Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Double image w/horseshoe shape top and bottom
There was a flash on the screen then the picture went to a double image causing what looks like a horseshoe shape up from the bottom and down from the top
Have the horse shoe very miner and the red will ajust side to side but not up or down
ray at 416-8307330 call if you can help thanks
Posted on Dec 24, 2008
    Problem Solver:
  • 13 Answers
Sounds like the convergence amplifiers need to be replaced
Posted on Dec 22, 2008
  • dj70s80s Dec 22, 2008
    400ma fuse next to flyback transformer is open..replace fuse
How can I make the image on tv screen smaller?
Press the Format button. It's directly below the power button. It has a symbol of a rectangle with a double-headed arrow inside.
Press it to cycle through the different picture shapes.
Sep 10, 2014 | Emerson LC320EM2 32" LCD HD Television
Toshiba 40BV700B - the screen has started to flicker with a bit of a double image up and down the screen. Eventually it freezes and sort of blurs up and down the screen.
Looks like either a TCON board failure or if you are lucky it could be a flex cable connection problem at the TCON or Main board.
Mar 21, 2014 | Toshiba Televison & Video
On my Toshiba Tecra when in GoogleChrome the the image on the screen is 25mm too far to the right. This makes it impossible to use the up/down key at the top right of the screen and the enlarge and...
Have you tried double clicking on the bar right at the top of the screen next to the minimize, maximise, close buttons? By double clicking in this area it'll change the size/shape of the browser screen, you can then reposition the window to the top left of your screen and then click and drag the bottom right hand side of his window once the cursor turns into a double headed arrow.
Apr 18, 2011 | Computers & Internet
My screen went blank but the sound works fine. We were watching TV when the screen went out. The sound stayed on. We still get sound but no picture. Is this worth fixing? If so what is the best way to go...
all in one day my screen started by showing a u look at top and bottom. all three colors kind of separated from each other and therefore made shadows on all the writing and double and triple vision on people and images. then it drawed in from sides and showed some black. then it popped in the back and no picture. the sound then came back on with no picture. so i shut it off and unplugged it. what do i have to get to fix this? thank you, Robert Hopkins
Jan 01, 2011 | Akai PT5598HD 55" Rear Projection...
I have the same problem with a 61uwx10b. I
the ics could have been defective, or maybe you missed a resistor or something. the ics could short out and cause the tv to totally shutdown if dead shorted, as some of these have no fuses. I would doublecheck all your solder connections and make sure nothing is shorted out and look for other bad resistors. here is my tutorial if this helps
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Jun 13, 2010 | Hitachi 61UWX10B 61" Rear Projection...
DOUBLE IMAGE ON SCREEN. tOP OF PICTURE LOOK LIKE A
That symptoms are due to failure of convergence out ICs in your TV that will be replaced to get correct converge picture on front screen.
There are 2 big black IC mounted on big aluminum heat sink and number would be written on as STKxxx, these 2 ICs will be replaced.
If you want to repair TV by yourself then confirm model number of TV to provide you more info or call local tech to replace said ICs.
Thanks.
Dec 21, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/reginald_bec291de192ca44f
Jun 16, 2017 | Mito Car Audio & Video
3 curved lines top & bottom/blurred picture
This indicates a convergence problem..convergence power supply probally.. however ive seen 2 other cuicits cause this ..
Sep 24, 2007 | RCA HD52W59 HDTV Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
