Question about Whirlpool 24 in. DU1100XTPS Built-in Dishwasher
Clean light stays on
I have tried many things and I cannot get the dishwasher to work. There isn't a troubleshooter sheets for this dishwasher. How can I repair this problem?
  • 1 more comment
  • Carlos Hamer
    Carlos Hamer Apr 11, 2007
    Yes, the clean light is flashing and the dishwasher will not operate. What can I do to fix it?
  • Carlos Hamer
    Carlos Hamer Apr 29, 2007
    Yes, the clean light is flashing.
    What do I do next?
  • Anonymous Apr 29, 2009
    Clean light stays on. - I tried the recommended fix by Guru and it worked 1st time. Brilliant !!!!!! Saved me a lot of aggravation.
    President:
  • 878 Answers
Chamer, do you have high temp wash, heated dry pads on the control panel? If so do this key dance...high temp wash..heated dry..high temp wash...heated dry. The panel should light up and go through the test mode. Im assuming the clean light is flashing. Post back, let me know..Catriver.
Posted on Apr 09, 2007
SOURCE:
"Clean" & "Heated Dry" Lights Flashing
Trcontrol panal sorryy turning off the breaker for thirty seconds if not it could be a stuck
Apr 13, 2014 | Maytag MDB7100AWB Dishwasher
Kenmore dishwasher model #665.17034401 --- Clean light blinks
The blinking clean light is an interruption in the dishwasher program that indicates a component malfunction, or it can be a result of a momentary program glitch. If a component is defective, it's usually attributed to the heating cycle or thermostat failure. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
http://www.fixya.com/support/r3575752-dishwasher_blinking_clean_light
Keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
In many cases, I found this to be a momentary glitch in operation. If the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. As all dishwashers differ in operation and features, refer to your tech sheet for the recommended troubleshooting steps.
NOTE: Some dishwashers use the Sani-Rinse/Air Dry combination, some use the Sani-Rinse/Heated Dry combination. Some use a sequence of three, others use a sequence of 5 pushes of the buttons. If the tech sheet is not located behind the lower toe panel, it should be affixed somewhere under the dishwasher. I have also found them located inside the inner door panel. Let me know if you still need assistance.
May 07, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Clean light keeps blinking
The blinking clean light is an interruption in the dishwasher program that usually indicates a component malfunction. It can also be a result of a momentary program glitch as well. If a component is defective, it's most commonly attributed to a heating cycle or thermostat failure. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
Mar 31, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Hello. I have a dishwater KUDS01FL, and today I noticed that it didn't work at all. It has had the clean light flashing all day long, and it wont work when l push start . please help me Claudia
The blinking clean light is an interruption in the dishwasher program that either indicates a component malfunction, or a program glitch. The following link explains how you may be able to clear the blinking clean light problem and possibly avoid a service call:
Now...keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
Feb 23, 2010 | Dishwashers
Flashing clean light
Feb 11, 2010 | Dishwashers
Clean button light blinks 7 times, pauses and blinks 7 times. This repeats over and over. Dishwasher will not work. Model is DU1055XTPS4
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or a simple program glitch. The light blinking 7 times can commonly attributed to a thermostat problem. However, before assuming you have a component failure, read through the following information.
The following link explains how you may be able to clear the blinking clean light problem:
I hope this helps you solve your problem.
Jan 06, 2010 | Whirlpool 24 in. DU1055XTPS Stainless...
The clean light is blinking, and the cycle won't
The blinking clean light is an interruption in the dishwasher program that either indicates a malfunction, or a simple program glitch. The following link explains how you may be able to clear the blinking clean light problem:
Jan 06, 2010 | Dishwashers
Clean light flashes and the dishwasher will do nothing
Dec 27, 2009 | Dishwashers
Whirlpool dish washer clean light stays on and it wont do anything else
This information may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now, keep in mind all dishwashers are not alike and have different panel options. If you do not have the same set up that I have mentioned, the tech sheet for your dishwasher will explain the touch pad functions. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting. Just remove the screws that hold the panel in place and remove.
I have often found this to be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of WHICH circuit is causing your problem. You will need to refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Nov 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Jul 02, 2007 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool 24 in. DU1100XTPS Built-in Dishwasher Logo
275 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
