Question about Philips 60PP9352 60" Rear Projection Television
My tv, when plugged in just keeps turning itself on and off in intervals of about 3 seconds. It doesn't give time for anything to come up on the screen at all.
As soon as I plug in my television, in about 3 seconds it will shut itself off, then about 3 seconds later turn back on and this cycle continues as long as it is plugged in. I don't have any control of the power, whether that is turning it on or off. It just starts by itself and continues until I unplug it. Nothing ever comes up on the screen because it doesn't have time and it all just started one day all of a sudden when I tried to turn off the tv.
    Top Expert:
  • Philips Master
  • 14,553 Answers
Problem is in standby power supply or microprocessor area---not the do it yourself repair and likely not economical to repair due to age and brand of set.
Posted on Sep 01, 2012
SOURCE:
I have a Samsung television that powers off almost 3 minutes to the second after I turn the t.v. on. It turns itself back on, but continues to power off around the 3 minute mark repeatedly.
The power supply in the television is faulting under a load. There is a fault with the TV after the power supply or with the power supply itself. The power supply is a 'switched mode' type and will shut down and then recover under a fault. Therefore it will continue to 'cycle' if the fault is still present. Samsungs are renowned for doing power supplies but a new board could be a costly guess if it is not the reason. Sorry, I know this probably doesn't help much, but, with all electronics they are good when they work but are a costly headache when they don't. If the set is old it is probably better to look at upgrading. Cheers
Oct 09, 2017 | Samsung Televison & Video
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
Oct 19, 2014 | Panasonic PT-50LC14 50" Rear Projection...
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony wega 55 inch tv turns on fine but after one minute tv shuts itself off and comes back on 40 seconds later by itself and this cycle continues - none of the error code lights blink
This kind of problem occurs when lamp becomes weak that means near to end of working life hours but still not dead nor broken.
Replacement of lamp in tv will solve your problem, lamp replacement procedure is easy and would be written in user manual.
Thanks.
Oct 30, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
AKAI MODEL CFT2716. AT POWER ON TV COMES
AKAI MODEL NUMBER PT50DL24 it turns on then goes off n all th screen says LAMP TEMP WHAT DOES THAT MEAN N WHAT DO I ND TO GET IT WORKING
May 10, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
My Maxent turns off when it comes back on it has dark colors.
goto maxentuse.com, open user manual and look under troubleshooter.
May 01, 2008 | Maxent MX-42EPM20 42 in. Plasma EDTV
Tv powers on and off
Sound
Sounds like your bulb is nearing the end of its life span you will be needing a new bulb soon.
Jan 14, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Receiver turns on and off in endless cycle
Its one of Three problems. The main b+ filter is defective, one of the standby power sources have a bad capacitor on the line, or theres a short in the main amp. section. Its probabvly going to cost you more then you would care to invest in a reciver thats around 5 to 6 years old. Its most likly time for you to upgrade to a suround sound dydtem with new fancy lights bells and whistles. Good Luck
Jul 29, 2006 | Onkyo TX-SV636 Receiver
Television shuts down as if thermal problem, but cool
Shorted red driver trans shorted red pic tube defective focus/screen block any or all of these stk's on convergence module check the solder joints on convergence module
Jan 06, 2006 | Panasonic PT-40LC12 40" Rear Projection...
Philips 60PP9352 60" Rear Projection Television Logo
70 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
