Question about Ambir Technology DocketPort 485
Docketport 485 ambir
Having a problem with it making noise and not feeding document. Please help as soon as possible as I need it for work.
Thanks
    Problem Solver:
  • 5 Answers
There isn't anything you can do the gears inside that scanner I missaligned. I would suggest contacting the manufacturer and seeing if the unit is still in warranty. Those things are impossible to open up so you wont be able to fix it yourself.
Posted on Jun 29, 2009
Clicking sound
Open the feeder and heck for pieces of paper or paper clips. Is there an possibility that someone scanned stapled documents ?
May 20, 2014 | Brother MFC 7840W Printer
I have just moved to a property with electrolux ew1005f washing machine and there is no instruction manual. It seems simple enough to operate but I cannot seem to get it to work! I would really appreciate...
Start of with obtaining a manual then, if you still cannot get it to work having follwed the book, post another query with as much detail as possible- any lights on/flashing, any noises like water going in (or not!) etc and we should be able to assist you further ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Aug 19, 2011 | Washing Machines
The feeder on top of printer does not feed the document--it makes a grinding noise. --The flat bed printer works. Please help me.
Open the ADF cover, Clean / rub the rollers with a damp cloth and a dab of dish detergent.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 28, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP DeskJet 1560 - multiple paper feed
This link may not help you to print duplex, but it will possibly explain why you're having problems...Make sure you fan the paper before loading it. You might try putting a fan on it to dry out the ink as it prints...or try a heavier paper. Good luck! If you google duplexer feed problem you'll see this is the subject of numerous patents and attempts to resolve the very difficulty you are having.
(Maybe another of the same model would work better? Hp should exchange it if it's not working, no?)
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 16, 2009 | HP D1560 Deskjet Printer InkJet
GE Spacemaker XL1800 hum/buzz noise but heating works
the magnetron needs replacement my friend, although you can still heat up food but eventually it will soon fail.
appreciate your kind comment
Apr 12, 2009 | GE XL1800 1100 Watts Microwave Oven
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Fred
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Network Error CE-02
There is a Windows Port that is being blocked. First make sure the IP it's scanning to and IP on the machine are the same. disable the firewall. I'm working on narrowing down the port now and will post as soon as I find it.
-Mike
Oct 31, 2008 | Computers & Internet
Personal fax problem
its seems as though you may have a sensor problem or dirty rollers which feed in your original document. Try this:
open up the cover where you feed in your original document and clean all feed rollers which are normally rubber rollers and make sure you dry them off.
also check for a little arm sticking out which is a sensor flag and make sure it is not damaged and also that it springs back up when pressed.
Can you please let us know the make and model of fax please.
Hope this helps.
John
Jun 14, 2008 | Office Equipment & Supplies
Saying no paper,. even when it's fully loaded & wont print.
i just thought i had the same problem... but you know how there are 2 buttons on the front of the printer once the paper output tray is down? the bottom of those 2 i think switches it back and forth between paper feeding from the normal, top spot, and from somewhere else, so you can try pushing that button! worked for me!
Oct 11, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Ambir Technology DocketPort 485 Logo
159 people viewed this question
Top Ambir Technology Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you an Ambir Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
