Question about RCA DRC290
I would like to make my samsung dvd-sr270m multiregional
I have several region 1 dvd's that i cannot play on my samsung which is region 2 and would like the code to make it multiregional.
jaffa012001
  • 376 Answers
SOURCE: CODE REGION
Turn the player on and open the disc tray. Press [CLEAR] followed by [1][3][6][9] and one of the keys [0]...[8] corresponding to the region you want to set the player for (1 for Region 1, 2 for Region 2 and so on, press 0 for Region 0 or Region Free). Turn the player off then on again for the changes to take effect.
To verify the region code, press [SETUP] followed by [1][3][7][9]. A screen will then pop up with the firmware info and the current region code setting. Using [SETUP][1][3][6][9] did not work for me.
Or
To modify the region, turn on the unit and open the disk tray. Using the remote, press [CLEAR][1][3][6][9][zone code] and cycle power on the unit (not necessary to unplug the unit, simply use the front left <POWER> button. Example: Turn on; open tray; [CLEAR] [1][3][6][9][0]; unit OFF, unit ON and you'll get a zone free DVD player.
To confirm the zone code, turn on DVD player, (unit may or may not have a disc, check that the disc tray is closed, and press [SETUP][1][3][7][9]. You'll have all the firmware information (Version xx.xx.xx.xx SUB-VER xx.xx.xx.xx;
8032 xx.xx.xx.xx; Servo xx.xx.xx.xx; RISC xx.xx.xx.xx; DSP xx.xx.xx.xx; Region Code 0) That's that final "0" that you are looking for!
Posted on Aug 07, 2008
SOURCE: Multiregion DVD region code for Samsung V6800
This is not promised to work but a known hack for your model of DVD player is...
Make sure the player is switched on, and is at the Samsung logo
screen. Also check the tray is shut and that there's no disc in the
player.
Now press the REPEAT button on the remote, followed by a five digit
code. This code is different depending on what region your player is
*currently* set to:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
So for example if you have an R2 player, press REPEAT-3-8-7-6-7.
If you've done this correctly (and your player is compatible with the
hack), you should see a number at the top left corner of the screen
corresponding to the current region.
Now, pressing any number from 1 to 6 will change to the corresponding
region. Or, press 9 for auto-region mode.
Next, press OPEN/CLOSE to open the tray, followed by Standby (or DVD
POWER) on the remote to close it and put the player into Standby mode.
The next time you turn your player on, the new region will be set.
Don't forget that if you want to hack it again, you'll need to use a
different code, as listed above. If it's currently set to region 9,
use the code for the last *proper* region you set it to.
People have reported a problem with the codes given however another was posted (57538) try that one to!!
Hope this works post back and let me know. Thank you for choosing Fixya!
Posted on Mar 21, 2009
  • 219 Answers
SOURCE: region codes for Samsung ht z110
Try this
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
Posted on Apr 25, 2009
rodamo
  • 224 Answers
SOURCE: unlock region code on DVD player
http://www.dvdexploder.com/multihacks
go here and have a look
Posted on May 01, 2009
Obertelli
  • 3006 Answers
SOURCE: I have a region 2 samsung dvd player. All of a
What follows is mostly generic advice which applies to the vast majority of DVD players which I've tinkered with.
Your problem normally only happens if someone else has played a different region coded DVD on your machine. Normally you get seven chances to reset the region code before the machine locks itself permanently to one of them. before the changes are permanent the player will usually ask you if you want to change the region code when you try to play a disc from the wrong region.
Before doing anything else it's worth asking other members of your household if they have recently used the player, especially if you know anyone may have been using imported discs. If they've used up all of the region changing opportunities then hacking the machine might not work at all.
If you use a search engine you can search for DVD-P181 hack and these will guide you through the process to make your DVD player a multi-region machine, but there are three different hacks which I've seen for the same player so you may need to try them all.
Posted on Jul 03, 2009
How can a make multiregion my sony bdp s2500
Sony BDP S1200 - Region hack ?. - VideoHelp Forum
forum.videohelp.com > Forum > Hardware > DVD & Blu-ray Players
Dec 14, 2014 - 13 posts - ‎7 authors
Hi peeps, My old Phillips Blu Ray gave up the ghost this week, ... especially bluray players. usually only the dvd side can be made region free. Sony BDP-S2500
Nov 30, 2015
Jan 26, 2010
Samsung BD-P2500 - All Regions Hack Required
Dec 1, 2008
More results from forum.videohelp.com
Multiregion sony bdp s2500 - Fixya
www.fixya.com/support/t25991992-multiregion_sony_bdp_s2500
3 hours ago - multiregion sony bdp s2500 - Sony DVD & Blu-Ray Players question. ... How can a make multiregion my sony bdp s2500 Multiregion. Dec 03 ...
Sony BDP-S580 multi region DVD hack with URC-3440 ' AVForu
Dec 03, 2015 | Sony Televison & Video
Hi, Change region 2 dvd player to multi region however will only play region 1 dvd now and not region 2, tried making it multi region still does not work
Region 1 is North America. You need Region 0 for multiregion.
Where you get that information from, I don't know.
Mar 02, 2011 | Televison & Video
Code for unlocking dvd regions samsung r155
hi,
1.Turn on R155 without disc inserted
2. Press and hold Play and Stop for 5 seconds then release
3. Press menu
4. enter code for current region as above i.e if you have a region 4 type: 7, 6, 8, 8, 4
5. The region is displayed in the top right.
6. You have about 5 seconds to enter the new region (1,2,3,4,5,6 or 9 for multiregional)
Region codes for Samsung:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8)
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
Thank u
Oct 07, 2009 | Samsung DVD-R155
Convert US DVD in Region 1 to play in UK Region 2
Please go to codemasters.com , type in the details of your dvd player, there will be several region code hacks ,follow the instructions and this should work for you, basically you are needing to make your dvd player a multiregion player. all dvd players are multi region at time of manufacture, but they are code set for the county that they are shipped to, hopefully this should help. you can also go on to google type in Hack for whaterver your dvd player is and you will get a region code there.
best Wishes
jimba
May 28, 2009 | Philips Televison & Video
How do I change the regions on my Samsung DVD-VR325
Here you go..
1. Turn ON
2. Open Tray
3. Press Menu Button
4. Enter 57538
(region will appear in top left hand corner)
5. Enter 9 for multiregion
Jay
Jan 17, 2009 | Samsung DVD-VR325 DVD Recorder/VCR
Free region code for samsung dvd HT-
Multiregion samsung
It is suppose to work on most samsung dvd players
Use by your own risk
Turn on
Press repeat or subtitle button
  • for Region 1 press 2, 9, 3, 3 and 4
  • for Region 2 press 3, 8, 7, 6 and 7
  • for Region 3 press 5, 6, 7, 3 and 2
  • for Region 4 press 7, 6, 8, 8 and 4
  • for Region 5 press 5, 3, 8, 1 and 4
  • for Region 6 press 2, 4, 4, 6 and 2
Press 9
Turn off and on again
Oct 09, 2008 | Samsung DVD-V90K Multisystem DVD/VCR
Trying to de code my samsung dvd/vr 355 to play multi regional dvd
samsung dvd vr355 hack (uk model only)
remove dvd
switch on
press dvd button
press menu
press 57538 (76884 for non uk)
a number will appear in top left corner i.e. 2
then press 9 for multiregion
press open
switch off
player should be multi region now
Hope this helps.
Thanks
Sep 13, 2008 | Televison & Video
Samsung dvd-r155 unlock region code
RC 1: 2, 9, 3, 3, 4
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
3. Press menu
Works just fine on my region 4 R155. Hope this helps.
Aug 03, 2008 | Televison & Video
Convert to all regions
Turn On
Press Menu button
Enter 57538
region will appear on top left corner (2)
Select new region 1-6 or 9 for multiregion
Mar 09, 2008 | Televison & Video
Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
Feb 02, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
RCA DRC290 Logo
75 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
