Question about Pioneer PRO-99 TV
Green colors are seperated from rest
During outer convergence, the green points on the lower left were a few inches aboive and the right of the other color ponts. The green was also crooked. The same is almost in the other three corners, but not as bad
  • Kurtis Wood Apr 23, 2007
    Thanx Stargazer,
    Is this a part I am able to order and replace?
    goldenorange
    Novelist:
    Champion:
  • 236 Answers
You might have a bad green convergence output IC either loose from the circuit board or open internally OR shorted. Stargazer
Posted on Apr 23, 2007
My Toshiba TV was on like normal, then suddenly the green color seperated from the red and blue.. On the bottom left corner you can see the green is 4 inches up while the others stay at the bottom. So if...
Ur tv have a problems known as a convergence pictures problems,it is dead.Ur tv have any colors lines like R,B,G mis alignments,tv have any colors shadows pictures or have a 3D pictures look alike?Yes,than ur tv have a dead convergence board to causes the tv to have all of these pictures problems.The tv convergence board must have be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Sep 20, 2011 | Toshiba TheaterWide 52HM84 52" Rear...
Colors of the wires for CX 400 headphones
yellow and red-green are most likely grounds. red is normally the right channel and green is normally the left channel. quick question though, why on earth would you cut the plug off of a pair of 75-90$ headphones?
Apr 15, 2010 | Sennheiser CX 400 Headphones
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
Green color seperation multiple images convergence will not fix
Your TV most likely a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
May 14, 2009 | JVC AV-48WP74 48" Rear Projection...
Colors have seperated on tv, and curve
You have a convergence problem.
Maybe need change the IC of convergence, or the power supply of these parts.
Bye.
Apr 04, 2009 | Mitsubishi VS-50501 50" Rear Projection...
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
51MP392H/17 Blue convergence wont move not IC chip
You could have some opened resistors low ohms that are bad go back and ck them around convergence ics.
Nov 20, 2008 | Akai PT4298HD Rear Projection Television
No color adjustment
Problem with Hitachi 51F500 51 in. Rear Projection HDTV-Ready Television
i want to learn how to do convergence on my tv its a hitachi rear projection i have problums with colors not aligning,could you lead me in the right direction ps: i don't have the remote so i
can't magic focus
Posted by avatar13.jpgejaparks on Mar 03, 2011
AdChoicesMajor Appliance Repair
www.graysoncollinapplianceandac.comResidential/ Commercial, all brands Friendly, knowledgable technicians!
Get $75 of Advertising
www.Google.com/AdWordsPromote Your Business On Google. Claim Your $75 Coupon Now!
Solutions (1)
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 04, 2008 | Philips Magnavox 9P6034C 60" Rear...
Arched picture at bottom seperating the green and red
Your tv has a convergance failure. the convergance ic's need to be replaced. Upgraded part # STK392-150 or STK392-160. Both ic's should be replaced to prevent future failure of other colors.
May 20, 2007 | Toshiba 43H70 43" Rear Projection...
Convergence problem, lower left corner fixed green gun convergence bows upward
You have a componet out of tolerance in the green drive circuits, resistor or capacitor. If you have the service manual you should be able to take some raedings off the test points for the circuit and be able to track it down. I am enclosing a link where you can purchase the service manual for that set for 10.99. They will mail it to you unless you go back to the site and request that they email it to you by clicking on the contact us link. They also offer unlimited free support if you purchase your manual. I am one of their support techs. Hope this helps. Heres the link
http://servicemanuals.vstore.ca/
Dec 27, 2006 | Pioneer PRO-119 60" Rear Projection...
Televison & Video Logo
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
