Question about Adobe Audition 3 for PC (22011292)
I have just purchased Audtion 3.0 and need to know just how to set up micophone and get started. I am a novice to say the least!
If you are running your microphone(s) through a sound board, you need to make sure the board is being ran through a interface, preferably with XLR cords (it is more balanced than TRS or TS cords). Than from the interface (USB Interfaces are just fine) to your computer. Now that the hardware part is complete, all you have to do is "Arm" a track for recording, you do that by pushing the red "R" button on one of the tracks. After you go through the process of saving, push the record button. Hope that helps.
Posted on Jan 16, 2009
How do i use the micophone
To start voice recording, follow these steps:
1. Press the Menu button to return to Main Menu.
2. Select Voice
3. Press Play/Pause to start recording.
4. To pause recording, press Play/Pause again
5. To stop recording, press Select. A pop-up window will appear on the screen. Select Yes to
save recording. The recording will be saved in the RECORD/VOICE folder.
6. Press 'button to return to the Voice Menu.
Jun 20, 2011 | SanDisk Sansa Clip MP3 Player
Windshield washer pump is gone on my 1993 nissan truck xt.. Is it hard for a novice to fix???
The auto parts store (auto zone ) has a replacement kit available or call a auto salvage yard see if they have one. The units are usually held on with 10 mm bolts purchase a mm 1/4 inch drive socket set and that should do it empower you to do the job you may need to purchase a universal adapter with long extension to reach an inaccessible bolt.
Jul 03, 2009 | Nissan King Cab Cars & Trucks
SAMPLE RATE DIFFER ADOBE AUDITION 1.5
here is a tutorial that shows how to use edit/view in adobe audtion.
you will find what you need in this site also.
http://www.adobepress.com/articles/article.asp?p=478951
Jun 06, 2009 | Adobe Audition 1.5
Transmission swap for a '93 Toyota corolla
This is not a novice job. its quite sophisticated and you will need an assistant and a good set of tools to achieve this goal. It good to know a bit about the arrangement as well.
If you are considering it, i would advise to purchase the latest service and repair manual for this vehicle. this will help when you get to the really technical stuff dealing with the linkages and tcm.
May 28, 2009 | 1993 Toyota Corolla
03 yz 125 suspension set-up
You need to start with the spring sag. You need of 3 inches of sag front and rear with you on it and all of your riding gear on. you will need a friends help to measure for you.
May 22, 2009 | 2003 Yamaha YZ 125
Connecting lap top to internet
Try to connect with wireless lan to linksys router. first u shuld check ping the ipaddress of linksys router with laptop
Jobi
Feb 21, 2009 | Dell Latitude D600 Notebook
Micophone not working
unplug the headset then plug it toanother usb port.
check your audio settings in windows and make sure its unmuted.
if that doesnt help.
uninstall your usb ports then reboot and let them reinstall themselfs.
after that try again.
Jan 20, 2008 | Logitech ClearChat Stereo Headset Headset
Connection of HD TV Issues
hdmi cables u need also set moterol box out to 1080 i if it can or 720 p ok use hd antenna for locals in hd also
Jan 10, 2008 | Audio Players & Recorders
Midi sound prob
ok..try this open control panel->click on sounds and audio devices...click on advanced button->If your midi volume control is shown..make sure it is not muted and the midi volume is high..If it is not shown..then click on options->properties ->tick the midi box and close the window..then adjust the MIDI volume..I hope this helps
Regards,
VJ
Dec 01, 2007 | Edirol UA20 USB Audio/MIDI Interface...
Picture is yellow
Your picture tubes are weak or you need to do whats called a grey scale adjustment. In other words you need to put on a totally B&W movie or test pattern and adjust the red , green, and the blue screens to the best B&W you can get. Then you need to adjust the CRT drives to the best grey scale. If you do not know what this is, I'm afraid you should call out a pro to assist you with this alignment, as if you go messing around, and do not know what you are doing, you can make the set landfill material. Not for a novice to do. Good Luck
Sep 13, 2007 | JVC AV-56WP74 56" Rear Projection...
Adobe Audition 3 for PC (22011292) Logo
101 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
