Question about Smeg 24 in. DWF612SS Free-standing Dishwasher
SMEG dishwasher doesn't get things clean
All sees to be well, power, water throughput and pressure, no blockages, heat - it just doesn't clean anything at all. Model dwf612ss, type 10043
SOURCE: start problem
Hi
WE give this answer in good faith that anybody who benefits from it will make a donation to COMIC RELIEF, because I've just fixed my smeg d/w which is a great relief and no joke when not working,
SO DONATE.
My dishwasher tried to start but would not ,it tried but could not, the panel showed no fault.
The fault was caused by the failure of the solinoid (electric magnet) which opens the soap dispenser mechanism, located inside the door. I used an electric light up screw drive (from £ shop) which glows when you touch the end, to test the solioid, you could also use a multi meter though not as reliable.
We replace solinoid, (Common solinoid from any appliance repair shop) but I note on ebay there is a dishwasher guy selling the complete dispenser unit with new solinoid fitted.
Hope this helps( we have just had our first wash)
Do not forget to donate
Minnie Moon (twitter)
P.S. Sorry I can not remember how to spell solinoid (electro magnet)
Posted on Feb 28, 2009
ginko
  • 19396 Answers
SOURCE: SMEG Dishwasher - Water fill level is too low
Hi, I found your problem stuck here from one year ago.
I will post my solution the same, as reference for you and more users with same problem, apologies.
Re: smeg dishwasher fails to fill with enough water to sucessfully wash. It does put some water in.. but nowhere near enough.
Before checking parts inside the machine, ensure that water is coming from the faucet at the back with regular pressure.
To start check the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is getting stuck then that is the problem.
If the water level is OK, then the responsible is usually the inlet valve, or clogged inlet lines.
From description it looks more like a faulty water level.
Posted on Apr 07, 2009
  • 109 Answers
SOURCE: smeg dishwasher does not take water. all water supply
Check the inlet hose is not kinked first.
Posted on Jun 16, 2009
  • 70 Answers
SOURCE: My Smeg dishwasher model DW1 410
More than likely water inlet valve is bad. Maybe replaceable.
Posted on Nov 04, 2009
ginko
  • 19396 Answers
SOURCE: I have an E3 error
Hi.
E3 means that there is a problem with the heating system. The problem is either heating element or thermostat. The heating element in SMEG dishwashers is usually located underneath the appliance (in some model is at one side or at the back). Access is gained removing the front inspection panel at the bottom and the right hand side panel. Check at the bottom and see if the heating element is there. Check near to the heating element and locate also the thermostat, connected in line with the heating element. If the thermostat is not at the bottom, then it is inside the door, clipped near to the dispenser.
Before replacing parts test both heating element and thermostat.
Both parts are tested reading Ohms. Set the Multimeter on Impedance (any R scale).
Remove thermostat and element from circuit and read impedance touching each part contacts with multimeter probes. If the element reads infinity of Ohms (open, same as on air), then the part must be replaced. A good element will read a value different from infinity (SMEG is usually 30/40 Ohms).
The thermostat is tested in a similar way. A good thermostat will read zero or a couple of Ohms at room and will open when water is hot. Usually is only necessary to test the thermostat at room, testing in hot water is more complex. If the thermostat is open at room temperature, replace the thermostat (at room it must read zero or a couple of Ohms). If the thermostat does not open in hot water, replace the thermostat.
If thermostat and element are OK, inspect the control board.
Regards.
Ginko.
Posted on May 03, 2011
Why is our Smeg DC146L not cleaning properly?
Check the pump. I had the same problem and found a chicken bone in the pump inlet.
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_843b43f7ebebd3f5
May 26, 2014 | Smeg Dishwashers
No power after blocked drain dishwasher
Reset it by turning power off to it or unplugging it for a minute. If it still wont work then you need to take the kick panel off and see if there is leak under the machine.
Feb 08, 2014 | Smeg Dishwashers
Maytag dishwasher MDB6160AWB "Clean" indicator
Hi
It may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 16, 2011 | Maytag Dishwasher
The dishwasher is not completing it's cycle and doesn't seem to drain at the end.
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 15, 2011 | Smeg 18 in. DWD409SS Built-in Dishwasher
My dishwasher clean light keeps flashing and wont run. it flashes 7 times and pauses then repeats. whats the issue?
This is an error code.
The error indicates that your dishwasher is failing to heat the water in an allotted time. The error can be caused by numerous issues but the first thing you want to do is reset the control board.
-To reset the control board press: high temp wash, heated dry, High temp wash, heated dry, high temp wash, heated dry, high temp wash, heated dry, high temp wash. If you don't have a "heated dry" button, use the "air dry" or "energy saver dry" button instead.
-All the lights will go solid at which point you press cancel to reset the board.
-If the control board doesn't reset, it's likely that you've just got a faulty control board and the control board will need to be ordered and replaced.
The next step in this process is to start a new cycle and see what happens. If the error code returns, then you'll want to reset the board again and check several things. The most common reasons for this error is because the water coming from your household is just too cold. The dishwasher is expecting 110 degree water to enter your dishwasher, so if your pipes are cold, the water may only come in luke warm. To correct this issue, just run your faucet next to the dishwasher until the water coming out is hot. On another note, make sure the dishwasher is washing with good water pressure. You can put a cup in the upper rack facing upwards and run a cycle to see if it will fill within 10 minutes of starting the cycle. If it doesn't fill with water then you know that the dishwasher isn't producing enough pressure which, in turn, will cause the water to not heat. You'd want to take your pump and motor assembly apart to clean inside if you had a loss of pressure.
You could also have a failed component including a faulty heater, control board, or high limit thermostat. You'd need to uninstall your dishwasher, disconnect power and lay it on it's back to check the resistance of the heater as well as the resistance of the high limit thermostat to confirm if they were bad or good. You should get tangible reading of between 5 and 30 ohms on the heater if it's good and less than one ohm on the high limit thermostat. If both of those devices check good, then replace the control board because that's the one device you cannot test.
Jul 05, 2011 | Maytag Dishwashers
Smeg integrated dishwasher continually washing - won't move to drying cycle.
you should check the heating element. if the water is not hot enough, the timer will not advance. crack open the door mid-cycle. let the water stop flying around. then open it all the way up. if you don't get a big ball of steam, you have an indication that your heating element may not be working properly. this is not too hard to check the resistance with a multimeter and then replace, if necessary. good luck
Nov 02, 2009 | Smeg STA4645U 18" Fully Integrated...
Dirty dishes
check manual,your water hardness and salt/detergent quantities can make a big difference,theres usually some switches you can adjust for salt/detergent,if not check for partial blockage in pump etc,may be not enough water comming through.
Nov 02, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
My SMEG Dishwasher is not cleaning my dishes, I put the wash on and it cleans it but when I come to take the dishes out they are still dirty
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
75osrha
Oct 12, 2009 | Smeg 24 in. DWF612WH Free-standing...
My Smeg dishwasher DWF 64 SSE won't go onto rinse or dry
Easy one first try this to see if it helps
Water pre-heating
Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Jan 29, 2008 | Smeg 24 in. DWF612WH Free-standing...
Open Questions:
Smeg DWF612SS leaking & not functioning The dishwasher seems to attempt to run program's as normal but after a few minutes when the water is supposed to start spraying around inside, there is only a humming noise and no water seems to be coming in to the machine. Also, a small leak of water is coming out of the bottom of the machine. I have removed the covers and laid the unit on its side and it would appear that water is coming out of the salt reservoir/ water softener unit. I can see no other visible problems and no evidence that the water inlet pipe is not functioning and I have ensured that the drain is working normally. What I can see is that there is a darker, coppery coloured content inside the water softener reservoir, alongside the fresh new salt I put in this week. But right at the bottom of the white salt appears some grime or grit. Up on the Side, in the water softener tank ( the complex routed flat shaped tank), there appears to be a white calcified surface on some of the channels and there is water high in the tank which appears to be blocked by the calc deposits. So I can imagine if water pressure is being pushed into this whole system and water is unable to flow, then the whole reservoir will begin to leak. Do all of these components need replacing or can I remove them and maybe wash out with some mild acid to remove the offending calc? Or am I barking up the wrong tree altogether? One concern is that if I remove these parts then I may damage other seals. Help/ advice would be very welcome, thanks.
Feb 28, 2017 | Smeg 24 in. DWF612SS Free-standing...
See all Smeg 24 in. DWF612SS Free-standing Dishwasher Questions
Smeg 24 in. DWF612SS Free-standing Dishwasher Logo
64 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
