fits in the machine clean the water exit above the drawer with a washing up brush. This can appear brown or white depending on your water type. If this is OK try running the machine. If there is still a problem, remove the drawer again and turn off the power at the mains. Use something like a paper clip to poke all the holes in the water dispenser area above the drawer. There are lots of them so some patience might be required. If you live in a hard water area it could be blocked with limescale in which case an application of a descaling mousse or spraty will assist. Once complete, make sure you rinse the drawer area, drawer and put the drawer back in and run the machine on a short cold fill wash cycle. Put some fab con in the drawer to test that the machine drains it correctly. If all is well then there will be no fab con left. If it is still there then you will need to get into the water dispensing area to see what is wrong. Occasionally the mechanism can get jammed, lose a spring or just get broken, in which case it will need replacing.
Oct 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
LG WM-2277HW Water overflowing from soap drawer (compartment)
look for port inside top area of basket where water comes in may be plugged with same junk found in pump
May 28, 2008 | LG WM-2277HW Front Load Washer
Indesit washing machine W103 softener drawer
The softener could be retained in the drawer due to a defective release or controller fault but washing machines are designed to flush the drawer with water to ensure no residue is left to congeal. It may take a service call to find out what the real problem is.
Apr 21, 2017 | Washing Machines
Dispenser issues
pull drawer out towards you, untill it comes to a stop.!push down plastic tab and pull the rest of the way out,some dispensers have to be lifted and pulled at the same time.wash it then with hot water! take apart softener compartment to clean,makeing sure small hole is free!!!close eire
Dec 15, 2007 | Frigidaire GLTF1670A Front Load Washer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Tricity Bendix AW1400W Front Load Washer Logo
32 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
