Question about Brother MFC-8220 Fax
The Black line on the paper when I scan and fax
My Brother MFC-8220 have problems of scan and fax the paper. It always show the 3" black line on the right side of the paper, It doesn't have any problems of receiving fax and print. I tried everyway that people suggested online. I cleaned the drum, scanner glass, the glass thing on the top of the machine where insert the drum. I also did the RAM clear by press the *2864 01 on the machine, nothing lookes help. Please advise what should I do about it. Thanks.
  • 4 more comments
  • ydu30 Jan 02, 2009
    Hi, Wtart:
    Thanks for your help. I tried what you suggested and after I entered *286482, the screen shows the number for couple of mintunes and back to the sleep mode. It didn't display any code on it. just back to the sleep mode just the way it should be.
    Please advise.
    Thanks
    ydu30
  • libster1318 Jan 16, 2009
    when i entered 82..it now says Machine Error 00
  • Anonymous Jan 16, 2009
    same problem Cannot access maintenance using the procedure mentuioned.
  • spinerbait Feb 19, 2009
    i get a 1/2 inch black line on the right side when i copy or scan. it prints just fine.
  • rabarnes08 Feb 21, 2009
    I have the brother fac all-in-one #665cw with the same problem but the line is towards the middle of the paper pls help
  • wtart May 11, 2010
    If you have cleaned the scanner glass and you still get the same thing, there is a possibility that you may have scanner malfunction.
    To verify, try this: Access maintenance mode once again by pressing Menu * 2864, after it enters maintenance mode press 82. Reply back to me with the code that shows on your display. I will then respond to you with the status of your machine.
The sensor-bar/imaging unit is not lighting up all the way. Maybe a loose plug at either end of the cable; the bar end- open and remove the scan feed for access, or underneath- remove bottom covers. If no loose cable, the bar has failed- save your drum and toner and buy a used/refurb machine since they want the same price for a new imaging sensor bar. {-O
Posted on Mar 10, 2009
    Champion:
  • 320 Answers
Try cleaning the grid on the drum unit and you might replace the drum
Posted on Jan 20, 2009
My Brother MFC-7420 Printer always prints black lines and splotches down the left side of my paper. This happens whether I'm scanning or printing from my PC. When I looked at my drum, it appears a
If you are seeing vertical streaks/black lines your primary corona wire is dirty and or the fax scanner may be dirty.
1)To clean the corona wire you take the drum unit and toner cartridge and place it on disposable paper to avoid spilling.
2) Clean the primary corona wire inside the drum unit by sliding the blue tab from right to left several times.
3) Return the blue tab and snap it into the home position.
4) Reinstall the drum unit and toner cartridge.
5) Close the front cover.
Caution: if you do not return the blue tab to the home position it may repeat the black lines.
Nov 29, 2012 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-8220 leaving ink on printed docs. How do you clean that?
That's usually a bad toner cartridge that dumps too much toner per print. Buying a new toner cartridge should fix it. You may need to wipe up a little spilled toner inside. Just use a dry cloth, and be very careful around the little black levers that stick up to detect the paper.
There are other manufacturers who sell toner for these, but some of them have toner inside that's so hard to stir, it breaks the gear in the machine. That makes a very expensive repair for the little money you save on generic toner.
Dec 03, 2010 | Brother MFC-8220 Fax
Brother MFC 8220 has a red ligth with an error message saying check paper reload paper. I put the tray correctly with papers loaded and it keeps. Cannot print, copy or fax anything
mine was doing the same thing. pull the paper tray out and there is a black lever next to the feed drum, it wouldn't move up and down. I took of the cover and slid the lever over to the left so it would move freely and now it is fine.
Mar 12, 2010 | Brother MFC-8220 Fax
Paper port Brother MFC 8220
Paperport is the scanning software for Brother products. It is included in the driver CD
Dec 01, 2009 | Brother MFC-8220 Fax
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Having problems with long distance fax transmissions - receiving number not receiving fax. Fax machine: Brother MFC-8220.
Is the 1 placed infront of the number, is the line part of a PBX system requiring to dial a 9 to get a outside line.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 13, 2009 | Brother MFC-8220 Fax
3 black smudge horizontal lines on prints
Your brother can send faxes without printing the pages try your computer just you should download the driver.
You can download the driver from this link: " http://download.cnet.com/Brother-MFC-8220-USB/3000-2118_4-65318.html ".
About the lines which appear on the print, you will have to buy a Drum unit for your Brother 575, because the drum cleaning blade has quit working and there is no other way to fix this only by putting a new drum unit.
note:
the drum unit is different from the toner cartridge, but if you search good you can find them together for lower price.
Please rate me
Jul 15, 2009 | Brother MFC-8220 Fax
I have a Brother MFC 8220 Super G3. It will accept incoming faxes without a problem, however when I try to fax anything out at all it jams and says to call BROTHER
most likeli there is something stuck in the feeder. cut a file folder to 8x11 and force feed it thru the feeder manualy if there is any paper un there it will be pushed out, good luck brother tech
Jan 06, 2009 | Brother MFC-8220 Fax
Brother MFC-8220 Fax Logo
932 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
