Question about Pentax Optio 43WR Digital Camera
Turning on the camera
I used my camera today for some time until I run out of batteries. The camera was turned off due to the power failure. When I inserted new batteries in it didn't want to turn on again. What can I do? It doens't work any more at all. It just says nothing.
  • Flummox Feb 02, 2008
    Mine just started doing the same thing. It runs on AC power with the adaptor, but no longer on batteries. When I press the power button, it blinks yellow, but the camera won't start on batteries.
SOURCE:
SOURCE: S5i won't turn on in Capture mode
Hi Aunty Edna. I had exactly the same problem with my S5I 4 weeks ago. Went out and bought another camera then decided had nothing to lose by doing heart segury on S5I. Found it has a watch battery soldered to board under memmory card holder which was flat. I replaced that with a similar battery and it fixed the problem. Its not an easy job but if you know someone good with there hands it would take about an hour.Hope this helps. Regards Andy
Posted on Dec 23, 2006
jackboy
  • 2985 Answers
SOURCE: i think my camera's stuck
This is possibly some dirt has got into the lens barrel thus making things grind to a halt. Do you have access to a photo store or camera repair shop? I don't think there is much a normal user can do here.
Posted on May 16, 2007
SOURCE: Camera turns on, beeps, turns off.
I've managed to fix my camera - but it took several hours and I needed someone to help. Not sure everyone will want to do this.
Here goes:
Need small Philips screw driver. Pair of tweezers for the small screws. A small flat screw driver for leveraging
1. Remove the battery and memory card.
2. Remove wrist strap
3. Take off the battery cover by gently lifting the retaining metal strap (with small flat screwdriver).
4. Remove all screws of the front cover of the camera housing. (one of the screws is smaller than the others). There's a screw above wrist strap loop.
5. The top of the cover is clipped in under the shiny silver bit with the on/off switch and shutter button (I’ll call it the switch/speaker assembly). I find that inserting a finger nail and gently applying pressure works well.
6. The switch/speaker assembly is best kept secure by an elastic band.
7. Verify the problem is the same: looking into the lens, at bottom right corner of camera is a small motor (silver). Look carefully, you’ll see a white plastic gear which connects the motor with a (hidden) pink gear. This pink gear is attached to a worm gear (a pin with a fine screw thread) that is brass/golden. On this worm gear is a U-shaped blue piece of plastic, which in my case was no longer at right angles to the shaft/worm gear. That's the problem.
You should be able to see all of this under a strong light and peering into the little openings.
8. Resist the temptation to just fix this by leveraging the blue rider with a tiny screwdriver (or something) until it is back in its original position. You might strip the screw thread inside the blue rider and that would be the end of the camera.
9. Next take the LCD display off. Above the little motor is a metal clip attached with 2 screws hidden behind self-adhesive copper strips.
10. Fold the LCD panel away from the camera body. Then carefully and gently unplug the power plug (pink & white in my case). Careful, the green PCB (printed circuit board) to which the socket is attached is flimsy. I don’t think it can take much force. Rather try to pry the plug & socket apart by using a knife or tiny flat screwdriver?
11. With the power cable removed, you can turn the LCD panel over (anti-clockwise) to undo the fold that is in the flat cable. The flat cable is attached to a small white plug on the PC board that contains the rear panel buttons of the camera. There is a thin, orange plastic sheet stuck over this. Lift it away gently and store somewhere for later re-assembly.
12. The socket for the flat cable has a black flap that can be lifted to release the cable. Gently tug the flat cable out of its socket and you can put the LCD panel aside.
13. Remove the metal plate that covers the rear of the lens assembly. First remove the two small screws, then unclip it at the bottom and on the side.
14. CAREFUL: in the centre of the lens assembly is the CCD (charge coupled device). This is the “thing” that contains 7 Megapixels and takes the pictures. NEVER TOUCH THE FRONT OF IT (or so I have read – I think it prudent to observe this.
15. Remove the 3 screws that hold the CCD in place. It needs to be lifted vertically from the lens assembly, otherwise it gets stuck. NOTE that my camera had two small washers under the CCD assembly: top right screw = copper, bottom screw = silver washer. The CCD assembly, too, is attached with a flat cable. The socket works exactly the same as the LCD display. I put my CCD assembly into my glasses case to prevent it from getting dust or dirt on it.
16. Now remove the 4 screws that keep the rear cover of the lens assembly attached.
17. Before removing the cover, unhook the little metal spring that is attached to the mechanism next to the worm gear. Take it right out, feed a bit of thread through one end (for re-assembly) and put it aside. (If you attach the thread immediately, the risk of losing it is reduced.)
18. Then, using your finger nail gently unclip the plastic hook next to the worm gear and lift the lens assembly cover off. There is a long plastic pin so you need to lift it quite high. Observe how the pink gear is situated relative to the plastic mechanism crossing the lens assembly. Remove the pink gear/worm gear with the blue “rider”. Be careful not to lose the small white gear that makes the connection to the driving motor.
19. Unscrew the blue “rider” from the worm gear. Ensure you keep the same orientation and gently find the correct way of putting it back. That is at right angles to the worm. Leave it fairly close to the end of the worm gear away from the pink gear.
20. Now put it back carefully. Try not to lift the part that crosses the lens assembly (the one that was attached with the little spring) too much. Otherwise a little lens flips down and you’ll have extra work to put it all back correctly. There is also a pin on which the plastic piece rides which then needs guidance when re-assembling. (Happened to me, not the end of the world.) (BTW, I think this is the auto-focus mechanism, but I can’t be sure.)
21. Hook the spring over one of its attachment points. Feed the thread through to the other side and use it to hook up the other end of the spring. Cut and remove the thread.
22. Replace the rear lens assembly cover. The long plastic pin needs to find its corresponding hole near the middle of the lens assembly. Remember the hook at the worm-gear corner. Do that one last (after the screws), ensuring that all gears and shafts/pins are in their respective holes.
23. Put back the CCD. I attached the flat cable first (flip down the black locking lever on the socket), then put in the screws. (Remember the washers.)
24. Now put back the metal plate. Clip it in on the left side first, then at the bottom, then the screws.
25. Attach the LCD flat cable. (Remember to lock the socket.) Flip it over and attach the power cable to the LCD. Remember again to be careful with the plug & socket since the PCB is flimsy. Try to apply pressure only on the plug & socket.
26. Replace the orange plastic that covers the electronics.
27. If you like, try out the camera to see the effect of the repair. I used an elastic band to keep the LCD and switch/speaker assembly in place. The battery can be inserted as per normal. NOTE: Where you observe the little blue rider in its installed position, there is a plastic pin sticking up towards the front of the camera (just under the lens). You have to hold something over this hole to prevent the pin (which is being pulled up by the little spring we removed/replaced earlier) from coming up too far. I held my thumb over the hole. If you don’t do this, you camera won’t switch on properly or won’t focus correctly. (In normal operation the front cover stops the pin from advancing too far.) Now switch on and see that all is in order. Careful when operating the zoom and other switches, since you don’t want to break the plastic covering of the switches.
28. If all is OK, then finish the assembly. REMOVE the battery! Next is the little metal plate that keeps the LCD panel in place from the side of the camera. (Remember to flatten/re-attach the adhesive copper strips.)
29. Clean the LCD panel and inside of the rear cover very well. Then put on the back cover.
30. Attach the front cover, clipping in the top carefully. Be careful to position the speaker/switch assembly properly. There is a tiny locating pin (made of plastic) - don’t break this.
31. Put back the screws all around the camera housing. Remember there is one smaller screw that fits underneath the lens. Remember also the screw just above the wrist strap loop.
32. Slide back the battery compartment cover onto its metal strip. Insert battery & memory card. Attach wrist strap. Done!
Stephan
Posted on Jul 12, 2008
  • 3 Answers
SOURCE: Digital camera
I had almost similar problems with my A10 from day one. The camera shuts down before the battery is depleted, most of the time while I was operating the zoomlens. I bought a new battery, but that didn't solve it. Later I decided to take it apart as a last option. As my suspicion was the zoomlens I took out two crews of the motor that operates it. Now the motor has a bit more space to move. It seemed to be too tight against the gears so it could cause an overload. After that it worked perfectly. I made pictures for hours without having the same fault again. Be carefull too make notes where all the tiny screws belong of the casing. And maybe it will be enough to just loosen the motorscrews, but leaving them out will not make it fall out of it's place. I hope someone can use this information.
Greetings, Ron Timmermans.
Posted on Jul 25, 2008
gemmy23
  • 346 Answers
SOURCE: New batteries but no power...
Have you tried cleaning the battery terminals with a bit of alcohol on a Q-tip? Make sure the terminals are completely dry before inserting new batteries. I am not sure if this is your problem as it may be a lose connection between the battery unit and the camera. Best of luck.
Posted on Aug 06, 2009
The camera will turn on however the lens will not come out and it makes a bleeping noise 3 times. After this the camera turns off. We have removed the memory card and battery and nothing works. Any ideas?
The lens error is due to failure of the lens control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service centre.
get estimate before you decide. It will be good to have it checked at the Samsung service as you do not have to run around for spares.
Apr 23, 2011 | Samsung ST45 Digital Camera
A new set of batteries after 3-5 snaps saying Low battery. what could be the problem ?
  • Hi, this can happen due to failure in detecting battery level, (sensor problems) if this case you can use the camera eve though it says low battery,
  • in the other case the battery might be low power model, for this you have to check the battery label ( ex:- 2000mAh). see wheather it matches with the original batteries.
  • also can happen due to camera malfunction, for example the software or display may be running even when it is turned off.
Feb 16, 2011 | Olympus SP-320 Digital Camera
Sony Cybershot DSC-P52: Lens Cover Failure
If the camera has recently been dropped you may have lens damage that is preventing it from powering up. If it's something simple, a power-down reset may help. Turn the camera off, remove the battery, let the camera set for at least 30 minutes, then replace the battery and power up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera and give them a full charge (assuming that you are using rechargeable batteries). This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced or the camera may have a problem that requires professional repair.
Dec 18, 2009 | Cameras
Even with new batteries, the screen says batteries exhausted on Coolpix L18. Sometimes by switching the position of the batteries, it turns on. (I'm not talking about changing the polarity...just changing...
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, chances are that your camera may have a problem that requires professional repair.
Oct 12, 2009 | Nikon COOLPIX L18 Digital Camera
Camera will not turn on. Tried several new batteries.
I had (and continue to have - from time to time) the same problem. Each time I replace the batteries and try to turn the camera on, it will not go. I have found a simple "fix" with my own camera: that is to flip the on/off switch several times rapidly, and then, you will eventually hear the beep indicating the unit has powered on. Not really sure why this works, but it is the only way I can get mine to work. It has been a persistent problem since I have owned it.
Jun 09, 2009 | Panasonic Lumix DMC-LC33 Digital Camera
Sony trv87
Although the battery shows it takes a charge and the camera will run in playbackmode (VTR) I found if I remove the battery and run on AC the camera turns on and now I can record with it. The battery must be the problem.
Jan 25, 2009 | Sony Handycam CCD-TRV87 Camcorder
I have to set the date/time every time I turn on my Canon A720. Once I've set the date/time, it stays set until I turn the camera off.
YOUR PROBLEM SHOULD BE OVER! ON THE BOTTOM OF YOUR CAMERA IN THE COMPARTMENT WHERE THE TWO BATTERIES GO IS A SMALL DOOR. THIS IS THE CLOCK BATTERY DOOR! YOUR CLOCK BATTERY MUST BE DEAD OR MOSTLY DEAD. AT LEAST IT IS WORTH CHECKING OUT. THIS IS THE MOST LIKELY CAUSE OF TIME DATE FAILURE BECAUSE IT WILL RUN WITH THE MAIN BATTERY POWER WHEN THE CAMERA IS ON, BUT WHEN YOU TURN IT OFF, THIS SMALL BATTERY IS SUPPOSED TO KEEP THE TIME, DATE CURRENT IN THE OFF MODE AND IT IS DOING IT! CHECK IT OUT AND SEE IF THIS DOESN'T SOLVE YOUR PROBLEM. GOOD LUCK! HOPE THIS WORKS FOR YOU!!
ARCLIGHT1217
Nov 08, 2008 | Canon Cameras
S5000 fujifilm
Was probably caused by the zoom carriage locking on power out due to batteries running low. Turn off camera, tap barrel with solid but non-metallic object and turn on. Did this two times and it worked for me on second.
Oct 16, 2008 | Fuji FinePix S5000 Digital Camera
Can't get tv to turn on
There may be a scan failure, and or a failure in the main power supply. The main power supply is in the protect mode due to the failure.
A TV service tech should be able to go through the set and determine the exact failure to service it.
Jerry G.
Apr 19, 2008 | Televison & Video
Off and On
The power button must be stuck. Try to clean it.
Jul 02, 2007 | Sony Cyber-Shot DSC-P200 Digital Camera
Pentax Optio 43WR Digital Camera Logo
32 people viewed this question
Top Pentax Cameras Experts
Geoff Hone
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Pentax Camera Expert? Answer questions, earn points and help others
