Question about Car Audio & Video
Rosen DVD monitor is not displaying a picture
I am not getting a picture on the DVD screen when playing a DVD. Audio is working and the DVD player itself is working. Verified this with external TV monitor. The DVD screen does show the Rosen splash screen when it starts up, and it does display when the system is muted or changed to FM on or off. Initially it was sensitive as to where the screen was opened to, but eventually it got to where it will not display the movie at all.
SOURCE: Rosen CV-II 10.4 inch Car Monitor
ribbon cable broken that leads from fpd pcb to cpm control
Posted on Aug 21, 2007
  • 16 Answers
SOURCE: No audio with CD/DVD but works fine with aux and FM
Check the cable between the media centre and bass module for signs of damage (if its buried in the wall / under the floor and you can't check it, assume it could be damaged).
however, this sounds like a fault with the Digital Analogue Converter - this coverts the digital audio on a disc to analogue information the amplifer can use to produce sound. Contact your retailer for exchange / repair.....
Posted on Jan 16, 2008
Ruff_Racer
  • 49 Answers
SOURCE: cannot see dvd picture
If you have the "dvd bypass hookup" dont worry about the E-brake, go to the background setting screen and make sure it is set to "no image"...unfortunately with this system, you cannot set a background image and play videos at the same time.
Posted on Jun 25, 2009
  • 220 Answers
SOURCE: i have DVD player purchase 4 years before. The DVD
is you tv setup correctly,tv should be set to AV,check connections from dvd to tv.check cables connected to correct slots.
Posted on Jun 29, 2009
bigTROY502
  • 129 Answers
SOURCE: 2005 chrysler 300 radio/nav system problem.
Sounds like an amplifier issue. Check the fuses that run the factory amplifier, if not a fuse, then most likely a bad amp.
Posted on Aug 08, 2009
I've got VW Passat b6 2006. Rosen-VW0710-H11 is installed in it. When I try to play DVD (no matter audio or video) system displays message: "Password Fail". What can be the reason of this...
I would recommend resetting the Rosen unit. This is done by entering the "Menu" and pressing "Settings". From this screen, you select "Keypad" in the top right corner of the screen and then enter "7-5-2-3" and press "Enter". This should erase any code for Parental Control (levels 0 - 8). Also, the Rosen product states to only use "Store bought media" for CD's and DVD's meaning that it won't play all 'burned' discs. Hope this helps.- Elliot
Sep 29, 2011 | Car Audio & Video
It looks like it reads the dvd but we just get a black picture no sound or pic. We just porchased 2005 Yukon Xl Denali.
Check the A/V ouput on another monitor and if there is no display then this section is faulty.
If picture is present then the monitor is faulty and needs a check for the backlight circuit or the LCD.
Jul 21, 2011 | Rosen CV7080D Portable DVD Player
I have tried everthing i can to get the dvd player to be heard over the car speakers but can only get the sound on the head phones. Are these Rosen A7 dvd players designed to play over the radio or not?...
Put a cd in the dvd player then tune to the channel and it should work, then try a dvd.
When dvd player does not boot up and display the Kia logo, try moving the door as the hinge turns on the screen and sometimes the connection in the hinge can play up a bit.
Apr 13, 2011 | Rosen A7 Car DVD Player
Dvd player hangs up while playing
Sir I dont think its the dvd that is not working I thisnk its the screen that is starting to fail, it can be that the dvd is not sending the video signal to the screen when you open it and thatt is why you only get the blue screen and nothing else, because if the dvd was not working let it be the laser or a motor the most common message that you get in the screen is no disc, but that is not your case so I would have the screen check on that portable dvd.
Jul 23, 2010 | Rosen CV8081D Portable DVD Player
Overhead DVD monitor screen dead but sound plays through stereo
If it's a Rosen dvd player the dvd will need to be put in the unit itself & not the unit in the dashboard! The dvd player mounted in the head ligning is a seperate unit from the stereo system fitted in your dashboard!
Sounds to me like you are putting a dvd into the dashboard stereo system which will play any audio through the car speakers...
Put a dvd into the Rosen unit itself & i am sure you will get a picture on the drop down screen! Remember that as far as i know all Rosen dvd players transmit the sound from the dvd to infra red headphones that should be included! Remember to check the batteries if you still can't hear any sound as they run down quick if the headphones are left on!
Hope this helps....
Apr 08, 2009 | Rosen A7 Car DVD Player
Rosen a9 dvd player
Hi, Rosen plays repairs close to the vest, they want you to take a digital picture and send it for help. I don't know if they will send you any info or not but you can email them at info@rosenentertainment.com and see. I also have a phone number, don't know how old it is, 909-898-9808. Good Luck!
Nov 12, 2008 | Rosen CV7080D Portable DVD Player
Rosen a7 dvd player
Hi there, sounds like the ribbon to the screen is broken.
Mar 11, 2008 | Televison & Video
Buttons don't work, wont eject disk
the model you have pictured does not have a dvd,only a monitor
Jan 08, 2007 | Rosen CV1092 10.4 in. Car Monitor
Dec 20, 2006 | Rosen CV1092 10.4 in. Car Monitor
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
