Question about Intel Celeron -D 2.26Ghz Computer System PC Desktop
Motherboard replacement needed eide compatible
I need to replace an AK33Gold motherboard but need to keep my old drives. Just bought a new Western Digital 320 gig hard drive a few weeks ago and also am not yet ready to give up my 3.5 drive (call me lod fashioned, but I still havd some old data disks I haven't transfered.
What would you recommend product and procedure wise?
  • leebundy1 Dec 22, 2008
    You called it, the old processor is an amd athalon. But I figured that would probably change when I change the motherboard. Right?
  • Vern Haynes
    Vern Haynes May 11, 2010
    Do you have a formfactor/chipset/processor in mind?
    The AK33 gold is a socket A mobo, so I would assume that you are using either an Athlon or possibly an Athlon XP CPU. Many mainboards (of the last generation) still support floppy drives with headers on the mainboard. Otherwise, you may want to consider a USB floppy. They are very cheap and portable.
  • 281 Answers
Athlon 64 mainboards are pretty cheap right now, as are Intel Dual Core CPU's and mainboards. Some of the newer boards do not even have a FD header on them, so if you want to go that way just pick up a USB floppy drive. Shouldn't cost more than about $15.
For a real bargain, check out socket 478 (intel) and socket 754 (AMD) combos. They can be an excellent deal. I buy most of my stuff @
Posted on Dec 23, 2008
I Have a old G4 tower/400GHZ, Hard drives blown and cant seem to find one anywhere. Quantum 10GB 3.5 series fireball plus
Hi Henry,
You can replace that hard drive with any 3.5" EIDE hard drive of any capacity. Here's a link on Amazon for an 80 GB for about $30: >> Click Here <<
If you want to search for other drives, use the search term: 3.5" EIDE hard drive
The most trusted brands on the market are currently Seagate and Western Digital.
Hope this helps!
Feb 06, 2013 | Apple Power Mac G4 Desktop
My new Western Digital Desktop PATA EIDE 3.5 Inch Internal 250GB Hard Drive only shows 127GB on My Computer. I am running XP SP3 with IDE Connectors. Is the Mother Board too old to handle that many...
The motherboard BIOS most likely have a hard drive size limit. Yes you can create two or mare partitions to use the rest of the hard drive space.
Go to Control Panel - Administrator Tools - Disk Manager to create a partition and format this partition.
Aug 12, 2012 | Western Digital Caviar SE 250GB 7200rpm...
Western Digital WD800JB internal hard drive. I install it, it is listed in device manager, but not on "My Computer". I have unistalled the device and drivers (IDE primary & secondary),...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to boot
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
Dec 11, 2010 | Western Digital Caviar SE WD800JB 80 GB...
I just bought a Western Digital hard drive (model number wd2500js) to replace my old one in my dell. And for some reason the computer is not reading the new hard drive. All it says is Primary drive 0 and 1...
have had similiar problems after pulling my hair out replaced all leads
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
Oct 26, 2010 | Western Digital Caviar SE WD2500JS...
Hard drive crashed need replacement can you give me a part # for a compatible upgrade toshiba satellite m45-s169
Actually you can put just about any size in there. The only thing you need to do is match the connector style. (that takes care of anything else) There are two type SATA and EIDE SATA is the new style and you can get a 500gb drive (and bigger ) EIDE is the older style and has a block looking socket. SATA looks like a tab. On the label on your dead drive you should see a diagram and it should say sata or eide.
Now as long as you get the same connector as your old drive you can get what ever size of drive they have. So this is a good time to spend $10 more and get a 160 or a 320 instead of the 80. The brand does not matter as long as the conenctor and type are correct. I put a 160 in a old A70 I had as there was only a few dollars difference in the prices.
Aug 13, 2010 | Toshiba Satellite M45-S169 Notebook
I want this one WD2500JB
That is an old drive. No need to buy an exact replacement since that one is so old. Any hard drive will do. If your BIOS supports a larger drive, you can get an even higher capacity drive to replace it.
Apr 15, 2010 | Western Digital Caviar SE WD2500JB 250 GB...
Can I replace an ultra ATA drive with an EIDE drive?
Yes there are several ways.
1st is there a spare IDE socket on the motherboard?
If not you can get a IDE to SATA convertor thet plugs in the back of the drive. or you can get a convertor for a SATA drive to make it IDE compatable.
Sep 20, 2009 | HP 100GB Ultra ATA/100 EIDE hard drive -...
New motherboard with old peripherals - will they work
Yes it will is the short answer.
Were I in your shoes I would look at three things at once to give you better options along the road.
First. A better case with a decently rated power supply
Reason is to give you more space to add items (extra hard drives rom drives better video card and a whole lot of other benefits later
Two. A motherboard that has many ram AND io (pci pci-e etc)
slots as possible within your budget.
Reason as for case but also expandability with regard memory and video.
Three. An intel cpu.
Reason durability, compatibility, and all round long term reliability.
I know there are those that might disagree with 3. but in my experience I have had less issues with intel in business environments than AMD
If you found this information useful please click
Aug 14, 2009 | Computers & Internet
Maxtor Internal EIDE hard drive dip switch settings.
I assume you have two IDE controllers? IDE1 and IDE2, I'll try to help, the primary HD needs to have the pin set to primary and the secondary set to slave, if you're running both of these drives off of the same ribbon cable. You may have to go into your BIOS settings and check to make sure the Primary HD is the WD drive.
Apr 06, 2009 | Western Digital Caviar 500GB Internal EIDE...
SATA won't work
I think you're saying you've got XP installed, but the second drive isn't showing up.
You need to format the drive.
Right-click My Computer/Manage/Disk Management.
The drive should show as unallocated. Right click and select format. It may ask you to create a partition first.
Oct 16, 2007 | Intel Motherboard
Open Questions:
as some sites suggest about cheat for igi game i tried it and make changes under Project IGI- I'm going in Cheats----hi friends in this game it is difficult to get the blood/medipack to get this use the folowing instruction. 1)first go to the igi installed folder then go to weapon folder u will find some folders like Ak47,binoculars,colt anaconda,medipack etc. 2)then go to Ak47 folder you will find a folder like weapon the open in hex editor u will find a string like weapon_id_Ak47 by using hexeditor edit the string to weapon_id _medipack. then similarly go to medipack folder u will get a folder like weapon then open in hex editor edit weapon_id_medipack to weapon_id Ak47 the save it. 3)when u will kill a soldier u will get a medipack. for hex editing i installed software and changes in hex file as i described above but due to mistake my igi game not start well aND , SHOW A error like igi stopped and shows problem detail Problem Event Name: APPCRASH Application Name: IGI.exe Application Version: Application Timestamp: 3a1d74c6 Fault Module Name: StackHash_169c Fault Module Version: Fault Module Timestamp: 00000000 Exception Code: c0000005 Exception Offset: 00000000 OS Version: 6.1.7600. Locale ID: 1033 Additional Information 1: 169c Additional Information 2: 169c69b50cca39ebafad90cf9acfe712 Additional Information 3: 166e Additional Information 4: 166ed9faa1184e606930c56f1ef84d85 please send solution ... or reply
Dec 31, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Intel Celeron -D 2.26Ghz Computer System PC Desktop Logo
79 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
