Question about Dell 926 All-In-One InkJet Printer
Envelope stuck inside of printer Dell Photo AIO Printer 926. Can see it down inside from the loading side but no where else and it won't print anything else (won't load the paper). How do I get to the envelope to get it out.
  • Anonymous Mar 07, 2009
    envelope stuck inside of printer Dell Photo AIO Printer 926. Can see it down inside from the loading side but no where else and it won't print anything else (won't load the paper). How do I get to the to envelop to get out
  • 24 Answers
Raise the scanner lid as if you were going to change the ink cartridge. You should be able to see the stuck envelope -- just grasp it and pull firmly to remove it.
For suggestions on avoiding paper jams, please go to Dell's support page
Please rate this solution if you find it helpful!
~~Cheryl
Posted on Dec 26, 2008
It does not print alignment test page can you email me one ?
How to Align a Printer Cartridge for a Dell Photo AIO 926Printers capable of producing high quality graphics and photos, like the Dell Photo All-In-One 926 printer, must have their cartridges properly aligned for best results. Typically you only need to align your printer's ink cartridges immediately after replacement. However, if documents show signs of uneven lines the cartridges being out of alignment. After aligning the cartridges print a test page to check print Instructions 1 Load printer paper into the Dell Photo 926 printer 2 Click on the start menu icon, on your computer, with your left mouse button. Left click on "Control Panel." Left click on "Hardware" and then left click on "Printers and Devices." 3 Locate and double left click on the icon for the Dell Photo 926 printer. The printer control window will open. Double left click on the "Adjust Print Options" button. 4 Click on the "Services" tab in the printer's window menu bar. Double left click on the "Align Print Cartridges" button." Left click on "align." Wait for the "Parameter" page to print. 5 Compare the figures on printed parameter page to current settings in the "Align Print Cartridges" window that has popped up on the computer. If the figures on the printed page correspond to the figures displayed in the window the cartridges are in alignment. If the figures on the page do not correspond with the figures in the window you need to set new parameters. Enter the new figures from the printed parameter page into the fields on the align print cartridges window on the computer, as directed by the prompts. 6 Click "Done" or "Okay." Exit out of all menus. Print any document and check the text and or graphics for quality.
Oct 13, 2011 | Dell 926 All-In-One InkJet Printer
My dell photo AIO all in one printer 926 the scanner wont work. The printer and copier works fine but the scanner dont
First I would reinstall the driver from the Dell website.
If that doesn't work, check if you are under warranty and have them replace it.
Jan 25, 2011 | Dell Photo 926 All-in-One Printer
I'm tryin g to scan a photo with my Dell AIO 926 Printer, connected to my Dell Inspiron 1525 laptop. But the laptop doesnt seem to be bringing up the AIO 926 printer file folder/menu, and when I request...
Did you figure this out? You should have a "Dell All-In-One Center" that was installed with the drivers for the printer. Try searching for it by pasting that phrase in the box in your "Start" button. When you locate it, drag the shortcut to your desktop or up in the top of the programs in the Start location. When you click on the Dell All-In-One Center icon, you should find some options for scanning.
Nov 12, 2010 | Dell Photo 926 All-in-One Printer
Deleted the whole Dell photo aio 926 program in error. Try to run the orig cd that came with printer but it won't run. How can I get it back? Went to search and came up with 'google icon' and 'folder' but...
Try reinstalling the printer using the instructions located at....
926 Photo All-In-One Printer owners thread (W7)
You'll need to disconnect the printer. Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer.
Install the proper drivers. You'll get the message, the printer is not connected. Connect the printer at this time.
Rick
May 21, 2010 | Dell 926 All-In-One InkJet Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Dell Photo 926 AIO "Load Paper" error
Solved myself: I reseated the 4 internal wire harnesses and ribbon cables. None of these were obviously loose, but it seemed to do the trick.
Jan 06, 2009 | Dell 926 All-In-One InkJet Printer
Dell AIO 926 driver is not installed, even though I installed it!
Hi, The problem here is that the CD has an older version of the driver which has some known issues. Few steps will be required to fix this.
  1. Unplug the printer
  2. Goto control panel -> Add/Remove programs (or) Programs & features (Vista), uninsuatll the Dell Printer software if listed.
  3. Download the Driver from the Dell Support Website
XP Driver
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=195205
XP Printer Application
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=205258
Vista Driver
Vista Printer Application
Hope this works... Please rate your feedback!!! Thanks
Nov 30, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
468 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
