Question about Western Digital Caviar SE WD2500JS (WD2500JS20PK) 250 GB Hard Drive
New Hd HELP
I have an abit av8 socket 939 with a 3400 amd chip i just installed a 250 gb wd wd2500js. It shows up in bios but doesnt show up in windows and i cant edit it in bios? please help?
    Problem Solver:
  • 5 Answers
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...http://www.wdc.com
Posted on Apr 09, 2007
Need hd parameters to manually install my wd2500js sata drive.
Unless you have specific reason or odd hardware then then for most purpose setting the BIOS on a comuter to AUTO for the hard drive is all that is needed.
If the BIOS fails to see a SATA drive then in most instances there is an issue with the drive itself or it has had the settings changed at a low level.
In both those instances the settings for the drive itself would be of no help to you.
However if you really do need them they are available here.
http://www.wdc.com/wdsearch/?sc=&sl=en-US&sq=WD2500JS&Go=Go
Feb 04, 2011 | Western Digital WD2500JS 250GB SATA2...
Hello sir, i recovered some imported data from my corrupted hard disk (WD2500js) but after that i could not install the windows on it. I have partitioned it three times but didn't affect. i think i need a...
I think that your disk-drive is about to "die", and the symptom of not being able to install Windows (which tries to write many files onto the disk) is a strong indicator.
Is the drive still under warranty? If so, W.D. will give you a free replacement. If not, W.D. has a 'Customer Loyalty' program -- buy a new disk-drive from their web-site, and get a discount.
Oct 25, 2010 | Western Digital WD2500JS 250GB SATA2...
Have an AN9 32X mobo with a Sapphire HD 4850 (512) vc, which works fine with Win XP Pro, but when I go to install a new HD (WD 1tb) and new OS all I get is graphics card crashes and won't actually boot. ...
Try this site- http://abit.ws/page/sa/motherboard/motherboard_detail.php@pMODEL_NAME=Fatal1ty+AN9+32X&fMTYPE=Socket%20AM2&pPRODINFO=BIOS
I assume you know what key to press at boot up in order to get the machine to boot into bios. On mine I have to keep hitting the delete key at boot time for the Award setup screen to show. Other machines may take different key strokes.
Also you might want to get a copy of a compatible edition of a Linux distro and boot into it. You'll have to set your BIOS for the DVD to be your first boot drive in order for the "live" Linux DVD to boot into Linux.
Jul 09, 2017 | Abit Fatal1ty AN9 32X Motherboard
My 250 gb hard drive is only showing capacity of 127gb
Firstly install SP3 if that doesnt work you need to update your bios to get large disk support. If you dont want to perform any of these fixes you could simply split the drive into 2 or more partitions to access the full 250gb. Goto Control Panel/Computer Management/Disk Management you will see in there the missing gb's of your drive. Simply right click it format it and give it a drive letter.......Cheers from Scott
Apr 18, 2010 | Microsoft Windows XP Professional SP2
Dear Support I'm currently reconditioning an Aleinware desktop which was D.O.A. and totally non-functional and after taking it totally apart & re-seating the CPU with new Antec Silver 5 Thermal...
I don't think that you need a bios upgrade for a 'virus' infection - they generally don't go there, as modifications to the flash memory can be tricky and difficult without knowing the flash type; viruses generally affect OS areas as being much easier.
Mar 28, 2010 | Abit AV8 Motherboard
I can't get Vista Ultimate set up to recognize my WD 1TB HDD in a new build. Is this a software problem or problem with the HDD. I get the short beep at BIOS start up so I don't think its with the...
Few steps to check your harddisk status on the motherboard would resolve this issue. Checkin to the cmos setup and look for the detection of the HDD and the size it shows once you have done a formating.
Vista 64 bit shows issues at times while installing a new SATA 1TB HDD. Check if the 1TB HDD is installed on to SATA 0.
Use a WD Disk Manager and format the HDD initially and then try install Vista on to it. Else if this doesnt work on the system, Put the HD on to another working system and Format it with NTFS File system and try installing Vista.. You will be successful. Good Luck.
Feb 13, 2010 | Gigabyte GA-MA785GPMT-UD2H AM3 AMD 785G...
New ASUS A8V-MX motherboard will not boot to CD or HD with XP
The first thing is to make sure that your CD/DVD drive has the windows disk in it. Also check drive C which is where the windows will be installed. It may require that it is hard formated. Hard formatted means "format x /u" [format-space-drive to be formatted-space-right slash-u]. This will place the drive for "windows xp sp2", all of it, to one pass of zeroes. So, once we have a clean drive C and the installation disc is inserted into the CD/DVD drive, you may proceed to install. You will need to find "install" or "setup" and start it on he "RUN" mode. Any questions or help get back to me. CONSTANTIN (arzconst)
Jun 03, 2009 | ASUS K8V-MX Motherboard
Convert internal hard drive to external back-up drive
Greetings
use the cd installer that comes with "Master Cooler"
after successful installation, u can now use the Hard drive.
Jan 12, 2009 | Western Digital WD2500JS 250GB SATA2...
New cpu but no video output
I SEE YOU MENTIONED NOTHING ABOUT INSTALLING ANY DRIVERS FOR THE HD'S DID YOU?
GOOD DAY
KZ
Feb 28, 2008 | Intel Motherboard
Western Digital Caviar SE WD2500JS (WD2500JS20PK) 250 GB Hard Drive Logo
255 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
