Question about Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Vertical green line on screen
Turned on my Sony Bravia 40" this afternoon and there was a vertical green line, about 1 mm in width, running the entire length of the screen approximately 6 inches from the right side. Does this mean that something has burned out?? What is the solution. Phil Quinley Sacramento, CA
  • 3 more comments
  • Philip Quinley Apr 17, 2007
    LCD............not plasma. Problem disappeared 8 days later. PQ
  • Anonymous Dec 31, 2007
    My new Sony XBR 5 suddenly has a 6-8" vertical line on the left middle of the screen. The top and bottom of the line is a little wider and is green. The middle line is thinner and is darker.
  • mdlewis11 Jul 08, 2008
    5 or 6 inches tall green line, six inches or so from right side, 8 or nine inches up from the bottom, very thin line. 52" XBR4 LCD.
  • Anonymous Mar 11, 2009
    1 MM GREEN/BLUE DEPENDING ON YOUR EYESIGHT FROM TOP TO BOTTOM INDICATES ACCORDING TO TECHS WORKING ON OUR LCD THAT THE PANEL IS IN NEED OF REPLACEMENT. THEY ARE WORKING ON WHICH IS THE CHEAPEST - REPLACEMENT LCD OR REPLACEMENT PANEL. ALL GOOD WITH EXT WARRANTY OTHERWISE OOPS
  • Anonymous Mar 24, 2014
    first on right side then the left
  • 3 Answers
If your set is a plasma, this can be one of two problems : either there is a loose connection (one of many, many connections) between the plasma screen and the driver board, or one of the transistor devices has blown. Try GENTLY applying pressure to the opposite ends of the TV to give it a subtle "twist" (please be careful!). Sometimes moving the set to a different location will produce the same effect. If it's still under warranty, call your dealer. Vertical stripes are a common fault with plasma technology I'm afraid! :-( Next time, go for LCD!
Posted on Apr 14, 2007
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Tip
I have a 46" toshiba zf355. when i first turn on the tv i get vertical lines...
This is the basic guide that can be applied to most LCD flat panel TV.
By Bud Martin
First, try unplugging it from the outlet for about an hour to see if the TV will reset itself since the minute the TV is plugged into the wall, the power supply and processor will be running 24/7 and the EPROM can get corrupted by spikes and surges. Try using good quality surge suppressor to see if it will help if it happen often.
Look for burnt brown hot spots on the circuit boards, capacitors with leaking/bulging top or seals. Loose wires and connectors. Blown fuses.
Notes: We are dealing with high voltage that can kill you! so if you are not sure what you are doing, please have it fixed by the pro that has proper tools and safety equipment. Try to use GFI outlet and isolation transformer when work around the TV set and DO NOT DEFEAT THE GROUND PIN OF THE OUTLET/POWER CORD.
1) The power supply module (There are 4 regulated output voltages:- Standby 5vdc, switched 5vdc, 12~16vdc, and 24vdc).
The power supply converts the 120/230vac 50/60Hz into DC, then the high frequency (50~100kHz) switching circuits convert it back to AC but at high frequency which allows the power supply to use smaller and much lighter weight transformers (Ferrite core instead of heavy iron core), then this high frequency AC voltage is fed to the rectifier Diodes to get the DC output and filtered by DC filter capacitors that must have low ESR (Equivalent Series Resistance), if general purpose electrolytic caps are use, they will fail within a year or less due to high ESR.
The power supply has Standby 5vdc (5VSB, this is a MUST have before anything else will work, when this voltage is not present, there will be no any indicator light on the front panel) which is always on the minute the TV is plugged into the AC outlet, so it is on 24/7 and that is why the power supply will fail even though you may use the a TV not very often. It will see all the voltage spikes and surges 24/7.
This 5vdc is used to power the Processor and the Infrared remote receiver module which will be waiting for the command from the remote control or from the power switch, when the Power on command is received, the Processor will send the turn on signal (3.3~5vdc) to the power supply module (PSON pin) to the switch on the main 5vdc for the rest of the logic and Tuner circuits, 12~16vdc for the sound amplifiers (mostly Class D amplifier for efficiency and small size) and for the T-CON board (interface board between the LCD panel, some T-CON uses 5vdc, and the Logic board), and 24vdc for the Back lights inverter board (if there is no 24vdc then no back light).
Common failures:
Blown main AC fuse due to shorted out Diodes, transistors.
Bad capacitors leaking or bulging tops:
Shorted Diodes, transistors in the DC output side.
Testing the power supply output with dummy load:
24vdc testing: Disconnect the wires that go to the inverter board first. You can use two #1157 (using both Lo & Hi filaments by paralleling them at the base) car light bulbs connected in series so they can handle the 24vdc, this will put light load (about 70w) on the 24vdc output, the voltage out should be steady at 24vdc (+/-2v), if not, the power supply has regulation problem.
12vdc testing: disconnect the 12vdc TV load from the power supply board and attach one #1157 (using just the Hi filament), the 12vdc output should stay at 12v (+/-1v), if not, the power supply has regulation problem.
You should see the lamps go on when the TV power switch is ON and go OFF when the TV is powered OFF.
2) Main Logic board (It has Processor, Tuner, Sound Processor, Sources selector, Power amplifiers for speakers, interface port to the T-CON board for pictures).
This logic board sends out the turn on signals (3.3~5vdc) to turn on the rest of the Power supply module (Switched main 5vdc, 12~16vdc, and 24vdc), Inverter backlight ON (if no back light on command then there is no back lights),
Logic board supplies 5 or 12vdc to T-CON board B+ pin through switched transistor if T-CON board does not get the voltage from the logic board, you will get white/gray glowing screen without pictures.
Back lights Dimming (PWM) control signal.
3) Back lights Inverter board. Its job is to provide the drive voltage for the CCFL (Cold Cathode Fluorescent Lamp) to give white light for the screen.
This board is fed by the switched 24vdc (VBL) from the power supply module, it also get the Back lights on (BL on) control signal and the Dimming (Dim/PWM/) signal from the logic board. So for it to work, it needs 24vdc and the BL_ON signal.
Common failures:
Blown surface mounted fuses due to shorted transistors/ICs, Transformers.
Bad capacitors.
4) The T-CON (Timing Control or LCD controller) board (on the LCD panel assembly). It transfer the universal image signal of TTL and LVDS signal to specific TFT (Thin Film Transistor) LCD.
This is the interface board that talks to the Logic board and the LCD panel to produce pictures on the screen. White/gray glowing screen when it fails or not getting the voltage from the logic board (the 5 or 12vdc is supplied by switched transistor on the logic board). Notes: T-CON board is mounted under the metal cover shield.
Common failures:
Scrambled pictures, Lines, multiple pictures, color smears/blotches, rolling pictures after warm up.
Blown surface mounted fuse.
No pictures, very dark screen almost like there is no backlights.
5) LCD panel assembly to display pictures. The LCD pixels will block or unblock the back lights from the back of the panel to the front of the panel. This is the most expensive part of the TV, it will be more than the TV is worth.
As you can see, you must have all the above Voltages and signals for the TV to work properly. This may help you narrowing down the bad modules instead of buying the wrong module just to find out later that it did not solve the problem. Hope this will help you out.
Sound problem:
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. To get the sound repair, it can be from $150 and up, so if you can put up with using the good set of Powered PC speakers which actually give better sound than the tiny speakers inside the TV, I would keep using it that way, you may want to find out if the on screen sound setup will allow you to set the audio line out to be VARIABLE which means the sound output feeding the PC speakers can be varied using the TV remote control, then all you have to do is to set the PC volume to about half way up and set the TV volume to what ever you want.
Inverter board connector: you can also see the Fuse 4A/160V
http://i.fixya.nethttp://i.fixya.net13ca788.jpg
Power supply connector:
http://i.fixya.nethttp://i.fixya.net78e0d9a.jpg
http://i.fixya.nethttp://i.fixya.net2fc510f.jpg
T-CON board: (metal cover shielding is removed to show the bd.)
http://i.fixya.nethttp://i.fixya.net0b5367e.jpg
Inverter board:
http://i.fixya.nethttp://i.fixya.netaf0a695.jpg
Logic board:
http://i.fixya.nethttp://i.fixya.net4bd108e.jpg
T-CON board is dead, no power or blown fuse on the board, screen turns WHITE, must see it in darkened room, otherwise you may mistaken it for failed backlight.
http://i.fixya.nethttp://i.fixya.net3a91b68.jpg
Bad T-CON board after warm up, you get lines, multiple pictures, strange colors blotches, etc.
http://i.fixya.nethttp://i.fixya.netd3cf194.jpg
Bad caps (leaking/bulging tops). Make sure to replace bad cap with good cap such as PANASONIC FM or FC series , they are Low ESR (Equivalent Series Resistance) which is a must for switch mode power supply, and 105c rating. Do not use generic electrolytic caps.
http://en.wikipedia.org/wiki/Capacitor_plague
http://i.fixya.nethttp://i.fixya.netbe827ec.jpg
Bad T-CON board or power supply problem
http://i.fixya.nethttp://i.fixya.net034e1db.jpg
24vdc power supply output testing using two 12vdc car lamps in series.
http://i.fixya.nethttp://i.fixya.net4f2929c.jpg
Bad LCD panel, vertical 1~2 pixel wide lines
http://i.fixya.nethttp://i.fixya.net28e50c1.jpg
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Free service manuals: www.elektrotanya.com
on Jan 15, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv sony kdlv40xbr1 stable vertical lines, no resonse from control except power buttum, plays only through hdmi input. no other inputs working. has vertical lines covering entire screen. could this pro
The T'Con board should be checked and replaced. Before replacing it check all connections comes to it and go out from it. Re-seat all flat cables connected to it. Check this to know more about the fault to this set.
Jan 08, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
We have a 40" bravia
This sounds like a defective T-Con board. I recommend having it looked at by a professional.
Nov 15, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have vertical green lines through the entire screen
Chances are it is the LCD Panel causing the problem.
I would call Sony at 1800-222-SONY and see if they could help with repairs and also referring a Service Facility to you for assistance to be sure that the Panel is causing the problem.
I hope this helps,
Sky Assoc
Oct 25, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony Bravia KLV-40U100M-screen is distorted, overlay or various vertical lines
The resolution on this was to check the surge protector the television was plugged into. Once we unplugged and plugged into another surge protector, the screen went back to normal and the appearance was great. We believe this was due to one of the resistors within the surge protector may have become faulty.
Oct 08, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Thin vertical red line
This maybe the symptom of a bad Panel. One Vertically This line is 99% bad panel. Call your warranty provider or SONY tech support if purchased under 2 years.
Best regards
CircuitCity
Nov 25, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV Logo
1,014 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
