Question about Compaq Presario R3000 15.4-inch TFT WXGA LCD display -350840-001 (350840001) CD-ROM Drive
I Have a Compaq Presario r3000 15.4 lcd screen and the display had lines running all through it and now the laptop will not even boot the screen does light up. Where is the video located on the motherboard
  • 538 Answers
Common problem.
There are small VRAM BGA chips.
They needs REFLOW.
Basically motherboard needs service.
Posted on Mar 20, 2009
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
My Compaq presario CQ42 has a white-red thin line at the right corner of the screen. Is it a problem to use the laptop with it before I fix it.
@tharindupedu
If you see a Vertical/Horizontal colored lines on your LCD, that means either the Video Card, LCD, or the LCD Flex cable (this is the cable that connects your motherboard to your LCD screen) are going bad and needs replacement. You can still use your laptop though but I strongly recommend having it fixed ASAP before it gets worse. You're still under warranty, call HP/Compaq at 1-800-652-6672.
Good luck.
Sep 07, 2011 | Compaq Presario M2000 Notebook
I haveMy compaq presario CQ40 and my monitor screen got flicker always for past few days and more red horizantal lines @bottom of the screen, where i couldn't see the data,time,date... Plz help me...
This is usually a sign of either a bad LCD screen cable, a bad LCD screen, or a bad display adapter.
If you connect an external monitor & you get a picture without these red horizontal lines, then your display adapter is OK.
Diagnosing a bad LCD screen cable or a bad LCD screen requires that you disassemble the LCD screen panel, & swap them one at a time with a matching part. This way you can identify which part is causing the problem & replace it.
Sep 02, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Compaq f756NR laptop won't boot.
I think this is a problem with the laptop's LCD display. To verify this connect the laptop to an external display and see if it resolves the issue. If it does then its confirmed that its a display related issue. Since the issue has appeared suddenly I dont think its a serious problem. May be just loose/disconnected connectors. Should be a 10 minute job for a qualified technician.
If the external display too doesn't come on then its an issue with the graphics card and you may need to replace it.
Oct 24, 2009 | HP Compaq Presario F756NR Notebook
Compaq presario starts but will not boot up
Check whether your CPU fan is working. It could be due to Fan malfunction of the cabinet also. Seek technician's help, if not resolved
Aug 21, 2009 | HP 435768-001 - Compaq Presario C300...
FS050UA , COMPAQ PRESARIO NOTEBOOK PC CQ50-210US the screen has lines and a black spot
Turn on the notebook and press F10 to get into BIOS screen. Even if the lines and the black spot appears then the issue is with the internal hardware of the notebook.
To check further connect an external monitor to the notebook and press Fn and F4 keys on the keyboard to get the display on external monitor. If the external monitor display is fine then the issue is with the LCD screen or else the issue is with the Video card of the notebook.
Jul 31, 2009 | HP Compaq Presario CQ50-210US Notebook
Lines on laptop screen(lcd)
connect your laptop to monitor and check display there, if the display is fine then the problem is on lcd, check it by some technician
Oct 06, 2008 | Compaq Presario M2000 Notebook
Computers & Internet Logo
66 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
