Question about Maytag PAV3240A Top Load Washer
Maytag Washer I have a Maytag washer model PAV3240AWW about 5-6 years old. Two problems: 1 - the lid got slammed against the timer knob, since then the second rince switch does not work. Does timer need replacing? 2- Bigger problem, with the setting on regular or delicate, I only get what appears to be a slow speed function on the agitator. I can hear the difference in the motor sound on different settings but no change in agitation speed. The agitator bolt under the softener cap is tight, but the agitator drifts up and down about an inch. What to look for, motor coupling, transmission problem, loose belt or worn agitator, something else? Thanks for your opinion
4 Suggested Answers
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Posted on Jul 15, 2008
  • 85 Answers
SOURCE: maytag top load performa, put
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Posted on Dec 16, 2008
  • 999 Answers
SOURCE: Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Posted on Aug 10, 2009
SOURCE: Maytag washing machine skips rinse cycle
Don't know how to solve it, but I do know that the Solution #1 is WRONG.
I have a 5 year warranty on my washer, but I hate people coming into my house. Background check or not, people are people.
Any ways, when they do fix my problem I will let you know. It's an electrical problem.
I know our electric meters are running, but all you have to do is put the washer on "SPIN" cycle, and it will spin and the water will come out. Or you can put your washer in RINSE cycle, since it did not actually rinse.
I was standing and I watched my washer fill 3/4 full with water, and the skip to "COMPLETE" all on it's own. It was suppose to fill all the way to FULL.
Thinking though, I have well water, and I have rust in my water, and I noticed that my water is pouring slower into the washer, maybe there is a clog with rust or something I'll have to clean the filter, but any ways, maybe the washers have a timer, and when it's to the time it should be complete, it skips to complete. It does take DOUBLE time for my water to go into the washer. I was standing there for several minutes.
Any ways, I hope that will help. My washer first did that a few months ago, it didn't do it again, I didn't think anything of it, then it did it again last month, and about every 2 or 3 washes, it does it. It's NOT the weight of my clothes! I wash mini loads and it does it.
Posted on Dec 13, 2009
0 characters
1 Points
The Maytag washer is 26 years old. The problem is
Sounds like the timer motor may be dead. Can you hear it ticking when it is on or can you see the gear on the timer motor shaft turning when it is running? If not then the timer should be replaced.
Jan 16, 2010 | Washing Machines
Maytag washer #A882 Washer fills, but will not agitate. Can hear timer run and after numerous tries of unplugging and slamming the lid, it agitates. My husband doesn't think it's the lid switch. Could it...
Open the lid and in the middle pull the cap off the top off the agitator.
Then remove the little plastic piece, and you should see a 1/2 nut and some little plastic teeth that when the unit is running it locks into those.
Verify by turning with your hand that they are not striped out, If they are then you will need to replace those. If its not agitating it will be more Technical to diagnose.
Also make sure the screw is tight.
Good Luck!
Nov 09, 2009 | Maytag Washing Machines
8-24-2009 5:55 P.M. I have a Maytag Performa PAV3240AWW top loading washer 2-3 years old has worked well for an active family of four until the last load of wash. It seemed to wash and rinse cycle OK when...
It sounds like the belt broke or the lid switch could be bad. Use a screw driver to manipulate the switch with the machine on. If you can tip the thing back enough to check the belt. I hope this helps.
Aug 24, 2009 | Washing Machines
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
Maytag mav6200aww washing machine doesn't rinse clothes
If you say this only happens on the Colors and Whites cycle i dont see what the lid switch or balance sensor (if your washer has one) would have to do with it. It does seem like it has something to do with the timer,,, it really sounds like maybe the (Colors & Whites) section of the timer is malfunctioning. Inside the timer, there are a series of gears and switches, and by slamming the lid, or tapping on the timer control knob,,, it could maybe help the damaged part of the gear move, temporarily "fixing" the problem
Mar 13, 2009 | Maytag MAV6200 Top Load Washer
Have maytag washing machine model no LAT5006AGE serial no 25000887yk which will not spin belt appears ok but motor is not working for the spin cycle. It washes fills drains all ok do you have a solution...
Possibly a lid switch. The washer shouldn't spin if it thinks the lid is open. Possibly a wiring issue. Check the wiring to the motor. If those check out it could be a problem with the timer. Sometimes bad contacts in a timer can be checked by turning the washer on in the spin cycle where it should be working and wiggling the timer shaft up and down and around without turning the knob. If the washer starts and stops, you've got a bad timer.
Jul 20, 2008 | Maytag Washing Machines
Timer on maytag washer
this is a good one! dependable care unit made in my home town.
insert flat blade under center plastic clip in the center if timer knob , you will find a little clip and sping here , then remove two 5/16 screws , then remove two phillips screws on control panel , you should see 4 ,2 on each side remove the inside 2 then tilt panel forward unplug timer. so easy
May 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Runs full wash cycle, but there it is still full of water and suds
Amy, there was a service flash for the lid switch on this model. The contacts inside the switch were sporatic which caused; stopping in mid cycle, wet clothes and no drain. You would have to put it in spin and have someone jiggle the wires to the lid switch to verify that this is the problem and not a timer problem. I really think it's a lid switch problem. Your part number for the new, non adjustable switch is 12001908.
Jan 14, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag PAV3240A Top Load Washer Logo
48 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Al Clark
Todd Marr
Todd Marr
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
