Question about Canon Pixma iP6600D InkJet Photo Printer
Cannon printer error pixima ip6600d, u071 error.
Says: I have more than one ink tank of the following color installed; in my case it is the yellow. I have replaced the cartridge, reseated it several times and it steal does not work. somtimes it also will come up with code u0140 cannnot recognize the ink cartridge. If I reseat the cartridge and open and close the top of the printer it will print a couple
pages
  • Donald Holder Dec 23, 2008
    getting ready throw that printer in the garbage and go with another company.
5 Suggested Answers
Corysf62
  • 188 Answers
SOURCE: RESEAT FUSER
Hi G,
99% of the time the error is the fuser. Either it is damaged, or just not locked in place, and with power off, reseating it will fix the error. Since you just replaced the fuser, I guess the question is did you do it because it was also giving this error, or because it reached EOL ( end of life ).
If it was for EOL message, I would try reinstalling it. If the "reseat fuser" error goes away, but comes back with the new fuser again, then the new fuser you purchased is defective and should be returned or exchanged.
See the information below to correctly troubleshoot your issue.
The following steps are the troubleshooting steps that should be followed for error code 010 397.
First, the definition of the failure is <IOT Fuser Failure>, and means a Fuser Error is detected.
1) With power off, reseat the fuser by physically removing it from the printer, then reinstalling it and locking it in place. Turn the power back on. ( if the error is still present, proceed to step 2 ).
2) If reseating the fuser did not resolve the problem, Replace the fuser with a known good fuser.
( if problem is not resolved, proceed to step 3)
3) Replace the LVPS ( low voltage power supply ). ( if problem not resolved, proceed to step 4 ).
4) Replace the PWBA MCU ( printed wiring board assembly - machine control unit ).
END of troubleshooting.........
In most cases, the fuser itself is the problem. If you tried to reseat or replace the fuser while power was still on, the LVPS could have been damaged just as if there were an electrical storm.
Hopefully this helped.
Posted on Oct 30, 2008
  • 3 Answers
SOURCE: Printing Cartridge error
I've seen this problem before and it turned out to be a faulty chip on the cartridge as opposed to a problem with the printer. Canon should replace the cartridge free of charge if this happens.
Posted on Nov 26, 2008
SOURCE: Reseat imaging unit notice won't go away
The Phaser 6250 has a known flaw in the design of the gear slide assembly associated with the door over the imaging unit. One of the teeth has skipped and will require a service tech to "realign Rack-V". It's an easy fix if pictures/diagrams could be posted, but I'm not recommending a novice to attempt this fix without them. "Reseat Imaging Unit" error is a common fix for Xerox printer techs familiar with the 6250.
Posted on Jul 20, 2009
  • 5 Answers
SOURCE: image unit reseat
Under the hood, between the LED rasterizers (four of them, one for each of CMY & K), there are rockers with a small but powerful magnet. When the lid is closed, the magnet will touch the top of the toner cartridge, which in turn, has a magnet on a rod that goes up and down with the rollers when the toner is churned in the cartridge. If the toner magnet is not in the position it is supposed to be (you can check it's position with a hand held magnet), the sensor will falsely interpret that no cartridge is present. You may need to replace the toner cartridge.
Or if you have more time than money, empty the toner cartridge into a clean vessel, disassemble the cartridge, fix the magnet-on-a-wire assembly, reassemble the cartridge, and replace the toner from the holding vessel. It is possible that the magnets are getting weak, so check them, both on the rocker and on the cartridge.
On the other hand, I've noticed the rocker switches get sticky in lower temperatures (I keep my 2135 in the garage). Maybe a shot of WD40 on the rocker would help, but to do that, you'll need to remove the lid. It's not too hard, there's only about 9 screws, after removing the back panel (another 4 or 5 screws), After a few more screws around the toner sensor panel (a PCB), you disconnect some quick-disconnect switches, and then you can see the rockers (the actual switches are opto-electrical components on the PCB, you might clean them with alcohol, but they are discrete packages that can't be repaired).
This is a major flaw in the Xerox 2135 (probably persists in the 7300 series as well) and the OKI 9200/9300 series upon which the 2135 is based. There's way too much that can go wrong, but the killer is that nothing except the sensor is failing. Very frustrating!
Posted on Nov 18, 2011
B200 wont go on line or connect took off cord and still wont work
Error B200 means that there's a problem concerning the Printhead in most cases... in a great 90% of the cases is not fixable but...
Please try the following to see if we can resolve your issue:
1. Open the cover of the printer.
2. Remove all ink tanks from the printer.
3. Lift up the gray locking lever on the side of the ink tank holder.
4. Gently remove the print head from the carriage unit.
5. Gently clean the printhead contacts with alcohol.
6. Place the print head back in and lock the lever down.
7. Place all of the ink tanks back in the printer.
8. Close the cover and turn the printer off.
9. Unplug the power from the printer. Leave the power unplugged for about 5-10 minutes.
10. Plug the power back in and turn the printer on.
Jan 02, 2016 | Cannon Office Equipment & Supplies
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
Jul 06, 2011 | Canon MG5250 Printer
ERR0R U071 MORE THAN 1 INK TANK OF THE FOLLOWING COLOUR IS INSTALLED. (CANNON PIXMA MP500)
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon Pixma MP500 All-In-One InkJet...
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Nov 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Check ink U071 cyan
Are you using genuine ink cartridges? If not, then perhaps there is no microchip on your ink cartridge. You can take the old chip off your used cartridge and put it on this cartridge and see if this solves your problem.
Dec 16, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Error U071
Make sure that the inks are not re-manuafactured ones with chips taken off genuine canon inks. It is possible that the wrong chips could be fitted to the wrong colours.
Dec 04, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Error U140 & U071 for Cannon pixma mp800
Thanks for checking back my printer problem. Solved the problem--purchased a new printer.My big problem now is repairs on my Mitsubishi WD 52725. I do not think I will buy a new one of those.I will purchase your help package for help with that. Please advise.
Cosie
Nov 26, 2008 | Canon Pixma MP800 All-In-One InkJet...
Nov 26, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Nov 06, 2008 | Office Equipment & Supplies
U071
Usually, it only takes on at a time. there  should only be 4 colors: Cyan, Yellow, Magenta and Black. Some printers have 8, one set is very small which is used for the printhead, but, they are still the same combo of colors. In that case is the only time you will have 2 of each color a small one for the printhead and a larger on for the actual printing.
Sep 13, 2007 | Canon PIXMA iP6700D InkJet Photo Printer
Canon Pixma iP6600D InkJet Photo Printer Logo
131 people viewed this question
old marine
old marine
