Question about Sharp LC-26SH10U 26 in. LCD Television
Intermittent Picture break-up
Occasionally, the right hand 1/12th of the screen will go all or partially green and then return to normal. Also, After some episodes of this, it will continue to get worse and become ragged on the edge. A slight tap on the set sometimes clears the problem. Usually, it will correct itself after a few minutes.
4 Suggested Answers
  • 53 Answers
SOURCE: No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Posted on Mar 14, 2008
SOURCE: green screen when changing channels
Hi Betty, I have the same problem and am researching it so far I have read a variety of solutions not sure what to believe however here are a few of them. 1.Conections on a little white ribbon strip/cable inside the tv needs to be cleaned 2.Change your HDMI cable to a better one and or use standard RCA jacks 3.Unplugging the tv for 10 minutes then plugging it back in. 4. T-Con or video board going out 5. Factory reset? I hope someone has a solution fo this.
Posted on May 14, 2010
e-Guru
  • 3917 Answers
SOURCE: Experiencing blue screen when first
Hi
Check if all the necessary cables are correctly connected. Please check if the cable contains the digital TV signal supplied by your cable TV service provider. Please make sure the correct signal source is selected: Press the "menu" button on the remote control, select "External Input", and choose the correct signal depending on your using environment.
Please view this article to get more details:-
http://www.ehow.com/how_6041027_fix-snowy-screen-satellite-tv.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Jan 07, 2011
My 32LD30UA LCD TV is 16 months old, when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.Help?
My HITACH 32LD30UA LCD TV when you switch TV on the picture has a band of reds and greens running down screen for about 30 minutes then returns to normal.
Dec 12, 2010 | Hitachi 32LD8700 32 in. LCD Television
Picture will freeze occasionally for approximately 30 seconds, then return to normal. Switching channels seems to take care of the freezing right away. It is a 53 inch rear projection about 8 years old,...
Good Day,
Try upgrading the Screen refresh rate.Right click on your desktop,properties,in the tab settings select advanced and then select the monitor tab.Select 85-100Hz in refresh rate.
I hope this helps...
Good Luck!
Jun 22, 2009 | Sony KP-53HS30 53" Rear Projection...
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Nov 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Green color comes on and off
I need some answers here... Do you have only one video source to test it? Is this happening with an external source or with your tv tuner or both? I need more info....
Aug 10, 2007 | Samsung HCL4715W 47" Rear Projection...
Sharp LC-26SH10U 26 in. LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
